Asus RTX 5090 OC - AMD 9-9950 X3D en DDR5 G-Skill 64GB Ram
/edit: Al 1 gevonden: http://www.hotscripts.com/Detailed/9739.html
werk te krijgen .
Maar goed dat ik de helpfile van dreamweaver wel in kon lezen .
Processing forms
Forms are processed by the script or application specified in the action attribute of the form tag. Select a form and look in the Property inspector to see what the associated action is.
The simplest forms use JavaScript or VBScript to perform all form processing on the client side (as opposed to sending the form data to the server for processing). For example, you might have a small form at the bottom of a page that contains only two radio buttons labeled Yes and No, plus a Submit button. The form action might be a JavaScript function defined in the head section of the document that displays one alert if the user selects Yes and another alert if the user selects No:
function processForm(){
if (document.forms[0].elements[0].checked){
alert('Yes');
}else{
alert('No');
To use a client-side JavaScript function as the form action:
1 Select a Submit button in a form.
2 Attach the Call JavaScript behavior to the button. (See Call JavaScript.)
3 In the JavaScript text box that appears while attaching the behavior, enter processForm().
4 Add a processForm() JavaScript function (like the one shown above) to the head section of your document.
You can handle many form-processing tasks using client-side scripting, but you can't save the data entered by the user or send it to someone else. For such purposes you need a server-side application such as a Common Gateway Interface (CGI) script. CGI scripts can be written in Perl, C, Java, or other programming languages. There are several sites on the Web that offer free CGI scripts that you can use (see HTML and Web technologies resources). You can modify those scripts to fit your needs. You can also ask your Internet service provider or Web team if there are any available CGI scripts that are already configured to run on your server.
For an introduction to CGI scripting, see The Common Gateway Interface.
| <form method="post" action="mailto:mijn@adres.nl"> |
Dat is wat minder gebruiksvriendelijk, maar werkt wel. Ik zal zo even kijken of ik iets in php kan brouwen en hosten (simpel mailscriptje).
Privacy-adepten vinden op AVGtekst.nl de Nederlandse AVG-tekst voorzien van uitspraken en besluiten.
Membersysteem ( PHP + MySql )
Versie: Zie versie.txt
Auteur: Dennis van den Hout ( XdRaG00n )
Email: XdRaG00n@hotmail.com
Homepage: http://www.thesaiyanuniverse.nl
Dit script mag op geen enkele voorwaarde op een andere site te downloaden staan en
ook de source-code mag op geen andere website te zien zijn dan onze eigen website.
Het inlogsysteem gebruikt sessions voor het inloggen van een member, cookies waren
onveilig en daarom hebben we dus voor sessions gekozen. Als men het window sluit is
men uitgelogd. Als je vragen hebt over de werking van dit script moet je contact
opnemen met het bovenstaande email adres.
Gebruik:
Upload dit script naar je server, je hoeft geen chmod te doen omdat dit script een MySql
database gebruikt. Je moet vervolgens de query in data.sql uitvoeren in:
> MySqlFront ( http://www.anse.de/mysqlfront )
> PHPMyAdmin ( Zit standaard bij phpdev4/5 )
Dus heb ik phpMyAdmin-2.3.0 binnen gehaald om het file data.sql te kunnen bewerken .
Nou je raad het natuurlijk al om phpMyAdmin-2.3.0 aan de praat te krijgen moet ik :
Open the file config.inc.php3 in your favourite editor and change the values for host, user, password and authentication mode to fit your environment
En dat file krijg ik dus niet op een normale manier ge edit .
Het word denk ik maar eens tijd dat ik ga slapen ik ben het behoorlijk zat
Hee man hardstike bedankt ik ben hier ff een tijdje mee geredPrammenhanger schreef op 29 augustus 2002 @ 11:29:
Als je alleen een form wil versturen, zonder verdere acties eromheen, check dit
Het mailtje komt niet aan en de pagina waar ze heen moeten als het verzenden is gelukt werkt niet ik heb vast nog iets verkeerd gedaan ik hoop dat je mijn ff kan helpen ik plaats hier de code ff .Prammenhanger schreef op 29 augustus 2002 @ 11:29:
EDIT :
Hij werkt het is gelukt en ik ben je euwig dankbaar heheheheh
EDIT :
Nog 1 vraag waarom doe je dit voor ons ?
heidiulrich.nl | adventura.nl : rugzakavonturen | pathwise.nl : prepping geeks to get jobs
Bovendien verveelde ik me gister, dus heb ik even dit script in elkaar geflanst. Groovy baby!
