mdk 8.2 | Limewire 2.55 installeren = error
  • himlims_
himlims_
🐧 Linux HOoligan
[root@localhost Internet Appz]# ./LimeWire255.bin
Preparing to install...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Launching installer...
Error: Unrecognized JVM specific option `-Xmx50331648'.
Error: Unrecognized JVM specific option `-Xms16777216'.
Invocation of this Java Application has caused an InvocationTargetException. Thi
s application will now exit. (LAX)
Stack Trace:
java.lang.NoClassDefFoundError: ZeroGcf
at ZeroGcq.a(source file unknown:line unknown, pc 0x8753049)
at ZeroGcj.<init>(source file unknown:line unknown, pc 0x86dad74)
at ZeroGcq.<init>(source file unknown:line unknown, pc 0x86be8a9)
at ZeroGb3.a(source file unknown:line unknown, pc 0x86ff907)
at com.zerog.ia.installer.Main.a(source file unknown:line unknown, pc 0x
86a74a5)
at com.zerog.ia.installer.Main.b(source file unknown:line unknown, pc 0x
864e1c1)
at com.zerog.ia.installer.Main.main(source file unknown:line unknown, pc
0x85b4281)
at java.lang.reflect.Method.invoke(Method.java:native)
at com.zerog.lax.LAX.launch(source file unknown:line unknown, pc 0x82ab9
d6)
at com.zerog.lax.LAX.main(source file unknown:line unknown, pc 0x825ebcb
dat is de error die ik krijg. Ik dacht eerst dat het aan m'n java oid lag, maar dit werkt goed.
iemand enig idee hoe dit te fixen?
  • GeeMoney
  • Laatst online: 00:31
Weet je zeker dat je j2re hebt geinstalled?
Wat zegt je $PATH ?
  • himlims_
himlims_
🐧 Linux HOoligan
[root@localhost j2re]# rpm --install j2re-1_4_0-fcs-linux-i386.rpm
package j2re-1.4.0-fcs is already installed
  • himlims_
himlims_
🐧 Linux HOoligan
/me *
