Het Abit AT7-MAX2 Topic
  • silentsnow
  • Laatst online: 15-04-2013
silentsnow
« '-_-' »
Wederom een socket A bord van Abit. Deze keer is het de opvolger van de AT7-MAX. Dit bord lijkt wel verdacht veel op de nForce2, met als enige verschil onboard video.
Hier zijn de specs van de AT7-MAX2:
Afbeeldingslocatie: http://www.hwsw.hu/kepek/hirek/2002/08/at7-max2.jpg
Afbeeldingslocatie: http://www.abit-usa.com/images/serillel_logo.jpg
CPU
. Supports AMD-K7 Athlon / Athlon XP Socket A 200/266MHz FSB Processors
. Supports AMD-K7 Duron Socket A 200 MHz FSB Processors
Chipset
. VIA KT400 / VT8235
. Supports Hi-Speed UniversaSeriaBus (USB 2.0)
. Supports Advanced Configuration and Power Management Interface (ACPI)
. Accelerated Graphics Port connector supports AGP 4X/8X (1.5V/0.8V)
Memory
. Four 184-pin DIMM sockets
. Supports 2 DIMM DDR 333/400 (Max. 2GB)
. Supports 3 DIMM Un-buffered DDR 200/266 (Max. 3GB)
. Supports 4 DIMM Registered DDR 200/266 (Max. 3.5GB)
Serial ATA
. On board Marvel88i8030 Controller x 2
. Support SATA data transfer rates 150 MB/s (1.5G bps)
RAID
. High Point HPT374 IDE RAID Controller? supports Ultra DMA 33/66/100/133
. RAID 0/1/0+1(striping + mirroring mode for boosting performance and data security)
Audio
. 6-ChanneAC 97 CODEC on board
. Professional digital audio interface supports 24-bit S/PDIF Out
Media XP (Optional)
. Supports card reader function for Memory Stick, Secure Digital; and Type I/II CompactFlash;
. Supports Wireless Remote Controand S/PDIF Out / Mic In / Headphone Out / USB 2.0 / IEEE 1394
System BIOS
. SoftMenu™ III Technology to set CPU parameters
. Supports Plug-and-Play (PNP)
. Supports Advanced Configuration Power Interface (ACPI)
. Supports Desktop Management Interface (DMI)
. Write-Protect Anti-Virus function by AWARD BIOS
LAN
. On board Realtek 8100B 10/100M PCI Fast Ethernet controller
IEEE 1394
. Supports IEEE 1394a at 100/200/400 Mb/s transfer rate
Internal I/O Connectors
. 1 x AGP, 5 x PCI slots
. Floppy Port supports up to 2.88MB
. 4 x Ultra DMA 33/66/100/133 Connectors
. 2 x SerialATA 150 Connectors
. 2 x USB headers, 1 x IEEE 1394a header
. 1 x CD-IN, 1 x AUX-IN
Back Panel I/O
. 1 x PS/2 Keyboard, 1 x PS/2 mouse
. 4 x USB connectors
. 2 x IEEE 1394 connectors
. 1 x SPDIF Out connector
. Audio connectors (Front Speaker, Line-in, Mic-in, Center/Sub, Surround Speaker)
. 2 x USB, 1 x RJ-45 LAN Connector
Miscellaneous
. ATX form factor
. Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
Abit AT7-MAX2 T.net AT7-MAX2
The trade of the tools
[ me | specs ] Klipsch Promedia Ultra 5.1 + Sennheiser HD-590
  • sdomburg
  • Laatst online: 03-09-2024
lekker bordje! :9 mooie fan ook :)
  • silentsnow
silentsnow
« '-_-' »
Een review van Tbreak: AT7-MAX2
Hij krijgt 89 punten :P
Even ter vergelijking:
MSI KT4 Ultra :78 punten
Gigabyte 7VAXP :74 punten
ABIT AT7-MAX2 :89 punten
  • SlowikPL
  • Laatst online: 17-03 11:01
aanstande week heb ik heb sammen met raedon 9700Pro :)
heeft iemand all deze bord :?
* Intel Core i7-6700K @ 4.8Ghz * Asus MAXIMUS VIII EXTREME* nVidia Asus Poseidon 1080Ti * Mushkin 16 GB * SSD Samsung M.2 2280 256GB + 3x Samsung 256GB 850Pro* Enermax Revolution85+ 1250W * CM Stacker 832 SE * Waretcooling CPU, NB ,VGA 3x Mora
silentsnow schreef op 15 september 2002 @ 20:54:
Ja en de Epox met KT400 chipset scoort 92 punten
  • SlowikPL
waar heb je dat gelezen????? :? de Epox is noch niet uit, pas begin volgend maand!
  • silentsnow
silentsnow
« '-_-' »
Verwijderd schreef op 16 september 2002 @ 13:16:
Mhhz, ik zie die EPoX niet staan. Kan je ff een linkje geven :?
