k7 @ 700mhz
hai
ik heb net met athlon overclocked naar 700mhz
1.7volt
is dit goed? :)
2981 3d marks
Processor 1 : AMD Athlon (Model 1) / 9F195B1C
: AMD-K7(tm) Processor
Platform : Slot A (SC242 Connector)
Vendor ID : AuthenticAMD
Type ID : 0 (0)
Family ID : 6 (7)
Model ID : 1 (1)
Stepping ID : 2 (2)
Brand ID : 0 (0)
Clock Frequency
Internal : 701.59 MHz
External : 200.45 MHz DDR
Multiplier : 7.0
L1 I-Cache : 64K
L1 D-Cache : 64K
L1 T-Cache : ---
L2 Cache : 512K Byte
L2 Speed : 1/2 H4 (1/2 H4, 1/2 S4)
L3 Cache : ---
MMX : Supported
SIMD : Not Supported
3DNow! : Supported
Machine : IBM PC/AT
Version : Windows 98 Version 4.10.1998
CPU AMD Athlon 700MHz
3D Accelerator NVIDIA RIVA TNT2
Chipset NVIDIA RIVA TNT2
Resolution 1024*768*16
Z-Buffer Depth 16-bit
Frame Buffer Triple
Refresh Rate V Sync.Off
CPU Optimization AMD Athlon(tm)
3DMark Result 2981 3D marks
CPU Speed 203 CPU 3D marks
Game 1 - Helicopter - Low Detail 63.96 FPS
Game 1 - Helicopter - Medium Detail 44.39 FPS
Game 1 - Helicopter - High Detail 19.29 FPS
Game 2 - Adventure - Low Detail 55.44 FPS
Game 2 - Adventure - Medium Detail 40.49 FPS
Game 2 - Adventure - High Detail 24.82 FPS
Fill Rate (Single-Texturing) 262.68 MTexels/s
Fill Rate (Multi-Texturing) 241.56 MTexels/s
High Polygon Count (1 Light) 3592 KTriangles/s
High Polygon Count (4 Lights) 3183 KTriangles/s
High Polygon Count (8 Lights) 2581 KTriangles/s
8MB Texture Rendering Speed 185.07 FPS
16MB Texture Rendering Speed 182.41 FPS
32MB Texture Rendering Speed 163.93 FPS
64MB Texture Rendering Speed Not Supported
Bump Mapping (Emboss, 3-pass) 100.03 FPS
Bump Mapping (Emboss, 2-pass) 116.98 FPS
Bump Mapping (Emboss, 1-pass) 177.23 FPS
Bump Mapping (Environment) Not Supported
Published No
Nope, ik heb slechtere componenten en ik heb een hogere score.
CPU Intel Celeron 950MHz
3D Accelerator 3dfx Interactive, Inc. Voodoo Series Driver
Chipset 3dfx Voodoo3 2000/3000
Frame Buffer Triple
CPU Optimization Intel(R) Pentium(R) III
3DMark Result 3217 3D marks
CPU Speed 222 CPU 3D marks
Game 1 - Helicopter - Low Detail 64.54 FPS
Game 1 - Helicopter - Medium Detail 42.05 FPS
Game 1 - Helicopter - High Detail 19.51 FPS
Game 2 - Adventure - Low Detail 65.74 FPS
Game 2 - Adventure - Medium Detail 46.96 FPS
Game 2 - Adventure - High Detail 29.24 FPS
Fill Rate (Single-Texturing) 182.41 MTexels/s
Fill Rate (Multi-Texturing) 359.25 MTexels/s
High Polygon Count (1 Light) 2837 KTriangles/s
High Polygon Count (4 Lights) 2561 KTriangles/s
High Polygon Count (8 Lights) 2283 KTriangles/s
8MB Texture Rendering Speed 156.72 FPS
16MB Texture Rendering Speed 148.05 FPS
32MB Texture Rendering Speed 127.26 FPS
64MB Texture Rendering Speed N/A
Bump Mapping (Emboss, 3-pass) 110.03 FPS
Bump Mapping (Emboss, 2-pass) 149.32 FPS
Bump Mapping (Emboss, 1-pass) Not Supported
Mijn config:
Celeron 2 566@933
MSI 6163 PRO
Voodoo 3 3000@185Mhz
M-Tec 128mb 133Mhz cas2
IBM DTLA 15,2 gig
Toshiba sd-m1202 5X DVD
HP8100i
  • seppie
  • Laatst online: 08-09 09:57
seppie
Wie anders?
tja,capone, hoever heb je je athlon nou geoc-ed?
Wat had je eerst?
Don't You stare there, Operate!
wat raar!
hoe kan dat?
iemand enig idee?
ik had dus eerst een athlon @ 500 mhz
met een riva tnt2 ultra
verder gebruik ik de detonator 2.08
Ligt aan die TNT2 denk ik, ik heb een Athlon 500, 128MB 100 Mhz en G-Force 1 (Asus V6600) en haalde iets van 3600.
