Named DNS probleem
  • Rembrand20
  • Laatst online: 22-09-2023
Tweakers,
Ik heb een dns server op gezet maar het werkt niet. Krijg in de logfiles geen foutmelding maar ik kan het domein niet pingen.
mijn named.conf ******* zijn ip nummers
29
30
31
32
33
34
35
36
37
38
39
40
// Config file for caching only name server
options {
        directory "/var/named";
        forwarders  {
                213.239.***.3;
                212.239.***.4;
datasize 20M;
zone "." {
type hint;
file "root.hints";
zone "0.0.127.in-addr.arpa" {
type master;
file "pz/127.0.0";
zone "formulaforce.net" {
type master;
file "pz/formulaforce.net";
zone "linuxfreakz.tk" {
type master;
file "pz/linuxfreakz.tk";
zone "nfss.tk" {
type master;
file "pz/nfss.tk";
zone "135.***.213.in-addr.arpa" {
type master;
file "pz/213.***.135";
Mijn zone files
127*
$TTL 3D
@               IN      SOA     formulaforce.net. root.formulafirce.net. (
                                199609203       ; Serial
                                28800   ; Refresh
                                7200    ; Retry
                                604800  ; Expire
                                86400)  ; Minimum TTL
                                $TTL
                        NS      mail.formulaforce.net.
1                       PTR     localhost.
213*
135.***.213.IN-ADDR.ARPA.       IN      SOA     server  FIS-ADTC-01.formulaforce.net. (
                        2001042501 ; serial
                        3600 ; refresh
                        900 ; retry
                        1209600 ; expire
                        43200 ; default_ttl
1       IN      PTR     FIS-ADTC-01.formulaforce.net.
2       IN      PTR     nfss.tk.
@       IN      NS      mail.formulaofrce.net.
nfss.tk
$TTL 3D
@       IN      SOA     nffs.tk. root.nfss.tk. (
                        20020906       ; serial, todays date + todays serial #
                        8H              ; refresh, seconds
                        2H              ; retry, seconds
                        4W              ; expire, seconds
                        1D )            ; minimum, seconds
                MX      10 mail.formulaforce.net.  ; Primary Mail Exchanger
                TXT     "NFSS"
localhost       A       127.0.0.1
nfss.tk.        A       213.***.135.31
ns              A       213.***.135.31
www             A       213.***.135.31
ftp             CNAME   nfss.tk.
mail            CNAME   nfss.tk.
formulaforce.net
$TTL 1D
@               IN      SOA     formulaforce.net. root.formulaforce.net. (
                                200202151            ; Serial
                                8H                   ; Refresh
                                2H                   ; Retry
                                1W                   ; Expire
                                1D)                  ; Minimum TTL
localhost                        IN     A       127.0.0.1
FIS-ADTC-01                      IN     A       213.***.135.31
@                                IN     NS      FIS-ADTC-01.formulaforce.net.
linuxreakz.tk
$TTL 3D
@       IN      SOA     linuxfreakz.tk. root.linuxfreakz.tk. (
                        199609206       ; serial, todays date + todays serial #
                        2H              ; retry, seconds
                TXT     "Linuxfreakz.tk a part of FormulaForce"
linuxfreakz.tk. A       213.***.135.31
nfss            A       213.***.135.31
ftp             CNAME   linuxfreakz.tk.
mail            CNAME   linuxfreakz.tk.
forum           CNAME   linuxfreakz.tk.
Het gaat hier om de domeinen nfss.tk en linuxfreakz.tk deze hebben allebei in hun toplevel domain mail.formulaforce.net staan.
mail.formulaforce.net is de ns van mijn named server.
het formulaforce.net domein staat ergens anders geregistreerd en dat is ook het primaire domein.
nfss.tk en linuxfreakz.tk heb ik zelf geregistreerd en daar wil ik ook mijn eigen dns van bij houden.
Wie kan mij helpen.
Model 3 LR AWD Solid Black / Black / Aero / Trekhaak - Bestelling 2-10 Leaseplan, 4-10 Tesla, RN 22-09, Nieuwe RN 25-11, VIN Yes, leverdatum: ?/?/19(?)
  • serkoon
serkoon
mekker.
mail.formulaforce.net kan niet geresolved worden omdat jouw nameserver de zone formulaforce.net geconfigged heeft, terwijl je daar helemaal niet authoritive over bent (dat is bit) en je er geen A-mapping voor hebt gemaakt.
Zelf formulaforce.net in je nameserver hebben zitten is dus niet echt een goed idee..
  • Rembrand20
Ik heb nu alles er uitgehaald behalve nfss.tk en nu staat er dit nog
127*
$TTL 3D
@               IN      SOA     nfss.tk. root.hfss.tk. (
                                199609203       ; Serial
                                28800   ; Refresh
                                7200    ; Retry
                                604800  ; Expire
1                       PTR     localhost.
213*
135.239.213.IN-ADDR.ARPA.       IN      SOA     server  FIS-ADTC-01.formulaforce.net. (
                        2001042501 ; serial
                        3600 ; refresh
                        900 ; retry
                        1209600 ; expire
                        43200 ; default_ttl
2       IN      PTR     nfss.tk.
nfss.tk
$TTL 3D
@       IN      SOA     nfss.tk. root.nfss.tk. (
                        2H              ; retry, seconds
                TXT     "NFSS"
ns              A       213.***.135.31
ftp             CNAME   nfss.tk.
mail            CNAME   nfss.tk.
