[Webalizer] Make wil niet, 'undefined reference' (gd2?)
  • razor-x
  • Laatst online: 05-06 07:37
Hoihoi,
Dit keer ben ik bezig om webalizer te proberen te installeeren,
maar dat werkt ( ookal ) niet.
de errors:
root@host:/emiel/webalizer-2.01-10# make install
gcc -L/usr/lib -o webalizer webalizer.o hashtab.o linklist.o preserve.o parser.o output.o dns_resolv.o graphs.o -lgd -lpng -lz -lm
/usr/lib/libgd.so: undefined reference to `FT_Init_FreeType'
/usr/lib/libgd.so: undefined reference to `jpeg_read_scanlines'
/usr/lib/libgd.so: undefined reference to `jpeg_simple_progression'
/usr/lib/libgd.so: undefined reference to `FT_Load_Glyph'
/usr/lib/libgd.so: undefined reference to `FT_Done_Face'
/usr/lib/libgd.so: undefined reference to `FT_Get_Kerning'
/usr/lib/libgd.so: undefined reference to `FT_Get_Char_Index'
/usr/lib/libgd.so: undefined reference to `jpeg_set_defaults'
/usr/lib/libgd.so: undefined reference to `FT_Get_Glyph'
/usr/lib/libgd.so: undefined reference to `jpeg_start_decompress'
/usr/lib/libgd.so: undefined reference to `jpeg_destroy'
/usr/lib/libgd.so: undefined reference to `jpeg_write_marker'
/usr/lib/libgd.so: undefined reference to `FT_Glyph_To_Bitmap'
/usr/lib/libgd.so: undefined reference to `jpeg_destroy_decompress'
/usr/lib/libgd.so: undefined reference to `jpeg_std_error'
/usr/lib/libgd.so: undefined reference to `jpeg_CreateDecompress'
/usr/lib/libgd.so: undefined reference to `FT_Set_Char_Size'
/usr/lib/libgd.so: undefined reference to `jpeg_read_header'
/usr/lib/libgd.so: undefined reference to `jpeg_start_compress'
/usr/lib/libgd.so: undefined reference to `jpeg_destroy_compress'
/usr/lib/libgd.so: undefined reference to `jpeg_finish_decompress'
/usr/lib/libgd.so: undefined reference to `jpeg_resync_to_restart'
/usr/lib/libgd.so: undefined reference to `jpeg_CreateCompress'
/usr/lib/libgd.so: undefined reference to `FT_Done_Glyph'
/usr/lib/libgd.so: undefined reference to `FT_Glyph_Get_CBox'
/usr/lib/libgd.so: undefined reference to `jpeg_finish_compress'
/usr/lib/libgd.so: undefined reference to `FT_New_Face'
/usr/lib/libgd.so: undefined reference to `jpeg_set_quality'
/usr/lib/libgd.so: undefined reference to `FT_Glyph_Transform'
/usr/lib/libgd.so: undefined reference to `jpeg_write_scanlines'
collect2: ld returned 1 exit status
make: *** [webalizer] Error 1
Nou je ziet veel errors met 'jpeg' erin, maar libjpg is goed geinstalleerd!
Ik gebruik slackware8.1, en ik heb GD2 , nou is me vaagjes vertelt dat webalizer niet werkt met GD2 ;( , maar ik heb gd2 'nodig' voor m'n php , is er een manier om het wel te laten werken?
bvd :)
  • _Squatt_
libjpeg is misschien wel geinstalleerd, maar die wordt niet mee gelinkt. De 'FT_*' dingen zijn volgens mij van Freetype, en ook die wordt niet meegelinkt.
In het rijtje: '-lgd -lpng -lz -lm' hoort ook nog '-ljpeg -lfreetype'. Misschien dat je dat er in de Makefile bij kunt zetten, of in de environment variabele LD_FLAGS (dacht ik).
Misschien dat je met het configure script ook het een en ander op kan geven. Geeft configure trouwens errors, zoals 'checking for libjpeg...not found'?
"He took a duck in the face at two hundred and fifty knots."
maak het jezelf makkelijk, download de binary. ik heb ook uren lang getracht webalizer te maken maar dan met dns support, ging voor geen meter.
  • razor-x
_Squatt_ schreef op 23 augustus 2002 @ 17:12:
Dankje!, dit was de oplossing :)
