[ Debian ] [ Apachetoolbox ] Error bij compilen apache
  • saviour
Ben ik weer...
Ik kon er zelf niets over vinden, maar ik krijg de volgende fout bij het compilen van apache:
======== Error Output for sanity check ========
cd ..; gcc -I/usr/local/mysql/include/mysql -DLINUX=22 -DMOD_SSL=208109 -I/home/saviour/Apachetoolbox-1.5.59/src/php-4.2.2 -I/home/saviour/Apachetoolbox-1.5.59/src/php-4.2.2/main -I/home/saviour/Apachetoolbox-1.5.59/src/php-4.2.2/main -I/home/saviour/Apachetoolbox-1.5.59/src/php-4.2.2/Zend -I/home/saviour/Apachetoolbox-1.5.59/src/php-4.2.2/Zend -I/home/saviour/Apachetoolbox-1.5.59/src/php-4.2.2/TSRM -I/home/saviour/Apachetoolbox-1.5.59/src/php-4.2.2/TSRM -I/home/saviour/Apachetoolbox-1.5.59/src/php-4.2.2 -DEAPI -DEAPI_MM -DUSE_EXPAT -I./lib/expat-lite `./apaci` -I/home/saviour/Apachetoolbox-1.5.59/src/mm-1.1.3 -L/usr/local/lib -L/home/saviour/Apachetoolbox-1.5.59/src/mm-1.1.3/.libs -o helpers/dummy helpers/dummy.c -lz -Wl,-rpath,/usr/local/lib -Wl,-rpath,/usr/local/mysql/lib/mysql -rdynamic -L/usr/local/lib -L/usr/local/mysql/lib/mysql -Lmodules/php4 -L../modules/php4 -L../../modules/php4 -lmodphp4 -lc-client -lmysqlclient -lcrypt -lcrypt -lssl -lcrypto -lresolv -lm -ldl -lnsl -lresolv -lcrypt -L/usr/local/mysql/lib/mysql -lmysqlclient -lcrypt -lm -lssl -lcrypto -lmm
/usr/bin/ld: cannot find -lz
collect2: ld returned 1 exit status
make: *** [dummy] Error 1
============= End of Error Report =============
Dus heb ik gezocht op "lz":
server:/home/saviour/Apachetoolbox-1.5.59# apt-cache search lz
aris-extractor - Scan system logs for security incidents and report them to ARIS
ark - An archiver for KDE
bzip2 - A high-quality block-sorting file compressor - utilities
elza - Script language for automating HTTP requests
file-roller - an Archiver for GNOME
gnomekiss - A KiSS paper doll viewer for GNOME
guitar - A GTK+ archive extraction/viewing tool.
inewsinn - NNTP client news injector, from InterNetNews (INN).
inn - News transport system `InterNetNews' by the ISC and Rich Salz
inn2 - News transport system `InterNetNews' by the ISC and Rich Salz
inn2-inews - NNTP client news injector, from InterNetNews (INN)
liblzo-dev - Development support files for the lzo library.
liblzo1 - A real-time data compression library.
libmagick5 - Image manipulation library (free version).
libtk-img - Extended image format support for Tcl/Tk
libungif-bin - programs to convert GIF images
libungif3g - shared library for GIF images (runtime lib)
libungif3g-dev - shared library for GIF images (development files)
libungif4-dev - shared library for GIF images (development files)
libungif4g - shared library for GIF images (runtime lib)
libzip-ocaml-dev - ocaml compression libraries
lsh - baby shell for novices with DOS compatible commands
lzop - A real-time compressor.
mscompress - Microsoft "compress.exe/expand.exe" compatible (de)compressor
scrollz - An advanced ircII-based IRC client
sdic-gene95 - GENE95 dictionaries for sdic (installer)
giflib-bin - programs to convert GIF images
giflib3g - shared library for GIF images (runtime lib)
giflib3g-dev - shared library for GIF images (development files)
gimp1.2-nonfree - GIF support for the GNU Image Manipulation Program
lha - lzh archiver
ncompress - Original Compress / Uncompress for News Transfers etc.
Daarvan heb ik het volgende geïnstalleerd:
liblzo1
liblzo-dev
Moet ik er soms nog meer van installeren?
Ik dacht eerst dat "lz" met mod_gzip te maken zou hebben, dus probeerde ik het zonder die module, maar nog steeds kreeg ik deze foutmelding.
  • Sjonny
  • Laatst online: 22:10
Sjonny
Fratser
zlib1g - compression library - runtime
zlib1g-dev - compression library - development
ik gok er op dat ie die wil hebben (geen garantie ;))
The problem is in the part of your brain that handles intelligence.
  • viper
  • Registratie: Augustus 1999
  • Laatst online: 06-08 23:31
je mist waarschijnlijk een development package van 'z'. Weet niet helemaal zeker wat het is, maar dacht dat het een compressieproggie is
Ok. Sjonnie was me net voor :P
  • saviour
Nou, ik heb zlib1-dev nu ook geïnstalleerd en ik ben het opnieuw aan het proberen.
Alvast bedankt, ik zal laten weten of het gelukt is :)
Btw, hoe kwam je erbij dat ik die package moest hebben?
  • saviour
Goed, het werkt allemaal weer..
Nu even uitzoeken wat er nog moet gebeuren aan MySQL.. er moet nog een wachtwoord ingestel worden enzo geloof ik. Ook nog tabels aanmaken voor Horde / IMP.
