Wat is jou mening: Epox 8K9A3+ of de Abit Abit-MAX2
  • 58 views sinds 30-01-2008
  • SlowikPL
  • Laatst online: 18-08 14:37
Wat zou jij kiezen?
Ik sta nu een keus te maken tussen Epox 8K9A3+ en de Abit Abit-MAX2. Wat zou jij doen?
Ik heb net een MSI KT3-Ultra2-R verkocht wegens ontevredenheid.Slechte IDE en overklok performance.Ik zoek een ultiem bord voor mijn toekomstige XP-2700+ (FSB333) en Gigabyte MAYA-II-GV-R9700-PRO en PC3200 Corsair Platinum C2?
1te. keus
Levertijd in Nederland WK37/38 Info http://www.tweakers.net/pricewatch/35927
Afbeeldingslocatie: http://202.168.194.118/abit/upload/products/AT7-MAX2_pic6.jpg
Spec`s
PROCESSOR
Supports AMD-K7 Athlon / Athlon XP Socket A 200/266MHz FSB Processors
Supports AMD-K7 Duron Socket A 200 MHz FSB Processors
Chipset
VIA KT400 / VT8235
Supports Hi-Speed UniversaSeriaBus (USB 2.0)
Supports Advanced Configuration and Power Management Interface (ACPI)
Accelerated Graphics Port connector supports AGP 4X/8X (1.5V/0.8V)
Memory
Four 184-pin DIMM sockets
Supports 2 DIMM DDR 333/400 (Max. 2GB)
Supports 3 DIMM Un-buffered DDR 200/266 (Max. 3GB)
Supports 4 DIMM Registered DDR 200/266 (Max. 3.5GB)
SeriaATA
On board Marvel88i8030 Controller x 2
Support SATA data transfer rates 150 MB/s (1.5G bps)
RAID
High Point HPT374 IDE RAID Controller supports Ultra DMA 33/66/100/133
RAID 0/1/0+1(striping + mirroring mode for boosting performance and data security)
Audio
6-ChanneAC 97 CODEC on board
Professional digital audio interface supports 24-bit S/PDIF Out
Media XP (Optional)
Supports card reader function for Memory Stick™, Secure Digital™ and Type I/II CompactFlash™
Supports Wireless Remote Control and S/PDIF Out / Mic In / Headphone Out / USB 2.0 / IEEE 1394
System BIOS
SoftMenu™ Technology to set CPU parameters
Supports Plug-and-Play (PNP)
Supports Advanced Configuration Power Interface (ACPI)
Supports Desktop Management Interface (DMI)
Write-Protect Anti-Virus function by AWARD BIOS
LAN
On board 10/100Mb Operation supports ACPI & Wake on LAN
IEEE 1394
Supports IEEE 1394a at 100/200/400 Mb/s transfer rate
InternaI/O Connectors
1 x AGP, 5 x PCI slots
Floppy Port supports up to 2.88MB
4 x Ultra DMA 33/66/100/133 Connectors
2 x SeriaATA 150 Connectors
2 x USB headers, 1 x IEEE 1394a header
1 x CD-IN, 1 x AUX-IN
Back PaneI/O
1 x PS/2 Keyboard, 1 x PS/2 mouse
4 x USB, 2 x IEEE 1394
1 x S/PDIF Output
Audio connectors (Front Speaker, Line-in, Mic-in, Center/Sub, Surround Speaker)
2 x USB, 1 x RJ-45 LAN Connector
Miscellaneous
ATX form factor
Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
2de. keus
Levertijd Nederland WK 40/41 Info:Epox Nederland
Afbeeldingslocatie: http://www.tbreak.com/forums/attachment.php?s=e691cfa19d7c10f3f60704b706f7360c&postid=105006
Epox 8K9A3+
Spec's
PROCESSOR:
The Socket A compatible AMD AthlonTM XP processor 1500+ to 2200+, 600MHz to 1.4GHz AMD AthlonTM and AMD DuronTM processor up to 1.3GHz
CHIPSET:
VIA KT400 AGPset (KT400+ VT8235)
DRAM MODULE:
184pin DDR DIMM x 4 for PC2700 Memory
DRAM Size: 64MB to 4GB
EXPANSION SLOT
PCI x 6 8x AGP x 1
ONBOARD I/O
Winbond W83697HF LPC I/O integrated with FDD, Parallel, Game, Serial and IrDA v1.0 and Power-On Controllers
ONBOARD PCI / IDE:
PCI Bus IDE Port with PIO / Ultra DMA-133 x 2 (Up to 4 Devices)
Extra dual channel IDE Port by HPT374 with Ultra DMA-133 & IDE RAID x 4 (Up to 8 Devices)
-Supports JBOD function (Just Bunch One-Disk)
Onboard LAN(By VIA VT6103):
Integrated 10/100MB fast Ethernet controller in chipset with external VIA VT6103 physical Layer by RJ-45 connector
I/O CONNECTOR:
PS/2 Mouse and PS/2 style Keyboard
COM1, COM2, Printer, Audio-in/out, MIC & Game Port connectors
USB:
Supports USB2.0 specification
USB connector x 6 (2 for Opt.)
BIOS:
Award Plug & Play BIOS
Built-in AC97 Digital Audio (By RealTek ALC650):
Compliant with AC97 2.2 specification
6 channel slot slectable DAC output for multi-channel applications
Supports digital SPDIF
EXTENDED FUNCTION:
Supports Hardware Monitoring Function by W83697HF
Supports exclusive KBPO (KeyBoard Power On)
Supports STR (Suspend To RAM) power saving Function
Supports CPU Vcore setting via BIOS
Supports CPU Clock setting via BIOS
Supports CPU Multiplier setting via BIOS
Supports Memory Voltage setting via BIOS
Supports Wake-On-LAN Function
Post port onboard design with LED display
FORM FACTOR:
305mm x 245mm x 40mm ATX Size
* Intel Core i7-6700K @ 4.8Ghz * Asus MAXIMUS VIII EXTREME* nVidia Asus Poseidon 1080Ti * Mushkin 16 GB * SSD Samsung M.2 2280 256GB + 3x Samsung 256GB 850Pro* Enermax Revolution85+ 1250W * CM Stacker 832 SE * Waretcooling CPU, NB ,VGA 3x Mora
  • BalusC
BalusC
Carpe diem
Abit AT7 MAX2
Waarom? Dit merk staat bij mij heel hoog. Dat is puur persoonlijk; sinds de BP6 ben ik voorgoed Abit-fan ;)
Maar het is moeilijk om te zeggen welke van die twee beter is. Ze hebben beiden dezelfde chipset, evenveel geheugenslotjes, bieden praktisch dezelfde overklokmogelijkheden, etc. Abit heeft het voordeel dat ze afstand doet van allerlei legacy spul, zo kun je weer een heel tijd vooruit. Epox heeft op haar beurt lekker veel IDE RAID poorten en een handige poort 80h scannertje (dat display'tje). Dat had je zelf al uitgevonden, zie ik (waslijsten van specs..) :)
Kortom: het is een beetje ondoenlijk om te zeggen welke beter is; dat is nog altijd een persoonlijke keuze. We zijn hier geen adviesbureau ;)
[ Voor 0% gewijzigd door BalusC op 29-08-2002 17:42 . Reden: grammatica ]
  • Exirion
  • Laatst online: 13:07
Exirion
Gadgetfetisjist
Zoveel mensen, zoveel meningen: zie hierboven :)
