ey, een vriend van mij krijgt al een tijdje de volgende foutmelding:
A problem has been detected and windows has been shut down to prevent damage to your computer.
IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this stop error screen restart your computer.
If this screen appears again, follow these steps:
Check to make sure any new hardware or spftware is proparly installed.
Is this is a new installation, ask your hardware or software manufacturer for any updates you might need.
If problems continue, disable or remove any newly installed hardware or software, disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disabe components restart your computer press F8 to selct advanced startup options and then select safe mode.
Technical information :
*** STOP : 0 x 0000000A ( 0 x 00000008, 0 x 00000002, 0 x 00000000 , 0x 804ECA6C)
Beginning dump op physical memory
Physical memory dump complete
Contact yor system administrator or technical support group for further assistance.
soms bij het afsluiten, maar soms ook gewoon tijdens t werken...
tis dus een windows xp professional os, ik heb geen idee wat er aan te doen, kan iemand mij helpen??
avb
avb
