online dungeonsiege
ik heb een probleem met dungeonsiege online spelen ik kan namelijk niet inloggen bijn zonematch ik krijg de error coud not connect
ik ben meteen naar microsoft.com gegaan om te kijken wat ik ken doen aan dit
bij microsoft zeggen ze dit
Dungeon Siege 1.0: Error Message: Could Not Connect to the ZoneMatch Server
The information in this article applies to:
Microsoft Dungeon Siege 1.0
Symptoms
When you try to start a multiplayer game by using ZoneMatch, you may receive an error message similar to the following:
Could not connect to the ZoneMatch Server.
Cause
This error may occur if Port 2300 is unavailable (blocked).
You must have Port 2300 available if you want to play Microsoft Dungeon Siege as a multiplayer game through a firewall, a proxy server, a router, Network Address Translation (NAT), or Internet Connection Sharing (ICS).
Resolution
To resolve this issue, open port 2300.
To verify that port 2300 is open or to open this port, please contact your network administrator or Internet service provider (ISP).
If you are the administrator of the network, please see your networking software documentation to determine how to open this port.
More Information
For additional information about the ports that you have to have to play a multiplayer game of Dungeon Siege, click the article number below to view the article in the Microsoft Knowledge Base:
Q320020 Dungeon Siege: Network Ports Required for Multiplayer Game
nu is mijn vraag hoe krijg ik poort 2300 open ?
  • Predator
  • Laatst online: 20:42
Predator
Suffers from split brain
Zit je achter een router ?
Zoja:
Het Grote Poortmappingsverhaal
Everybody lies | BFD rocks ! | PC-specs
zit niet achter een router en me firewal is uit :)