  • kieskes
  • Laatst online: 09:25
Ik vind het bordje nog wel vrij duur zeg.
Zou hij nog veel gaan zakken in prijs als hij wat beter verkrijgbaar is (meer winkels) ?
  • SlowikPL
Waar is ie al op voorraad ??????? Weet dai iemand aub. zeggen.
  • Chadi
  • Laatst online: 06-11-2025
Ow ik krijg hem vrijdag... dus nog 2 daagjes wachten.. heb gelijk MEdia XP erbij besteld.samen 240 euro. Wel relaxed :) Zaterdag of vrijdag avond heb ik hem getest.
  • silentsnow
silentsnow
« '-_-' »
kieskes schreef op 16 september 2002 @ 21:02:
Het is ook een soort all-in-one. Dus het is niet een concurrent voor de meeste moederborden. Het is meer een concurrent voor de nForce moederborden.
  • silentsnow
silentsnow
« '-_-' »
SlowikPL schreef op 19 september 2002 @ 23:59:
Nu ik heb een ABIT AY7-MAX2 moederbord en Club3D Raedon 700Pro.
Mijn vraag is waar kan ik zie dan nu mijn Raedon loopt op AGP 8X
Hier een aantal screenschot`s van SISoft Sandra Proffesional ,maar loopt de kaart wel in AGP 8X of 2X ????
http://www.theforumisdown.com/uploadfiles/0802/AGP 2X.JPG
http://www.theforumisdown.com/uploadfiles/0802/AGP 2X ..JPG
http://www.theforumisdown.com/uploadfiles/0802/AGP2x.JPG In 3Dmark 2001SE zegt ie ook dat ik nu AGP 2X aan heb. Ik kan nergens op deze moderbord AGP 8X inshakelen ,het zou moeten automatisch volgens de boekje gaan :?
ik vertrouw Sandra niet ,kunt iemand mijn een programa zeggen waar het duidelijk staat dat mijn AGP loopt op 8X ?
Wat moet ik doen mensen ?
Klopt, als je een videokaart gebruikt die aan de AGP3.0 specificaties voldoet (AGP8x), dan verdwijnd de optie waarin je kan selecteren welke AGP rate je wilt hebben.
Probeer de nieuwe via4in1 drivers de gebruiken. De nieuwe hebben AGP8x support. Misschien helpt dat :) http://www.viaarena.com/?PageID=2
  • SlowikPL
Ik heb de VIA_4in1_443v dirrect na de instal geinstaleerd en niks.Het blijft op 2X steken.Ligt dat niet aan de kaart?
SP1 heb ik ook geinstaleerd.
  • Nefiorim
  • Laatst online: 11-03 07:21
Zoals al te lezen was op de frontpage (een paar dagen terug) hebben sommige Radeon 9700's problemen met AGP 8x
nieuws: ATi bekent AGP8x problemen Radeon 9700 Pro
[ Voor 0% gewijzigd door Nefiorim op 20-09-2002 00:53 . Reden: URL toegevoegd ]
XBO: Michaël#3318
  • SlowikPL
Deus het ligt niet aan mijn moderbord :?
  • Nefiorim
Ja ze zijn er nog nie over uit of t aan de moederborden of aan de videokaarten ligt :)
't Is wellicht de moeite waard om hierover een nieuw topic te openen.. (Hint, hint)
XBO: Michaël#3318
  • silentsnow
silentsnow
« '-_-' »
SlowikPL schreef op 20 september 2002 @ 00:53:
Nope, je Radeon heeft je flink te pakken genomen. Ach, wees gerust. Over een paar maanden komen de geviseerde Radeon eraan, dan kan je vast wel je huidige ruilen :)
  • silentsnow
silentsnow
« '-_-' »
Nefiorim schreef op 20 september 2002 @ 00:56:
Radeon 9700 pro problem met AGP 8x? (Hint, hint)
  • SlowikPL
Ik heb al de ABIT AT7-MAX2 en moet wel zeggen dat de kwaliteit van de bord is niet te overtreffen.En die had ik:
ASUS P3B-F (het beste ooit, gebruik tot nu toe)
Soltek SL75-DRV2 (Miskoop!!!!)
Gigabyte GA-7VRXP (Goede boord ,klote inkomstabiliteit met GF4 !)
MSI KT3 Ultra2-R (goed ,meer te gevoelig voor overklokkenen en niet fijn)
ABIT AT7-MAX2 (zeer goed tot nu toe ,misschien wordt dat de beste)
Wat ik waardeer aan mijn ABIT AT7-MAX2 dat er erg simpel in de instellingen en zeer stabiel in overklokken!Ik kan wel overklokken an AMD XP1700 11x133 (1463!!) @ 12x142 (1704Mhz) !!! (waterkoeling) Met MSI bij hetzelfde hardware was dat “maar” (1610Mhz 11.5X140!Loop de sys. Toch vast dan hoef je bijna nooit clear CMOS doen want een reset of Power On bediening is genoeg.
