crosshair zit in het zelfde pulldown menu, andere tab.
voor zekerheid kan je checken voor system requirements. dit is voor 2000
AutoCAD uses the Autodesk® Heidi® 3D graphics system and supports dynamically loadable Heidi 3D Display Drivers. These Heidi Drivers are linked into AutoCAD at run time and allow AutoCAD to take advantage of 3D graphics hardware.
There are two Heidi 3D Display Drivers at present, Heidi Software and Heidi OpenGL. A third, Heidi Direct3D, will be provided in the future as a downloadable update to AutoCAD.
To use AutoCAD with OpenGL, the OpenGL driver provided by the 3D graphics card vendor must have the following characteristics:
Full support of OpenGL: Version 1.1 or later.
An OpenGL Installable Client Driver (ICD): The 3D graphics card must provide a full ICD in its OpenGL driver software. The "miniGL" driver provided by some 3D graphics cards and associated drivers is not sufficient for use with AutoCAD.
maar jaa...werken met 16 kleuren, niet fijn voor je oog.
