k ben dus nu zeker van plan zo`n speler te kopen maar hoeveel tekens mag die mp3 tags zijn ?
en leest dei alleen artiest + songtitle of ook nog is album title uit ?
het staat niet in de onderstaan de text namelijk :(
ah site doet het nu wel
komt oz van de site van de fabrikant.. k word er niet wijzer van.
NAPA DAV316 supports ID3 tag display. For each MP3 track playing, you will be able to observe the track information on the LCD of the player, including title, artist, playing time , compression ratio, album.
NAPA DAV316 is supplied with on-cord remote control. Every DAV316 package accompanies with a handy line remote control with ear phone, which allows users to operate all the functions of the player with extra convenience.
NAPA DAV316 is able to recognize and play multi-session CD. A multi-session CD is a data CD to which data is added incrementally in more than one session, allowing you to periodically add and update files and folders to your CD.
NAPA DAV316 has the greatest compatibility with most brands of CD-R/CD-RW disc. We have tested most of the well-known brands of CDRW and verified that they are able to be recognized and played by our DAV316.
NAPA DAV316 supports two kinds of file search mode to search a file at high-speed.
(1)Search a file number.(2)Search a directory level. This feature changes skip condition b file level or directory level for MP3 CD, which makes file searching easier and faster. Total number of files and directories supported would be up to 630.
Well-developed anti-shock feature. NAPA DAV316 provides and extraordinary ESP function of up to 120 seconds, making it impervious to the skipping and jitter experienced during heavy exercise of while being jostled.
Key Features
MP3, CD-DA disc playback.
Line remote control
ID3 information display:
Album / Artist / Title / Playing Time
Support Multi-session CD-R/RW disc playback.
Searching by directory / file selectable.
MP3/CD-DA with 120/40 seconds Anti-shock function.
5 bands EQ Mode : Classic / Pop / Jazz / Rock / Normal.
Song Programming : up to 32 songs.
Play Mode : Repeat DIR / Random Repeat DIR / Introduce /
Repeat One / Repeat All / Random Repeat All / Random
Song Tracking : Fast Forward / backward
FF / FW scanning in one track (CD Only)
Digital Volume Control : 32 Steps
Key Hold
Sony Mechanism
Specifications
KIND OF PLAYING FILES MP3, CD-DA.
DIGITAL VOLUMN CONTROL 32 steps
AUDIO FREQUENCY RANGE 20Hz ~ 20 kHz
MAXIMUM OUTPUT > 25mW (16 Ohms)
SIGNAL TO NOISE RATIO > 90 dB
TOTAL HARMONIC DISTORTION < 0.1%
AUDIO OUTPUT Ear-phone jack
LINE-OUT Line-out jack
OPERATING TIME 10-15 hours (MP3/128kbps/Alkaline Type)
6-12 hours (CD-DA ESP/Alkaline Type)
8-13 hours (CD-DA without ESP/Alkaline Type)
bron: http://www.amaxhk.com/products/napa/dav316/dav316.htm
  • SEFje
  • Laatst online: 09-03 11:51
Misschien moet je een mailtje sturen naar de mensen van www.mp3cdspelers.nl aangezien zij het ding in hun assortiment hebben kunnen ze daar vast wel uitsluitsel over geven...
SEFje schreef op 31 augustus 2002 @ 11:29:
k denk dat ik dat inderdaad maar eens ga doen.
dat dat nergens staat :(
beetje stom :)
leg het aan mij of staat er geen mail adres op die site?
hm gevonden :D