En natuurlijk mijn named.conf aangepast.
Maar het werkt nog niet.
  • serkoon
serkoon
mekker.
typo
Je kunt voor nfss.tk. het beste gewoon 1 A-mapping maken, bijv nfss.tk. en daar CNAMEs naar maken, dus niet alleen ftp en mail, maar ook ns en www. (zou kunnen dat de nameserver zoals je die aangeeft met een NS record geen CNAME mag zijn, maar per se een A-record, maar dat weet ik niet zeker)
Daarnaast heb je een NS record naar mail.formulaforce.net, ns.formulaforce.net is dan netter.
Die *** zijn niet nodig, we weten toch wel dat het 239 is.
Je serials zijn kun je het beste de huidige datum maken met een counter, verhoog je ze wel?
En dan de grote vraag: wat werkt er niet, wat heb je geprobeerd, log eens wat?
[ Voor 0% gewijzigd door serkoon op 06-09-2002 15:21 . Reden: Toevoegseltje ]
Doe eens het volgende:
tail -f /var/log/messages &
/usr/sbin/named <opties>
en post dan ff de startup messages van named.
Mochten hier geen messages in komen te staan kun je 2 dingen doen:
1) grep 'named' /var/log/* (om de logfile te vinden)
2) start named met debugging flaggen.
Het gaat mij/ons om de startup meldingen...
  • BamSlam_
Ik zou root.formulaf*I*rce.net ff veranderen in root.formulaf*O*rce.net
  • Rembrand20
De startup meldingen
May  9 15:41:18 FIS-ADTC-01 named[9838]: stopping command channel on 127.0.0.1#953
May  9 15:41:18 FIS-ADTC-01 named[9838]: no longer listening on 127.0.0.1#53
May  9 15:41:18 FIS-ADTC-01 named[9838]: no longer listening on 213.239.135.31#53
May  9 15:41:18 FIS-ADTC-01 named[9835]: exiting
May  9 15:41:18 FIS-ADTC-01 named: named shutdown succeeded
May  9 15:41:18 FIS-ADTC-01 named[10090]: starting BIND 9.2.0 -u named
May  9 15:41:18 FIS-ADTC-01 named[10090]: using 1 CPU
May  9 15:41:18 FIS-ADTC-01 named[10093]: loading configuration from '/etc/named.conf'
May  9 15:41:18 FIS-ADTC-01 named[10093]: no IPv6 interfaces found
May  9 15:41:18 FIS-ADTC-01 named[10093]: listening on IPv4 interface lo, 127.0.0.1#53
May  9 15:41:18 FIS-ADTC-01 named[10093]: listening on IPv4 interface eth0, 213.239.135.31#53
May  9 15:41:18 FIS-ADTC-01 named[10093]: command channel listening on 127.0.0.1#953
May  9 15:41:18 FIS-ADTC-01 named[10093]: zone 0.0.127.in-addr.arpa/IN: loaded serial 20020906
May  9 15:41:18 FIS-ADTC-01 named[10093]: zone 135.239.213.in-addr.arpa/IN: loaded serial 20020906
May  9 15:41:18 FIS-ADTC-01 named[10093]: zone nfss.tk/IN: loaded serial 20020906
May  9 15:41:18 FIS-ADTC-01 named[10093]: running
May  9 15:41:18 FIS-ADTC-01 named[10093]: zone 0.0.127.in-addr.arpa/IN: sending notifies (serial 20020906)
May  9 15:41:18 FIS-ADTC-01 named[10093]: zone 135.239.213.in-addr.arpa/IN: sending notifies (serial 20020906)
May  9 15:41:18 FIS-ADTC-01 named[10093]: zone nfss.tk/IN: sending notifies (serial 20020906)
May  9 15:41:18 FIS-ADTC-01 named: named startup succeeded
  • Rembrand20
Wat er niet werkt is heel simpel ik kan het domein nfss.tk niet benaderen op wat voor manier dan ook.
OP de machine zelf gaat het goed (locaal dus) maar op een andere machine kan die niets vinden.
  • Rembrand20
Dit is ook zo vaag
C:\>ping www.nfss.tk
Unknown host www.nfss.tk.
Zie het laatste puntje bij Unknown host www.nfss.tk.
  • qless
  • Laatst online: 13-08 16:41
qless
...vraag maar...
Is jouw machine wel de dns server voor dat domain?
Als het locaal werkt, maar ergens anders niet lijkt me dat het probleem.
Website
Drones: Air 3s, Mini 4 Pro, Avata 2
Camera's: Canon R6, Canon 5d2, Dji Osmo Action 4
Objectieven: 8 fisheye, 14f2.8, 24f2.8, 50f1.8, 135f2, 17-40f4, 24-105f4, 70-300f4-5.6, 150-600f5-6.3, 25f2.8-2.5x-5x
nffs.tk toch?
voor www.nffs.tk vind ik...
> nslookup www.nffs.tk
Address: 195.20.32.104
naar mij idee heb je het soa gewoon niet.
zorg dat je het soa record krijgt (dus een verwijzing voor het te beheren domain naar jou dns server op de ns server van je dns-provider)
  • Rembrand20
qless schreef op 06 september 2002 @ 15:58:
Hoe krijg ik hem domainserver voor dit dns
zie post hierboven
het laatste puntje is niet zo vreemd... in principe hoort dat puntje daar altijd te staan (root domain).
  • Rembrand20
Die soa moet ik die bij dot.tk regelen ???
