29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
| import java.text.NumberFormat;
import java.util.Observable;
import java.io.*;
/** Definition of a Ship class with position,
* speed, course and name information.
* @author David J. Barnes (d.j.barnes@ukc.ac.uk)
* @version Version 2.0 (14th Apr 1999)<br>
public class Ship extends Observable implements Runnable {
/** Default X position. */
public static final double DEFAULT_X = 25.0;
/** Default Y position. */
public static final double DEFAULT_Y = 25.0;
/** Default course. */
public static final double DEFAULT_COURSE = 0.0;
/** Default speed. */
public static final double DEFAULT_SPEED = 5.0;
/** Construct with explicit position, course, speed and name.
public Ship(double x, double y, double course, double speed,String name){
setSpeed(speed);
setPosition(x,y);
setCourse(course);
this.name = name;
// Am I the first?
if(getFormatter() == null){
formatter = NumberFormat.getNumberInstance();
// Print to two decimal places.
formatter.setMaximumFractionDigits(2);
setFormatter(formatter);
// Add myself to the GUI.
sea.add(this);
/** Construct with explicit position, course and speed.
* The ship has no name.
public Ship(double x, double y, double course, double speed){
this(x,y,course,speed,"");
/** Construct with explicit position and course.
public Ship(double x, double y, double course){
this(x,y,course,DEFAULT_SPEED);
/** Construct with explicit position.
public Ship(double x, double y){
this(x,y,DEFAULT_COURSE);
/** Construct with default position, course and speed.
public Ship(){
// Set default position, course and speed for this ship.
this(DEFAULT_X,DEFAULT_Y);
/** Construct with a name.
public Ship(String name){
this(DEFAULT_X,DEFAULT_Y,DEFAULT_COURSE,DEFAULT_SPEED,name);
/** Set the ship's position.
public void setPosition(double x, double y){
setPosition(new Position(x,y));
radarBlip();
public void setPosition(Position newPosition){
position = newPosition;
/** Set the ship's speed.
* @param newSpeed A positive or negative value.
public void setSpeed(double newSpeed){
speed = newSpeed;
/** Set the ship's course.
* @param newCourse The course in degrees. Values are
* adjusted to the range [0..360)
public void setCourse(double newCourse){
// Make sure it is in the range [0..360)
final double numDegrees = 360.0;
if(newCourse < 0){
newCourse = numDegrees+(newCourse%numDegrees);
course = newCourse % numDegrees;
radarBlip();
/** Report the ship's position, course and speed.
* Reporting is done via the ship's current.
* @see #getWriter()
* @see #setWriter(PrintWriter)
public void report(){
Position p = getPosition();
NumberFormat formatter = getFormatter();
PrintWriter writer = getWriter();
String name = getName();
if((name != null) && !name.equals("")){
writer.print(name+": ");
writer.print("Position is ("+formatter.format(p.getX())+","+
formatter.format(p.getY())+"), ");
writer.print("Course is "+formatter.format(getCourse())+", ");
writer.print("Speed is "+formatter.format(getSpeed()));
writer.println();
writer.flush();
/** Move the ship according to its current speed and position.
public void move(){
double radians = Math.toRadians(getCourse());
setPosition(p.getX()+speed*Math.cos(radians),
p.getY()+speed*Math.sin(radians));
/** An implementation of the Runnable interface, to enable a Ship
* to be run in an independent thread, if required.
* @see java.lang.Runnable
public void run(){
while(true){
move();
report();
// Be prepared to yield, in case we are not sleeping for
// some reason.
Thread.yield();
/** Return the current position.
* @see Position
public Position getPosition(){
return new Position(position.getX(),position.getY());
/** Return the current course.
public double getCourse(){
return course;
/** Return the current speed.
public double getSpeed(){
return speed;
/** Return the current name.
public String getName(){
return name;
/** Return the current course and position.
* @see CourseAndPosition
public CourseAndPosition getCourseAndPosition(){
return new CourseAndPosition(getCourse(),getPosition());
/** Get the writer to be used for reporting.
* @see #report()
public PrintWriter getWriter(){
return writer;
/** Set the writer to be used for reporting.
* @see #report()
public void setWriter(PrintWriter w){
writer = w;
/** Notify any observers of a significant change.
protected void radarBlip(){
setChanged();
notifyObservers(getCourseAndPosition());
// Give the UI a chance to display us.
delay();
/** Make the animation a little easier to follow.
* Sleep for a time related to the ship's speed.
* @see #getDelayTime()
* @see #setDelayTime(int)
protected void delay(){
try{
final int maxSleepTime = getDelayTime();
int sleepTime;
final double speed = getSpeed();
if(speed == 0){
sleepTime = maxSleepTime;
else{
sleepTime = (int) Math.abs(maxSleepTime/speed);
Thread.sleep(sleepTime);
catch(InterruptedException e){
protected NumberFormat getFormatter(){
return formatter;
protected void setFormatter(NumberFormat f){
formatter = f;
/** Get the delay time (in milliseconds) used by the animation.
protected int getDelayTime(){
return delayTime;
/** Set the delay time used by the animation.
* @param delay The delay time in milliseconds.
protected void setDelayTime(int delay){
if(delay >= 0){
delayTime = delay;
// (x,y) co-ordinates in the ocean.
private Position position;
// Speed and course
private double speed;
// Keep degrees in the range [0..360)
private double course;
// A name for the ship.
private final String name;
// The GUI used to display ships. Shared by them all.
private static final SeaGUI sea = new SeaGUI();
// A formatter used in reporting. Shared by all ships.
private static NumberFormat formatter;
// How long to delay between moves, to make the animation easier
// to follow. A value in milliseconds.
private int delayTime = 4000;
// Where reports are printed to. Standard output by default.
private PrintWriter writer = new PrintWriter(System.out);
