• GeFke
  • Laatst online: 18-08-2024
Ik wou even een leuke draad opzetten over : Registry :)
Je eigen wallpaper tijdens het opstarten
HKEY_USERS\.DEFAULT\Control Panel\Desktop\Wallpaper
Waarde : C:\...\*.bmp
Ook ooit het probleem gehad dat je een ander toetsenbord hebt bij het inloggen ?
Je toetsenbord settings instellen tijdens het opstarten
HKEY_USERS\.DEFAULT\Keyboard Layout\Preload
Waarde : 00000813 (Voor AZERTY)
Numlock aanzetten tijdens het opstarten
HKEY_CURRENT_USER\Control Panel\Keyboard\InitialKeyboardIndicators
Waarde : 2
Pijltjes van de snelkoppeling verwijderen
HKEY_CLASSES_ROOT\lnkfile\IsShortcut
Deze sleutel verwijderen
Zo ken ik er nog verschillende, iemand interresse ??
Dit is in elk geval leerrijker dan die tweak-programmatjes
  • Tyrian
Tyrian
It's Unreal.
Here's a great tip (a bug actually) to speed up your browsing of Windows 2000 machines. Its actually a fix to a bug that by default of a normal Windows 2000 setup that scans for shared files for Scheduled Tasks. And its turns out that you can experience a delay as long as 30 seconds when you try to view shared files across a network from as Windows 2000 is using the extra time to search the remote computer. Note that though the fix is originally intended for only those affected, Windows 2000 users will experience that actual browsing speed of both the Internet & Windows Explorers improving significantly after applying it since it doesnt search for the Scheduled Tasks anymore. Here's how :
Open up the Registry and go to :
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/Current Version/Explorer/RemoteComputer/NameSpace
Under that branch, select the key :
{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
and delete it.
This is key that instructs Windows to search for Scheduled Tasks. If you like you may want to export the exact branch so that you can restore the key if necessary. This fix is so effective that it doesn't require a reboot and you can almost immediately determine yourself how much it speeds up your browsing processes
http://www.hypercoop.tk | GW user page | GW2 user page
Specs
  • BalusC
BalusC
Carpe diem
Alle registry tweaks aangaande de Internetverbinding staan op www.speedguide.net - check 'Registry Tweaks' en 'Advanced Tweaks' aldaar :)
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Front verplichte underscores
Een opsomming van regedits lijkt me niet echt nodig, naast bovenstaande zijn daar nog veel meer sites voor;
http://www.tweakxp.com
http://www.jsiinc.com/reghack.htm
http://www.annoyances.org
http://www.activewin.com/tips/reg/index.shtml
etc etc :+
Ik denk dat die opsommingen genoeg zouen moeten zijn zonder een specifieke vraag.
kijk uit met reghacken... thuis is dit op zich geen probleem, maar probeer het in professionele omgevingen zoveel mogelijk te vermijden (je kan echter soms niet anders)
  • Dennahz
  • Laatst online: 25-11 08:13
Dennahz
Life feels like hell should.
Interessant draadje, heb zelf eigenlijk niks toe te voegen. :+
Twitter
  • GeFke
http://www.winguides.com
Deze vind ik zelf een heel goeie, maar de bedoeling van mijn draadje was echt om coole registrysettings te zoeken zonder daarvoor het hele internet voor af te schuimen ... ;)
Nog een leuke
Powerdown after Shutdown
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Winlogon
Hier een nieuwe tekenreekswaarde toevoegen :
Naam : PowerDownAfterShutdown
Waarde : 1
