[TV-Card]E-tech
m'n tv kaart van e-tech (e-tech.nu) krijg ik niet aan het werk onder linux
ik heb de bttv driver geladen en volgens mij werkt die ook wel:
tail -n 30 /var/log/messages zij:
Aug 20 17:28:35 celeron kernel: bttv: using 2 buffers with 2080k (4160k total) for capture
Aug 20 17:28:35 celeron kernel: bttv: Host bridge is VIA Technologies, Inc. VT82C693A/694x [Apollo PRO133x]
Aug 20 17:28:35 celeron kernel: bttv: Bt8xx card found (0).
Aug 20 17:28:35 celeron kernel: PCI: Found IRQ 5 for device 00:0c.0
Aug 20 17:28:35 celeron kernel: PCI: Sharing IRQ 5 with 00:08.0
Aug 20 17:28:35 celeron kernel: PCI: Sharing IRQ 5 with 00:0c.1
Aug 20 17:28:35 celeron kernel: bttv0: Bt878 (rev 17) at 00:0c.0, irq: 5, latency: 32, memory: 0xde000000
Aug 20 17:28:35 celeron kernel: bttv0: using: BT878( *** UNKNOWN/GENERIC **) [card=0,insmod option]
Aug 20 17:28:35 celeron modprobe: Note: /etc/modules.conf is more recent than /lib/modules/2.4.19/modules.dep
Aug 20 17:28:35 celeron kernel: bttv0: i2c: checking for MSP34xx @ 0x80... not found
Aug 20 17:28:35 celeron kernel: bttv0: i2c: checking for TDA9875 @ 0xb0... not found
Aug 20 17:28:35 celeron kernel: bttv0: i2c: checking for TDA7432 @ 0x8a... not found
Aug 20 17:28:35 celeron kernel: bttv0: registered device video0
Aug 20 17:28:35 celeron kernel: bttv0: registered device vbi0
Aug 20 17:30:16 celeron kernel: Linux video capture interface: v1.00
Aug 20 17:30:16 celeron kernel: bttv: driver version 0.7.91 loaded
Aug 20 17:30:16 celeron kernel: bttv: using 2 buffers with 2080k (4160k total) for capture
Aug 20 17:30:16 celeron kernel: bttv: Host bridge is VIA Technologies, Inc. VT82C693A/694x [Apollo PRO133x]
Aug 20 17:30:16 celeron kernel: bttv: Bt8xx card found (0).
Aug 20 17:30:16 celeron kernel: PCI: Found IRQ 5 for device 00:0c.0
Aug 20 17:30:16 celeron kernel: PCI: Sharing IRQ 5 with 00:08.0
Aug 20 17:30:16 celeron kernel: PCI: Sharing IRQ 5 with 00:0c.1
Aug 20 17:30:16 celeron kernel: bttv0: Bt878 (rev 17) at 00:0c.0, irq: 5, latency: 32, memory: 0xde000000
Aug 20 17:30:16 celeron kernel: bttv0: using: BT878( *** UNKNOWN/GENERIC **) [card=0,insmod option]
Aug 20 17:30:16 celeron kernel: bttv0: i2c: checking for MSP34xx @ 0x80... not found
Aug 20 17:30:16 celeron modprobe: Note: /etc/modules.conf is more recent than /lib/modules/2.4.19/modules.dep
Aug 20 17:30:16 celeron kernel: bttv0: i2c: checking for TDA9875 @ 0xb0... not found
Aug 20 17:30:16 celeron kernel: bttv0: i2c: checking for TDA7432 @ 0x8a... not found
Aug 20 17:30:16 celeron kernel: bttv0: registered device video0
Aug 20 17:30:16 celeron kernel: bttv0: registered device vbi0
als ik xawtv opstart krijg ik aleen maar zwart beeld en met fbtv krijg ik wel sneeuw maar geen beeld :(
ik heb ook een mailtje gestuurd naar e-tech (er stond op de doos dat die compatibel was met linux) maar ze zijden dat het alleen met redhat suse werkte en ik gebruik slackware :(
dus was mij vraag hoe krijg ik hem aan het werk?
  • Fatal-Error
Als je sneeuw krijgt werkt de kaart toch? Je moet alleen nog zenders zoeken lijkt mij...
