[PHP][MySQL] 2 tabellen gebruiken ?
  • C.44
  • Laatst online: 05-08-2020
C.44
TurboCharged Supra Driver
Nou ben nog maar net begonnen, met php, maar het schiet al een beetje op (ahum).
Nu heb ik het volgende stukkie code...
PHP:
29
30
31
32
33
34
35
36
37
38
39
<?php
include("db_connect.php");
$menu_options = mysql_query("select * from menu_options") or die (mysql_error());
$template_1 = mysql_query("select * from templates") or die (mysql_error());
$kolspan = mysql_num_fields($menu_options);
while ($row = mysql_fetch_array($template_1))
    echo "<table border=0 cellspacing=0>\n";
    echo "<tr>\n";
    echo "<td height='", $row["table_left_corner_height"], "' width='", $row["table_left_corner_width"], "' background='",$row["img_dir"],$row["temp_name"], "/",$row["table_left_corner_img"], "' style='background-repeat: no-repeat;'>\n";
    echo "<td width='", $row["table_menu_width"], "' height='", $row["table_menu_height"], "' background='",$row["img_dir"],$row["temp_name"], "/",$row["table_menu_header_img"], "' style='background-repeat: no-repeat;'>\n";
    echo "</tr>\n";
    echo "<tr>\n";
    echo "<td rowspan='", $kolspan, "' width='", $row["table_left_border_width"], "' background='",$row["img_dir"],$row["temp_name"], "/",$row["table_left_border_img"], "' style='background-repeat: repeat-y;'>\n";
        while ($row = mysql_fetch_array($menu_options))
                echo "<td height='", $row["table_left_corner_height"], "' width='", $row["table_left_corner_width"], "'>\n";
                echo $row["option_name"];
                echo "</tr>\n";
                echo "<tr>\n";
        mysql_free_result($menu_options);
    echo "<td bgcolor='#", $row["table_top_cell_remains_color"], "' background='",$row["img_dir"],$row["temp_name"], "/",$row["table_left_border_img"], "'>\n";
    echo "</td></tr></table>\n";
    echo "<table border=0 cellspacing=0 heigth=100%>\n";
    echo "<tr>\n";
    echo "<td rowspan='", $kolspan, "' width='", $row["table_left_border_width"], "' background='",$row["img_dir"],$row["temp_name"], "/",$row["table_left_border_img"], "' style='background-repeat: repeat-y;'>1234\n";
mysql_free_result($template_1);
Als je het een rommel vind, kan kloppen, m'n kamer ziet er net zo uit ;)
Nu geeft dat dus dit resultaat: http://213.51.1.161/site/
Mijn bedoeling was om, nadat je met de tweede tabel (menu_options) hebt gewerkt, weer met templates gaat werken... maar daar wil ie niet echt aan.
Kan iemand me daarbij helpen ?
Toyota Supra 3.0i Turbo Targa in Panther Black Mica - 300D || 30D || 10-20 || 50mm 1.8 mk1 || 18-55 || 17-85 || 75-300 || Giottos || Manfrotto || Cullmann || Kenko || Hoya
  • ACM
ACM
Software Architect
Werkt hier
"maar daar wil ie niet echt aan."
Moet je het anders doen ;)
Kortom: leg even wat meer uit, wat doet ie wel, wat doet ie niet wat jij wilt dat ie doet, welk stuk van de php-code gaat het dan fout, etc.
  • C.44
C.44
Hij haalt na
PHP:
geen informatie meer uit de tabel die templates heet.
Dit stuk php:
PHP:
    echo "<tr>\n";
laat alleen dit stuk html zien:
[html]
<tr>
<td rowspan='2' width='' background='/' style='background-repeat: repeat-y;'>1234
[/html]
En ik mis daar de values voor background en width...
  • ACM
ACM
Software Architect
Werkt hier
Je moet niet 2x dezelfde $row door elkaar gebruiken.
  • C.44
C.44
En hoe kan ik dit dan oplossen, ben nog nieuw en nat achter m'n oren wat dit betreft :)
  • ACM
ACM
Software Architect
Werkt hier
while($template_row = mysql_fetch_array($template_result))
in de ene gebruiken en in de andere while
while($menu_row = mysql_fetch_array($menu_result))
En dan hoe je het zelf wilt, lijkt me niet zo moeilijk om de variabelen andere namen te geven ;)
  • C.44
C.44
Damn, had ik nog niet es aan gedacht :D thanks
