Abits nieuwe GF 4 koeler [Pic inside :)]
  • SmokeyTheBandit
  • Laatst online: 17-06 10:20
SmokeyTheBandit
DOCer met Pensioen
ABIT Computer Corp will soon introduce a new graphics card powered by Geforce4 Ti4200 GPU. Although the card has 3.6ns memory on board, its revolutionary cooling system will ensure this will be one of if not the fastest Geforce4 Ti4200 yet. Read More for more info.
UPDATE: We now have first exclusive pictures of the new card. To see them - Read More...
OTES stands for Outside Thermal Exhaust System. It is ABIT’s new and patent pending VGA Cooling system.
ABIT claim it will be able to lower temperatures by around 15% comparing to standard cooling system. This includes GPU temperatures only I belive. The fan on the GPU is spinning @ 7200rpm!
ABIT believes their new Geforce4 TI4200 will be able to offer TI4600 performance because of the overclocking possibilities. That means you'll be getting Geforce4 Ti4600 performance at the price of Ti4200 card!
Not much is known about the OTES cooling system at this stage because its yet to be announced officially. It is set to be launched in September. If you were thinking about getting Geforce4 card soon, maybe you should wait for their announcement. It could be worh it ;)
Afbeeldingslocatie: http://forum.oc-forums.com/vb/attachment.php?s=70ec32e979ab6176bdf4fbbed5c23ab4&postid=1000266
Hieruit blijkt dus dat Abit ook de Heatpipe ondekt heeft :)
Turn it off and on again.
  • LoBbY_1
  • Laatst online: 18-07 21:03
Wahaha das wel gaaf, kun je (als je erg slim bent) denk ik ook nog wel zelf maken, maar was die grote zwarte gleuf op die kaart? lijkt wel een lucht inlaat 8)
[ Voor 0% gewijzigd door LoBbY_1 op 01-09-2002 13:07 . Reden: lijk = lijkt :P ]
Een echte golver is nooit uitgeput
  • Alien_Inside
  • Laatst online: 30-07 18:29
Alien_Inside
-geen-
erh... pic niet verkeerd om :?
en de prijs? zal door die revolu heatpipe dan wel tenkoste gaan... dus heb je een goedkope ti4400/4600 voor hetzelfde :)
-geen-
  • sarlo
  • Laatst online: 28-08 10:50
Als dit waar is zal deze kaart best aantrekkelijk worden >:)
helemaal als ie maar ong 200 euro gaat kosten _/-\o_
Iemand gf3 ti200 deluxe kopen :7
  • SmokeyTheBandit
SmokeyTheBandit
DOCer met Pensioen
LoBbY_1 schreef op 01 september 2002 @ 13:06:
Wahaha das wel gaaf, kun je (als je erg slim bent) denk ik ook nog wel zelf maken, maar was die grote zwarte gleuf op die kaart? lijk wel een lucht inlaat 8)
Das de uitlaat zeg maar :)
wel lomp :x
  • sarlo
ik vind er niks lomp aan
zeg nou zelf wat doe je liever
200 euro of 400 euro betalen??
Want je kunt deze kaart net een gf4 ti4600 laten draaie
  • Bart-01
  • Laatst online: 21-08 19:00
[b][Hieruit blijkt dus dat Abit ook de Heatpipe ondekt heeft :)
Ik zie niets dat lijkt op een heatpipe, wat ze doen is gewoon de warme lucht naar buiten afvoeren.
En 7200toeren, dat zal wel veel herrie maken :(
Do as I say, don't do as I do.
Afbeeldingslocatie: http://home.quicknet.nl/qn/prive/j.de.vlieger/1030745915_OTES2.jpg
prutser.
Maar op die site waar jij je text vandaan hebt hebben ze die foto op verzoek van Abit weg gehaald. Naja het ziet er iig goed uit.
[ Voor 0% gewijzigd door Verwijderd op 01-09-2002 14:51 . Reden: :+ ]
  • Pubbert
  • Laatst online: 10-09 16:33
Pubbert
random gestoord
gfo schreef op 01 september 2002 @ 13:12:
lol, ziet er erg bruut uit! (is die van leadtek nix bij :P)
maar een Ti4600 kun je ook weer overclocken he :)
Ik vind em er heel stoer uitzien, das niks bij de koeler van mijn GF4 :P
ja kan ik met de geforce 4 die ik nu heb ook wel...
Verwijderd schreef op 01 september 2002 @ 13:16:
Ik vind em er heel stoer uitzien, das niks bij de koeler van GF4 :P
Wat denk je dat dit is |:(
  • Vorkie
er zit zelfs een xtra aansluiting voor een fan op :Y) zal je wel nodig hebben met 7200RPM :P
  • SmokeyTheBandit
SmokeyTheBandit
DOCer met Pensioen
Heb je dat tegen mij ..... :?
