PLEXTOR CD-R PX-W4012A brand niet op 40x en sluit niet af
  • l3p
  • Laatst online: 11:52
l3p
www.^.nl
zoals de titel al zegt : PLEXTOR CD-R PX-W4012A brand niet op 40x en sluit niet af, ook niet op 16x dan sluit ie de cd ook niet nomaal af, heb win xp al 3x gereinstalled, firmware updates, software updates etc etc
logfile van nero hieronder
plzz help me out _/-\o_
Windows XP 5.1
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.45, size=172099 bytes, created 16-8-2002 18:05:56
Nero Version: 5.5.7.8
Recorder: <PLEXTOR CD-R PX-W4012A> Version: 1.02 - HA 0 TA 0 - 5.5.7.8
Adapter driver: <atapi> HA 0
Drive buffer : 4096kB
Bus Type : default (0) -> ATAPI
CD-ROM: <HL-DT-ST DVD-ROM GDR8160B>Version: 0009 - HA 0 TA 1 - 5.5.7.8
=== Scsi-Device-Map ===
CdRomPeripheral : PLEXTOR CD-R PX-W4012A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8160B atapi Port 0 ID 1 DMA: On
DiskPeripheral : Promise 2+0 Stripe/RAID01.10 Fasttrak Port 1 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 262MB (268796kB)
Memory in use : 48 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: On
bla bla
20:57:08 #33 SCSI -1023 File Cdrdrv.cpp, Line 1211
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x01FE3780
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x5A 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x58 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x2C 0x00
20:57:08 #34 CDR -1114 File ThreadedTransferInterface.cpp, Line 1448
Reset occurred
20:57:08 #35 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1448
Could not perform end of Disc At Once
20:57:16 #36 CDR -201 File WriterStatus.cpp, Line 155
Invalid writestate
20:57:16 #37 TRANSFER -24 File WriterStatus.cpp, Line 155
20:57:17 #38 Phase 38 File dlgbrnst.cpp, Line 1438
Burn process failed at 16x (2.400 KB/s)
20:57:17 #39 Text 0 File Scsicmd.cpp, Line 368
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
L3p - MK - PV - WP
al eens ander merk CDR geprobeerd :?
offtopic
bedankt nog voor dat serial nummer scheeld mij weer zoeken
/offtopic
idd serial weg :) k heb um al maar ok
  • robbert
  • Laatst online: 08:22
als die niet op 40x brand dan moet je een ander merk cd's nemen, komt door powerRec. die kijkt op welke snelheid die een cd kan branden. Heeft je pc er erg veel moeite mee waardoor die niet op 40x komt moet je DMA aanzetten
Dat afsluiten weet ik niet
  • The Dolf
Geen id maar om je toch te helpen. Haal asap die serial weg.
Gezocht!
Samsung 1TB HD103SI printplaat
Router
If everything seems to be going well, you have obviously overlooked something
  • l3p
l3p
www.^.nl
ehm is hij nu weg ?
L3p - MK - PV - WP
  • l3p
l3p
www.^.nl
robbertkrebbers schreef op 23 augustus 2002 @ 22:58:
hij staat al op dma, en ik heb 3 soorten cdees, en heb het bij allemaal
L3p - MK - PV - WP
  • l3p
l3p
www.^.nl
niemand die iets uit log kan opmaken ?
L3p - MK - PV - WP
