Was dr aan de hand met cs ...?
  • 153 views sinds 30-01-2008
  • Kortfragje
  • Laatst online: 28-10 21:05
Alle NL servers zijn d00d.....
Dr stond iets over updaten security module , maar wtf , hoelang duurt dat ? :(
http://www.gjpvanwesten.nl
Ik heb nergens last van hoor...
hmmm... ik ben net gestopt toen er een map change was, misschien dat de server er wel helemaal uitging ofzo? (Gamepoint)
  • Kortfragje
jah t gebeurt steed tijdens map change , maar kijk maar es in je gamespy / eye .. NIEMAND op wanadoo , NIEMAND op demon :?
  • HenkJan
  • Laatst online: 16-12-2025
Er was vanavond geloof ik een VAC (valve-anti-cheat) update, dus waarschijnlijk daarom down. De servers moeten dan eerst gerestart worden voor ze 't weer doen.
  • Kortfragje
ow owk, vandaar :D d8 al zoiets ( server is downloading security update) maar ik d8 dat je daarna verder kon spelen.. :(
  • YakuzA
YakuzA
Wat denk je nou zelluf hey :X
We've updated the public security modules again. If you've been helping us test the beta security modules, you should remove the password from your command line and restart your server. The beta security modules are no longer being tested.
These security modules should detect most versions of OGC and report detected cheaters to our ban list server.
We're no longer using port 27013 for the ban list. You will now see traffic (in/out) on port 27011. This traffic is to/from the ban list server. Make sure you have this port open in your firewall.
Your Counter-Strike and Day of Defeat servers should update themselves automatically. If you find your servers are suddenly having problems, try restarting them.
We've been investigating the problems some servers have been having after we update the security modules (clients not being able to connect, etc.). We're still working on the problems. If your server has a problem updating to the latest security modules, please send me any details you have (including which OS you're running and your log files during the update) that will help us track down the problem. You can send this information directly to me (mailto:erics@valvesoftware.com).
We hope to resolve the server problems soon. We appreciate your patience.
If you've been testing cheats on your server in the past you should stop. All information regarding detected cheaters will be going into the ban list database. If you suspect that a cheat still works, send the information to us and we'll look into it.
en dat vooral dit laaste stukkie is wel intressant, zijn wel zooi mensen die dit gebruiken volgens mij:
Also, CD key changers are considered cheats and will be reported to the ban list.
PSN
hey er zijn nog mensen die CS spelen..
ik dacht dat iedereen (inluding /me) er wel op uitgekeken was/is!
  • DasHMauL
  • Laatst online: 01-10 11:32
Verwijderd schreef op 22 augustus 2002 @ 11:23:
cs nog altijd nr.1 !
ja, maar als ze nou eens een soort van tracker hadden waar ze precies mee kon zien hoeveel mensen er spelen per maand ofzo, dan zou je wel een forse daling zien denk ik..
  • GTA3
Yja, ik denk dat iedereen hoopvol zit te wachten op condition zero zoals ik :P
  • Novah
  • Laatst online: 26-09 12:29
Zo kijk jij ff op hoeveel miljoenen mensen het spelen, het is nog altijd het meest gespeelde online fps op de wereld. :)
_/-\o_ Hozanna aan CS! _/-\o_
LoL wat een domme opmerking ;)
Maar bij mij doen alle NL servers het gewoon goed
Verwijderd schreef op 22 augustus 2002 @ 11:31:
misschien als je t maar vaak genoeg zegt ga je t zelf geloven ;)
