Ik snap er niets meer van‚ heb alles geprobeerd.
Van sendmail.cf editen tot dns en hosts enzovoorts gecontroleerd en de logs allemaal doorgekeken‚ maar met openbsd 3.1 met sendmail en apache gaat erg langzaam. Ik snap niet wat ik fout doe‚ please tips?
Extra erbij
Maillog:
Aug 23 14:48:31 coolzero sm-mta[30478]: starting daemon (8.12.2): SMTP+queueing@00:30:00
Aug 23 14:49:50 coolzero sendmail[15798]: g7NCnoaV015798: from=www‚ size=837‚ class=0‚ nrcpts=1‚ m
sgid=<200208231249.g7NCnoaV015798@coolzero.info>‚ relay=www@localhost
Aug 23 14:51:06 coolzero sm-mta[10363]: g7NCp5Q9010363: from=<www@coolzero.info>‚ size=1069‚ class
=0‚ nrcpts=1‚ msgid=<200208231249.g7NCnoaV015798@coolzero.info>‚ proto=ESMTP‚ daemon=MTA‚ relay=ww
w@localhost [127.0.0.1]
Aug 23 14:51:06 coolzero sendmail[15798]: g7NCnoaV015798: to=j.vanwel@multiweb.nl‚ ctladdr=www (67
/67)‚ delay=00:01:16‚ xdelay=00:01:16‚ mailer=relay‚ pri=30144‚ relay=localhost [127.0.0.1]‚ dsn=2
.0.0‚ stat=Sent (g7NCp5Q9010363 Message accepted for delivery)
Aug 23 14:51:06 coolzero sendmail[1681]: g7NCp6OC001681: from=www‚ size=815‚ class=0‚ nrcpts=1‚ ms
gid=<200208231251.g7NCp6OC001681@coolzero.info>‚ relay=www@localhost
Aug 23 14:51:06 coolzero sm-mta[27621]: g7NCp5Q9010363: to=<j.vanwel@multiweb.nl>‚ ctladdr=<www@co
olzero.info> (67/67)‚ delay=00:00:01‚ xdelay=00:00:00‚ mailer=esmtp‚ pri=30376‚ relay=mx01.quickne
t.nl. [213.73.255.40]‚ dsn=2.0.0‚ stat=Sent (Ok.)
Aug 23 14:52:22 coolzero sm-mta[1843]: g7NCqLQ9001843: from=<www@coolzero.info>‚ size=1047‚ class=
0‚ nrcpts=1‚ msgid=<200208231251.g7NCp6OC001681@coolzero.info>‚ proto=ESMTP‚ daemon=MTA‚ relay=www
Aug 23 14:52:22 coolzero sendmail[1681]: g7NCp6OC001681: to=coolzero@hackerz.nl‚ ctladdr=www (67/6
7)‚ delay=00:01:16‚ xdelay=00:01:16‚ mailer=relay‚ pri=30145‚ relay=localhost [127.0.0.1]‚ dsn=2.0
.0‚ stat=Sent (g7NCqLQ9001843 Message accepted for delivery)
Aug 23 14:52:22 coolzero sm-mta[25111]: g7NCqLQ9001843: to=<coolzero@hackerz.nl>‚ ctladdr=<www@coo
lzero.info> (67/67)‚ delay=00:00:01‚ xdelay=00:00:00‚ mailer=esmtp‚ pri=30377‚ relay=in2.mail.vuur
werk.net. [62.250.3.111]‚ dsn=2.0.0‚ stat=Sent (ok 1030106993 qp 44325)
Nog wat
Hij blijft dus meestal lang hangen op relay=www@localhost
Hoe verander ik dat zodat het wel rap gaat?
Extra erbij
Maillog:
Nog wat
