Probleem met HP brander
PC: PIII 1 Ghz WinXP
Brander: HP Cd-writer 8230e USB (extern)
Bij apparaatbeheer staat de brander aangegeven als:
CD-Rom drive (IMAPI settings 1,2)
ASPI: WNASPI32.DLL Version: 2.0.1.50 voor WinXP
DMA staat aan, WNASPI32.DLL van de Nero site afgehaald, nog niks.
Met Nero kan hij niet branden, zelfs niet op 1 speed, met de software van HP wel.
Hier het log van NERO:
Windows XP 5.1
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1013), size=48128 bytes, created 13-5-1998 5:18:28
ahead WinASPI: File 'C Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.44, size=172099 bytes, created 18-7-2002 13:03:44
Nero Version: 5.5.8.2
Recorder: <HP CD-Writer+ 8200a> Version: 1.0g - HA 2 TA 0 - 5.5.8.2
Adapter driver: <HPUATA> HA 2
Drive buffer : 12886kB
Bus Type : default (0) -> ATAPI
CD-ROM: <COMPAQ CD-ROM CR-594> Version: YC0G - HA 1 TA 0 - 5.5.8.2
Adapter driver: <atapi> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD200BB-60BNA1 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : COMPAQ CD-ROM CR-594 atapi Port 1 ID 0 DMA: Off
PeripheralA : HPUATA Port 2 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 254MB (260528kB)
Free physical memory: 50MB (52192kB)
Memory in use : 79 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: On
CD-ROM (ISO)
18.7.2002
13:12:08 #1 Text 0 File Isodoc.cpp, Line 5383
Iso document burn settings
Determine maximum speed : FALSE
Simulate : TRUE
Write : FALSE
Finalize CD : FALSE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9600
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
13:12:08 #2 Text 0 File Reader.cpp, Line 118
Reader running
13:12:08 #3 Text 0 File Writer.cpp, Line 129
Writer HP CD-Writer+ 8200a running
13:12:08 #4 Text 0 File Burncd.cpp, Line 2778
Turn on Track-At-Once, using CD-R/RW media
13:12:08 #5 ISO9660GEN -11 File geniso.cpp, Line 4428
First writeable address = 0 (0x00000000)
13:12:08 #6 Text 0 File ThreadedTransferInterface.cpp, Line 684
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 72136 (72136) = #72136/16:1.61
relocatable, CD pos for caching/writing not required/required, no patch infos
13:12:11 #7 Text 0 File DlgWaitCD.cpp, Line 199
Last possible write address on media: 395331 (87:53.06)
Last address to be written: 101207 (22:31.32)
13:12:11 #8 Text 0 File DlgWaitCD.cpp, Line 1394
Recorder: HP CD-Writer+ 8200a;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 90, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 00 (LO 79:59.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
13:12:15 #9 Text 0 File ThreadedTransferInterface.cpp, Line 834
Prepare recorder HP CD-Writer+ 8200a for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close Session
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 148041728
13:12:15 #10 Text 0 File ThreadedTransferInterface.cpp, Line 862
Removed 2 run-out blocks from end of track 1.
13:12:15 #11 Text 0 File ThreadedTransferInterface.cpp, Line 684
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 72134 blocks [HP CD-Writer+ 8200a]
13:12:15 #12 Phase 24 File dlgbrnst.cpp, Line 1550
Caching of files started
13:12:16 #13 Phase 25 File dlgbrnst.cpp, Line 1550
Caching of files completed
13:12:16 #14 Phase 32 File dlgbrnst.cpp, Line 1550
Simulation started at 1x (150 KB/s)
13:12:17 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1961
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #29072
13:12:19 #16 SCSI -1066 File Cdrdrv.cpp, Line 1399
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x04970000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x71 0x90 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x24 0x00
13:12:19 #17 CDR -1013 File Writer.cpp, Line 330
Buffer underrun
13:12:19 #18 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
13:12:19 #19 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
13:12:19 #20 CDR -201 File WriterStatus.cpp, Line 145
Invalid writestate
13:12:19 #21 TRANSFER -18 File WriterStatus.cpp, Line 145
Could not perform EndTrack
13:12:20 #22 Phase 34 File dlgbrnst.cpp, Line 1550
Simulation failed at 1x (150 KB/s)
13:12:20 #23 Text 0 File Scsicmd.cpp, Line 386
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=1.00 (1030), size=22585 bytes, created 21-11-2001 14:50:36
File 'Drivers\ASPI32.SYS': Ver=4.57 (1013), size=24256 bytes, created 13-5-1998 5:27:44
