Windows XP SP1 & Key Blocking Info
  • 40 views sinds 30-01-2008
  • maartena
  • Laatst online: 08-09-2025
Gevonden op het web. Welicht handig om te testen of je SP1 kunt installen of niet ;)
In an email sent to OEM system builders MS tells:
When released, Service Pack 1 for Microsoft Windows XP will not install if it identifies the underlying Windows XP installation as a known pirated installation. SP1 identifies known pirated installations by their Product IDs. The Product ID is generated from the Product Key used during install and can be found by choosing My Computer, then Properties, and viewing the General tab.
SP1 will not install on installations with the following product IDs containing the following serial numbers (note that X takes the place of any other value): XXXXX-640-0000356-23XXX, & XXXXX-640-2001765-23XXX. Users of licensed Microsoft software will be unaffected. If SP1 is installed on a Windows XP installation with one of the above product IDs, SP1 installation will fail and error with the following message: Service Pack 1 Setup Error: The product key used to install Windows is invalid.
Please contact your system administrator or retailer immediately to obtain a valid product key. You may also contact Microsoft Corporation's Anti-Piracy Team by emailing piracy@microsoft.com if you think you have purchased pirated Microsoft software. Please be assured that any personal information you send to the Microsoft Anti-Piracy team will be kept in strict confidence
"I reject your reality and substitute my own!"
Proud to be an American.
Hier woon ik
  • Pogostokje
  • Laatst online: 08-10 21:48
Pogostokje
* twiet *
Handig inderdaad, schept wel duidelijkheid in de zaak.
Wat is de bron van dit stukje tekst?
... ook ik heb soms per ongeluk gelijk.
  • maartena
Hier woon ik
domme vraag , maaruh wanneer komt ie officieel in nl uit?
Is hier nu eigenlijk al een fix voor?
  • blackd
Volgens mij gaan hier allemaal nare illegale dingen mee gebeuren. Dicht dus.
9000Wp o/w SolarEdge SE6K - Panasonic 5kW bi-bloc - gasloos sinds 17-7-2023
