FreeS/Wan "no suitable connection to peer"
  • 48 views sinds 30-01-2008
  • Rempage0611
  • Laatst online: 23-09-2025
Rempage0611
9405 WP @ 2x SMA Sunny Boy
Ik heb dus een Freeswan linux server en een winXP client. Ik heb de freeswan install gepatched met x.509. Het probleem wat is heb is dat ik de melding "no suitable connection to peer" krijg. Hieronder een uitgebreider log
Aug 19 14:56:11 Debian pluto[269]: packet from 213.194.1.179:500: ignoring Vendor ID payload
Aug 19 14:56:11 Debian pluto[269]: "roadwarrior"[1] 213.194.1.179 #1: responding to Main Mode from unknown peer 213.194.1.179
Aug 19 14:56:13 Debian pluto[269]: "roadwarrior"[1] 213.194.1.179 #1: Peer ID is ID_DER_ASN1_DN: 'C=NL, ST=NH, L=aa, O=aa, OU=TD, CN=aa, E=aa@aa.nl'
Aug 19 14:56:13 Debian pluto[269]: "roadwarrior"[1] 213.194.1.179 #1: no suitable connection for peer 'C=NL, ST=NH, L=aa, O=aa, OU=TD, CN=Flappie2,E=aa@aa.nl'
Aug 19 14:56:14 Debian pluto[269]: "roadwarrior"[1] 213.194.1.179 #1: Peer ID is ID_DER_ASN1_DN: 'C=NL, ST=NH, L=aa, O=aa, OU=TD, CN=Flappie2, E=aa@aa.nl'
Aug 19 14:56:14 Debian pluto[269]: "roadwarrior"[1] 213.194.1.179 #1: no suitable connection for peer 'C=NL, ST=NH, L=aa, O=aa, OU=TD, CN=Flappie2,E=aa@aa.nl'
Aug 19 14:56:16 Debian pluto[269]: "roadwarrior"[1] 213.194.1.179 #1: Peer ID is ID_DER_ASN1_DN: 'C=NL, ST=NH, L=aa, O=aa, OU=TD, CN=Flappie2,E=aa@aa.nl'
Aug 19 14:56:16 Debian pluto[269]: "roadwarrior"[1] 213.194.1.179 #1: no suitable connection for peer 'C=NL, ST=NH, L=aa, O=aa, OU=TD, CN=Flappie2, E=aa@aa.nl'
Aug 19 14:56:20 Debian pluto[269]: "roadwarrior"[1] 213.194.1.179 #1: Peer ID is ID_DER_ASN1_DN: 'C=NL, ST=NH, L=aa, O=aa, OU=TD, CN=Flappie2, E=aa@aa.nl'
Aug 19 14:56:20 Debian pluto[269]: "roadwarrior"[1] 213.194.1.179 #1: no suitable connection for peer 'C=NL, ST=NH, L=aa, O=aa, OU=TD, CN=Flappie2, E=aa@aa.nl'
Het volgende heb ik er over kunnen vinden in de FAQ van Frees/Wan:
When a connection is initiated by the peer, Pluto must choose which entry in the conf file best matches the incoming connection. A preliminary choice is made on the basis of source and destination IPs, since that information is available at that time.
A payload containing an ID arrives later in the negotiation. Based on this id and the *id= parameters, Pluto refines its conn selection. ...
The message "no suitable connection" indicates that in this refining step, Pluto does not find a connection that matches that ID.
Die ID komt netjes aan, inclusief alle gegevens. Kortom het certificaat is ook goed geinstalleerd. De naam Flappie2 zit nml in het certificaat ingebakken...
Maar waarom werkt het dan nog niet????
Hier nog m`n ipsec.conf
29
30
31
32
33
34
35
36
37
38
39
# /etc/ipsec.conf - FreeS/WAN IPsec configuration file
# More elaborate and more varied sample configurations can be found
# in FreeS/WAN's doc/examples file, and in the HTML documentation.
# basic configuration
config setup
        # THIS SETTING MUST BE CORRECT or almost nothing will work;
        # %defaultroute is okay for most simple cases.
        interfaces=%defaultroute
        # Debug-logging controls:  "none" for (almost) none, "all" for lots.
        klipsdebug=none
        plutodebug=none
        # Use auto= parameters in conn descriptions to control startup actions.
        plutoload=%search
        plutostart=%search
        # Close down old connection when new one using same ID shows up.
        uniqueids=yes
conn %default
        keyingtries=1
        compress=yes
        disablearrivalcheck=no
        authby=rsasig
        leftrsasigkey=%cert
        rightrsasigkey=%cert
conn roadwarrior
        right=%any
        left=111.11.11.111
        leftsubnet=10.1.0.0/24
        leftcert=host.example.com.pem
        rightcert=winhost.example.com.pem
        auto=add
        pfs=yes
Wie kan mij helpen? Thnx.
  • Rempage0611
Rempage0611
Inmiddels heb ik de leftcert en rightcert waardes weg gehaald en zie ik dit:
Aug 19 16:43:07 Debian pluto[270]: "roadwarrior"[2] 213.194.2.252 #6:responding to Main Mode from unknown peer 213.194.2.252
Aug 19 16:43:09 Debian pluto[270]: "roadwarrior"[2] 213.194.2.252 #6:Peer ID is ID_DER_ASN1_DN: 'C=NL, ST=NH, L=aa, O=aa, OU=TD, CN=Flappie2,=aa@aa.nl'
Aug 19 16:43:09 Debian pluto[270]: "roadwarrior"[2] 213.194.2.252 #6: sent MR3, ISAKMP SA established
En naarna gebeurt er nix meer...Wat kan dit zijn?
  • Predator
  • Laatst online: 20:42
Predator
Suffers from split brain
PNS -> NT & slot
FreesWan geeft Netgotiating IP Security
Je kan daar gewoon voortgaan.
Everybody lies | BFD rocks ! | PC-specs
