Vapor cooling
  • fleppuhstein
  • Laatst online: 21-10-2025
Na een beetje te surfen op de amerikaanse case mods site's kwam ik dele lieve schatjes tegen : http://www.iceepc.com/c30.htm
Afbeeldingslocatie: http://www.iceepc.com/tech-1-big.jpg
Afbeeldingslocatie: http://www.iceepc.com/kit-big.jpg
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
Features of the ATX
midi tower PC-case:
  Built in cooling unit
Snap-on front bezel for quick installation
Interchangeable M/B stakes for fast installation of various motherboard sizesSlide guides for quick FDD/HDD installation
More drive bay options than others on the market (4 X 5,25 + 3 X 3,5)
Easy access for faster service and maintenance
Unique cover and chassis construction for easy and accurate assembly
Meets CE and UL requirements
Cooling performance:
  The Prometeia is optimized for maintaining below -40C/-40F in the range up to 80W, but capable of maintaining an impressive -28C at a CPU load of 150W at 20C ambient temperature, thus having a comfortable margin for future processors.
From a Prometeia system mounted with Intel Pentium 4 2.2 GHz (Northwood) @1.8V @ +3 Ghz running CPU Stability Test 6.0. maximizing the CPU heat production, average display temperature of the evaporator shows -35C / -31F
Power consumption:
  The Compressor consumes 130 watt when the CPU is running standard windows. Power Consumption rises with the CPU load up to app. 170W at full CPU workload and 200W at a fictive 150W CPU workload.
Noise level:
  App. 35 db(A)at normal operation, 40dbA during start-up
Approvals:
  Certified with Iso 9001 and Environment 14001. (Elcold)
Meets CE requirements and specifications, UL approval pending
Refrigerant:
  Environmental friendly R134A
Overall Dimensions:
(W x H x D)
  190 x 675 x 480mm (7.5" x 26.5" x 18.9") incl. PC Case
190 x 240 x 480mm (7.5" x 9.45" x 18.9") Cooling unit only
Weight:
  27 kg excl. PC-power Supply
  • PoweRoy
  • Laatst online: 16:54
PoweRoy
funky!
oud of nie
[This space is for rent]
  • sarlo
  • Laatst online: 28-08 10:50
ooit gehoord van prometia koeling ;)
  • DjGeRo
  • Laatst online: 07-09 09:51
Er is zelfs al een MOD van hiero :)
Ow, btw kan die code met wat meer spaties ??
  • Aphelion
  • Laatst online: 19-07 19:19
haha oud jongens, sorry :( .. ap versteeg heeft hem gemod, en ccmod is hem aan het reviewen.
Feeling lonely and content at the same time, I believe, is a rare kind of happiness