De Layout van de bord is goed maar bijn mijn kast zijn de aansluit kabels van de case Chiftec iets te kort maar dat geef niet.
Wat ik wel probleem mee had dat er niet mogelijk was om met mijn Club3D Raedon 9700 Pro op AGP 8X laten lopen :) Maar het kan volgens ABIT zelf aan de kaart liggen :(
Nooit een vastlopers met Counet-Strike,UT2003,Quake 3,Battelfield 1942,Mafia 2,Soldier of Fortune II - Double Helix,Empire Earth !!!!!
(de kaart is inmiddels weg) en krijg zo een Gigabyte Maya II Raedon 9700Pro. :)
Ben noch niet achter hoe ik mijn enkel HD kan bedienen op de S-ATA :? Of het kan alleen 2 schijven omdat de S-ATA in aangesloten op mijn HTP374 RAID controler die een enkele schijf via S-ATA niet ziet :?
Binnenkort meld ik mijn MadOnion 3D Mark SE scores overklokked met de waterkoeling (processor en VGA kaart) :)
  • Chadi
verdomme ik kreeg de verkeerde thuis gestuurd... wacht tot morgen en dan hoor ik of ze de Juiste gaan leveren. :(
  • SlowikPL
weet iemand hoe je de S-ATA kan gebruiken :?
Ik heb zo een adapter van ABIT en wil mijn 15GB HD eensluiten en niks :? de moderbord ziet hem niet eens :?
Ook de RAID ingeschakeld maar er doet niks :?
Ik heb een Abit AT7-max2 met een unlocked Athlon XP 2000+, dmv. L1-bridges te verfen ( je weet wel).
Ik kan netjes 166Mhz FSB draaien met divider op 4:2:1 (Fsb:Agp:Pci). Als ik de divider op 5:2:1 ook op 166Mhz FSB zet, dus geen verdere aanpassingen boot het systeem nog geeneens. gebruik bios versie B7. Er is dus ondertussen niets met de Memory-settings gebeurd.
de 6:2:1 divider is er uit de B7 Bios gehaald ,omdat deze toch niet is geiplementeerd door VIA!
Zou het kunnen zijn dat je bij de Athlon XP nog andere bridges moet unlocken behalve dus de L1's om naar 5:2:1-divider te kunnen gaan ( lijkt me sterk)
Systeem loopt nu dus op:
166.88Mhzx11= 1836Mhz
Agp trekt deze snelheid niet-> 88Mhz, daarom wil ik naar 5:2:1 gaan!
Iemand suggesties?
  • kieskes
Ik heb het bordje hier inmiddels ook al een tijdje draaien, en het draait geweldig :)
wat betreft overklokken weet ik niet, heb ik nog niet geprobeert ;)
het enige wat me iets tegenvalt zijn de scores van de memory benchmarcs, maar goed, pc400 zal nog wel niet goed 'ondersteund' worden
Verwijderd schreef op 31 oktober 2002 @ 12:52:
Iemand suggesties?
Er zijn er meer met dat probleem. De KD7 heeft het ook (is hetzelfde bord alleen met minder features). Wat het is...geen id :| :?
Heb de oplossing voor het divider probleem, zet je CPU command-code op "Normal" en dus niet op "fast". Ik heb systeem nu op 190Mhz fsb lopen.
  • hoevenpe
Werkt helaas niet :(
Heb een XP2400+
Loopt lekker:
FSB 133
Multiplier 15
Voltage normal
4:2:1
CPU command code normal
Boot niet eens, scherm blijft zwart:
FSB 133
Multiplier 15
Voltage normal
5:2:1
  • SlowikPL
Er is een nieuwe bios van de AT7-MAX2 ftp://202.168.194.114/pub/download/fae/at72b7.exe
Heeft iemand dat ale in gebruik?
  • Tomcat84
  • Laatst online: 23-02-2025
Misschien kan dit een Abit AT-7MAX2 en Abit KD-7 topic worden, aangezien het allebei KT-400 borden zijn van Abit, alleen de KD-7 i de wat "simpelere" uitvoering?
En die Radeon die als AGP-2x wordt gezien is geloof ik gewoon software foutje, hij draait in werkelijkheid dan wel op AGP 8X (schijnt)
  • K-2SO
  • Laatst online: 12-12-2025
*SCHOP*
Ik heb dit bordje nu thuis liggen en zal het dit weekend inbouwen, zijn er nog mensen die wat ervaringen/tips met me willen delen ?
Het is nu al zo lang stil rondom dit plankje. :)