:r :r :r :r
Zeg dan niks ...... sjees :X
Smokey_The_Bandit schreef op 01 september 2002 @ 13:31:
:r :r :r :r
Yup als je het post doe dan met een knappe foto en niet eentje die op de kop staat :{
  • SmokeyTheBandit
SmokeyTheBandit
DOCer met Pensioen
Verwijderd schreef op 01 september 2002 @ 14:41:
Hmmmm bleek dus een "grapje" te zijn :P
8)7
  • Hahn
Ziet er wel geinig uit :P
The devil is in the details.
  • phYzar
  • Laatst online: 23:34
ik heb mijn videokaart toch echt zo in mijn kast hangen, misschien zit jouw moederbord wel op zijn kop :)
  • BounceMeister
Zo'n koeler moeten zo ook los gaan verkopen! Ze kunnen dan de exhaust aan het bovenste slotplaatje maken, zodat je het geheel bovenop je videokaart kunt plaatsen. Alleen weet ik niet of de GPU's van alle Ti4200/4400/4600 op dezelfde plaats zitten. Misschien zou een draaibare plastic kap en een zelf af te zagen heatpipe die je dan bevestigt op het slotplaatje een oplossing zijn. Of gewoon een flinke PCI kaart met een kap om de AGP kaart heen en een flinke fan erin, die alle lucht langs je videokaart zuigt en naar buiten blaast. Ik heb nu wel een slot koeler, maar die is te dik en die zit niet zo mooi om de AGP kaart heen.
Het kost je wel een PCI slot die extra koeler.
Meestal zit er ook nog een extra slotplaatje boven de AGP kaart, daar zou dan nog een exhaust kunnen komen om de andere kant te koelen..
Oeps typfout, moet zijn das niks bij de koeler van mijn GF4
  • FastBunny
  • Laatst online: 08-09 12:51
FastBunny
Give it the Works !
Dat sleufje lijkt wel een soort pcmcia slot voor extra geheugen kaarten ofzo. Maar zal wel voor koeling zijn, wel jammer dat het verplicht de opoffering van het eerste pci slot is :(
Server: Dell PowerEdge R610, 48GB DDR3 1333MHz, 3 x 4TB IronWolf RAID5, Dell H700, VMware ESXi 6.0
Laptop: Dell Latitude E6510, Intel i5-560m, 8GB RAM, 128GB Samsung SSD, 250GB 7200rpm, 15.4" WUXGA FHD
PSN: FastBunny_NL
FastBunny schreef op 01 september 2002 @ 15:52:
Misschien is dat toch niet zo erg. Want is het niet vaak zo dat het agp-slot en het eerste pci-slot een irq delen?
  • bobo1on1
  • Laatst online: 19-10-2025
Verwijderd schreef op 01 september 2002 @ 15:54:
Klopt ja, als je dat slot gebruikt kan je 3d prestatie nogal achteruit gaan, en als je daar een kaart in steekt dan kan die koeler bijna geen lucht meer aanzuigen.
Impedance, a measure of opposition to time-varying electric current in an electric circuit.
Not to be confused with impotence.
  • FastBunny
FastBunny
Give it the Works !
Ik gebruik anders toch gewoon het slot onder het agp slot met een videobewerkingskaart, alles is al harstikke vol namelijk ;)
Geen enkel probleem en de 3d prestaties zijn voor een GeForce ddr gewoon heel goed :)
PSN: FastBunny_NL
  • sebastius
  • Laatst online: 09-09 19:18
sebastius
Laten we lekker link gaan doen
Hmm, dan moet je dus je slotrand insmeren met koelprut, dan is je hele kast de cooler voor die gforce... Ziet er wel bruut uit, maar ik denk dat het overkill is.
7200 toeren met zo een kleine fan? Dat wordt het geluids nivo van een jumbojet ben ik bang :) Niks voor mij.
  • Phaerion
  • Laatst online: 23-12-2024
Phaerion
Stillborn!!!
Maar volgens mij kun je niet op alle geheugen chips een heatsinkje plakken.
Het lijkt me dat die koeler dan ietwat in de weg zit. :{
Maar zo'n radiaalkoeler op je kaart is wel vet.
Alleen hij zuigt in plaats van dat hij op de chip blaast.
Da's wel minder....dan profiteren de geheugenchips niet echt mee van de luchtstroom.
[ Voor 0% gewijzigd door Phaerion op 01-09-2002 17:24 . Reden: oeps verspreking. :P ]
Snoep verstandig, lik m'n reet! :P
Erg geile kaart :)
  • Yonni
  • Laatst online: 01-06 10:53
woei! dat ziet er ubervet uit man _/-\o_ Abit... :*)
maar zal dat ding niet rete veel geluidmaken met die fan @ 7000 rpm :o
D3200 - 35/F1.8G, 60/F2, 70-300/F4-5.6
  • Crash
  • Laatst online: 19:24
hij ziet er wel vet uit >:)
leuk om te zien zo, hopelijk komen er meer fabrikanten met 'nieuwe' soorten koelers
  • Aikon
Wat een lelijk ding zeg.
Gelijk je PCI slot weg.
Maar ja, voor de echte overclocker zal het wel leuk zijn, ook al zal de echte overclocker het nog liever zelf in elkaar knutselen denk ik. :)
