LG 995E 19" : is deze wel vlak ???
Mijn vraag is is deze ook echt vlak of kan ik beter een andere nemen, ik moet toevallig een nieuwe hebben en een 21 inch vind ik nouw net iets te !
( budget van 1000 piek ! )
DIt zijn de specificaties
995E 19" (18" VIS) Color Monitor
FEATURES:
- Auto-synchronous support from
640 x 480 up to 1600 x 1200 @ 75 Hz NI
- Flicker-free up to 1600 x 1200 @ 75 Hz NI
- On-screen digital microprocessor controls
- VESA DDC1 and DDC2B Plug and Play
compatible.
- PC, Mac and SPARC compatible
- EPA Energy Star and VESA DPMS compliant
- TCO '99 and MPR-II low-emission compliant
- Universal 90-264 VAC power
With its large 19" screen and compact cabinet, the Studioworks 995E gives you more room to work in, yet takes up less space on your desk. Now you can spread out your spreadsheets, or open multiple windows without the need to scroll around. What's more, the 995E has flicker-free resolution up to a super-sharp 1600 x 1200, special screen coatings, on-screen digital microprocessor controls, and TCO'99 compliance. The Studioworks 995E color monitor from LG.Enjoy the view.
CDT Size/Type 19" FST (18" VIS) Hitachi CPT, Invar mask, dark body tube, dark glass faceplate
Display Size 13.8" x 10.3" normal (365.8 mm x 274.3 mm)
14.4" x 10.8" full-screen (366 mm x 274 mm)
Display Colors Unlimited colors
CDT Transmission 44%
CDT Dot Pitch 0.26 mm diagonal (0.22 mm Horizontal)
CDT Coating ARASC (anti-static coating and anti-reflective)
Phosphor P22, medium short persistence
Maximum Resolution 1600 x 1200 @ 75 Hz NI
Maximum Flicker-Free Resolutions 1280 x 1024 @ 90 Hz NI
1152 x 864 @ 110 Hz NI
1024 x 768 @ 120 Hz NI
800 x 600 @ 150 Hz NI
832 x 624 @ 150 Hz NI
640 x 480 @ 190 Hz NI
Apple Compatibility 1280 x 1024 up to 90 Hz
1152 x 870 up to 110 Hz
832 x 624 up to 150 Hz NI
640 x 480 up to 190 Hz NI
Display Capability Auto-sync within scanning frequencies
Horizontal Scanning Frequencies 30-96 KHz
Vertical Scanning Frequencies 50-160 Hz
Pixel Frequency 203 MHz
Input Signal RGB analog, 0.7 p-p/75 ohms
Sync Signaling Separate H/V, H/V composite, Sync on Green
Input Connector 15-pin D-sub
Cable Connector 72" detachable
Monitor Control Type Digital microprocessor controls with on-screen display
Memory Modes 5 factory preset, 25 user-settable
VESA Plug and Play Level DDC1, DDC2B
Digital On-Screen Controls H/V position, H/V size, tilt, zoom, recall, side pincushion, trapezoid, pincushion balance, parallelogram, pin S adjust, pin W adjust, H/V moire, H/V convergence, degaussing, color control (9300K, 6500K, user RGB), clamp, OSD position, OSD time, 7 language OSD select (English, French, German, Spanish, Italian, Finnish, Swedish, Portuguese), information, video level , DDC, (on/off)
Front Panel Controls Power, brightness, contrast, OSD/adjust, select (l/r), exit
Power Requirements 90~264 VAC, 47~63 Hz
DPMS Power Consumption Maximum: 140 Watts Stand-by: 8 Watts Off: 3 Watts
Tilt/Swivel Base Detachable, Tilt: forward 5 °/back 15 °; Swivel: left 45 °/right 45 °
Dimensions with Base (WxDxH) 17.6" x 18.7" x 18.3" (448mm x 476mm x 465mm)
Weight 47.4 lbs.
Packed: 58.4 lbs
40 FT. CONTAINER QTY 320 Sets individual
Mean Time Between Failure 50,000 hours
Safety/Regulatory TCO '95, TCO '99, MPR II, UL, CSA, TUV-GS, SEMKO, NEMKO, DENKO, FIMKO, DHHS, HWC, ROV, FCC-B, CE, ISO 9241-3,ISO 9241-8, NUTEK, EPA Energy star , VCCI-2, GOSY CCIB, C-TICK
LGEUS Warranty 3 years limited on parts, labor, CDT
UPC# 719192164055
Ik weet totaal niet hoe je een plaatje invoegd maar dit is de link van de site zelf dan kan je hem ook zien :
http://www.lgeus.com
PS : Zoals jullie kunnen zien heb ik niet veel verstand van monitoren maar in ieder geval bedankt !!!!
Nope, die is niet vlak zoals een Trinitron, Diamondtron of Flatron
Het is inderdaad een normaal CRT scherm en geen flattron, trinitron of whatever. Wel een lekker scherm overigens voor zijn geld, Ik gebruik hem al bijna 10 maanden...
Ik kijk er nu ook naar.
Het is een heel mooi scherm, maar hij is niet vlak, maarja dan heb je die lelijke damper wires ook niet :)
wat zijn Damper-wires ??
Zo zie je maar geen snars verstand van monitoren !
  • FrankGuthrie
  • Laatst online: 27-08 21:36
FrankGuthrie
I Wanna Be Kate
<BLOCKQUOTE><font size=1 face=Verdana, Arial, Helvetica>quote:</font><HR>Op 20 oktober 2000 20:09 schreef stanley het volgende:
Zo zie je maar geen snars verstand van monitoren ![/quote]dat zijn van die draden die het scherm stabiel houden. Deze zijn alleen te vinden in schermen met platte beeldbuizen(dus diamondtron, of trinitron).
Russian Blue Neji
Kate Bush
Blue Horizon(a website about Star Trek & Babylon 5)
merk je dat ( zie je dat ) if niet ?
  • FiRePaTH
  • Laatst online: 24-07 01:36
FiRePaTH
Xbox One - TheXS NL
De Flattron-line van LG heeft geen damp-draden :)
Intel Core i7 SandyBridge 2600k - Asrock z68 Extreme 4 - 8GB G.Skill Ripjaws XF3 2133Mhz Cas9 - EVGA GTX750Ti FTW ACX - Eizo FORIS 23" 1080p IPS FS2332 6TByte Raid-0 Array - 1Gigabit Broadcom Netlink - Creative X-Fi Titanium - DTS ||| Xbox One - TheXS NL
Maar nu zit ik zelf te twijfelen of ik flattron zal nemen maar dat betekend in plaats van 900 gulden 1200 gulden uitgeven en dat is best veel geld vind ik.
Maar heeft het wel zin ?
Ik kijk nu ook tegen een gewoon beeldscherm aan.
  • Dr_Frickin_Evil
  • Laatst online: 30-08 09:31
Die draadjes zie je echt nauwelijks hoor! Om die reden zou ik de iiyama niet links laten staan.
