Niet onderstreepte hyperlink
  • 57 views sinds 30-01-2008
Ik ben via Frontpage bezig een website te maken. Nu worden de hyperlinks standaard onderstreept, maar ik wil dit eigenlijk niet. Wie weet hoe ik dit kan oplossen?
Dit hoort eigenlijk in W&G, maar dit is een vraag die je makkelijk met behulp van de seach of google kan oplossen, dus ik denk niet dat ze dit topic daar willen.
To create a page that contains both underlined and plain text hyperlinks, try the following:
If special text formatting is desired for some but not all of the links on a page, one strategy would involve inserting image files in place of the text. Use an image editing program to design graphics that display the text as desired, insert the images instead of typing text, then create links for the image files, using the Property inspector.
Another strategy avoids the use of images, and allows specific links on a page to be altered. Removing the underline from just one link on a page requires hand coding the HTML source code. After creating the linked text, open up the HTML inspector (Window > HTML Source) and find the anchor tag surrounding the text that should not be underlined. The source might look something like this:
<a href="http://www.macromedia.com">Macromedia</a>
Type in the code highlighted in red, to make this hyperlink display without an underline:
<a href="http://www.macromedia.com" style="text-decoration:none">Macromedia</a>
Note: Using this method, the modified links will appear without an underline, both in Dreamweaver's Document window and in the browser. The unaltered links will continue to display with underlines, by default. Conversely, if it is desired to display the majority of the links on a page with plain text, but a few with underlines, follow the steps above to redefine the anchor tag to remove the underlines. Then, highlight the links that should be underlined and add the code highlighted in red to the anchor tag:
<a href="http://www.macromedia.com" style="text-decoration:underline">Macromedia</a>
Bronvermelding:
Eerste link met google
Het zal misschien niet precies zijn wat je bedoelt, maar ik ben dan ook niet zoeen html. Je begrijpt de bedoeling iig wel.
[ Voor 0% gewijzigd door Verwijderd op 14-08-2002 21:28 . Reden: Toevoeging ]
  • elvis84
elvis84
Has Left The Building
idd...te makkelijk...stel voor dat hier snel een slot op komt...
Little Less Conversation, Little More Action Please!!!
Ik heb de search gebruikt, maar er staat niets hierover in. Google zal ik nu even raadplegen.
  • 2Dutch
2Dutch
No worries eh!
Eerst andere websites raadplegen, dan de search van GOT (als ie werkt..) en dan pas hier posten :)
  • Wildfire
  • Laatst online: 23:35
Wildfire
Joy to the world!
Zoals Airwolf al schreef:
<a href="(je URL hier)" style="text-decoration:none">(je tekst hier)</a>
Systeemspecs | Mijn V&A spulletjes | Mijn RIPE Atlas probe
  • Appeltaart
  • Laatst online: 18-05-2025
ik zou je liever adviseren om gewoon CSS te gebruiken bovenin de pagina of in een afzonderlijke file :S dan krijg je :
<style type="text/css">
a:link { text-decoration: none}
</style>
  • AW_Bos
  • Laatst online: 01:07
AW_Bos
Nostalgicus 🕰
Appeltaart schreef op 15 augustus 2002 @ 10:56:
</style>
Dan worden wel al je linkjes on-onderstreept!
  • Appeltaart
jep :o
  • Roelant
Dit hoort eigenlijk in Webdesign & Graphics thuis, maar daar wordt 'ie direct dichtgegooid, dus dan heeft moven weinig zin meer en gooi ik 'm hier op slot. Als je je afvraagt waarom, raad ik je aan de FAQ's in het forum waar dit topic thuishoort eens te lezen :)