Welcome to the desert of the real.
weet je zeker dat je de tuner goed hebt ingesteld?
insmod tuner type=5
dit is PAL waardoor je de zenders in deze streek kunt ontvangen, waarschijnlijk staat ie op de standaard (0), misschien dat je daardoor geen zenders kan ontvangen?
Misschien heb je ook wel het verkeerde kaart type geladen, jij hebt card=0, misschien moet je wel 1 van de andere 53 kaarten hebben:
card=0 - *** UNKNOWN ***
card=1 - MIRO PCTV
card=2 - Hauppauge old
card=3 - STB
card=4 - Intel
card=5 - Diamond DTV2000
card=6 - AVerMedia TVPhone
card=7 - MATRIX-Vision MV-Delta
card=8 - Fly Video II
card=9 - TurboTV
card=10 - Hauppauge new (bt878)
card=11 - MIRO PCTV pro
card=12 - ADS Technologies Channel Surfer TV
card=13 - AVerMedia TVCapture 98
card=14 - Aimslab VHX
card=15 - Zoltrix TV-Max
card=16 - Pixelview PlayTV (bt878)
card=17 - Leadtek WinView 601
card=18 - AVEC Intercapture
card=19 - LifeView FlyKit w/o Tuner
card=20 - CEI Raffles Card
card=21 - Lucky Star Image World ConferenceTV
card=22 - Phoebe Tv Master + FM
card=23 - Modular Technology MM205 PCTV, bt878
card=24 - Askey/Typhoon/Anubis Magic TView CPH051/061 (bt878)
card=25 - Terratec/Vobis TV-Boostar
card=26 - Newer Hauppauge WinCam (bt878)
card=27 - MAXI TV Video PCI2
card=28 - Terratec TerraTV+
card=29 - Imagenation PXC200
card=30 - FlyVideo 98
card=31 - iProTV
card=32 - Intel Create and Share PCI
card=33 - Terratec TerraTValue
card=34 - Leadtek WinFast 2000
card=35 - Chronos Video Shuttle II
card=36 - Typhoon TView TV/FM Tuner
card=37 - PixelView PlayTV pro
card=38 - TView99 CPH063
card=39 - Pinnacle PCTV Rave
card=40 - STB2
card=41 - AVerMedia TVPhone 98
card=42 - ProVideo PV951
card=43 - Little OnAir TV
card=44 - Sigma TVII-FM
card=45 - MATRIX-Vision MV-Delta 2
card=46 - Zoltrix Genie TV
card=47 - Terratec TV/Radio+
card=48 - Dynalink Magic TView
card=49 - GV-BCTV3
card=50 - Prolink PV-BT878P+4E (PixelView PlayTV PAK)
card=51 - Eagle Wireless Capricorn2 (bt878A)
card=52 - Pinnacle Studio PCTV Pro
card=53 - Typhoon TView RDS
veel succes :)
Verwijderd schreef op 20 augustus 2002 @ 17:49:
card=0? Zie /usr/src/linux/Documentation/video4linux/bttv/CARDLIST, je wilt hier waarschijnlijk iets anders invullen... ;). En de tuner module moet je ook insmodden ja.
  • cold
voor the record het is card=21 (werkt hier prima) :)
2x MT v3 | EMS v149 VNS v119 BMS v113 | Home Battery Control for Home Assistant & Node-RED | M5Stack RS485 | AstraMeter as virtual CT002
[KNIP]
[slightly offtopic]
Dat zetten ze bij E-tech wel vaker op de doos |:( Ik had laatsts nog een 56k6 PCI (soft)modem van E-tech, had ook drivers voor Linux stond er op de doos. Dus ikke op de CD kijken, werd ik doorverwezen naar de site van E-tech. Kom ik op de site van E-tech word ik doorverwezen naar de site van Linuxant, daar kon ik dan drivers kopen voor (de naar eigen zeggen bescheiden) prijs van $ 14.95 (per modem/MAC-adres). Het modem zelf kostte trouwens +- 10 EUR. :'(
[/slightly offtopic]
cold schreef op 22 juni 2004 @ 05:21:
Ik ga het kaartje zo wel even weer in mn pc stoppen en het uitproberen :D
Verwijderd schreef op 22 juni 2004 @ 11:12:
[slightly offtopic]
ook hun windows XP drivers voor mn tv kaart zijn slecht (het hele systeem werdt er instabiel door)
dit topic kan van mij dicht :) (het is 2 jaar oud zo te zien)
