even een aanvulling:
compilen onder kernel 2.4.19 van apmd wil niet. Je krijgt dan errors als:
29
30
31
| Compile log for apmd 3.0.2 Built on Sun Aug 11 14:53:27 UTC 2002
gcc -c -mcpu=i686 -march=i686 -O3 -Os -Wall -pipe -I. -I/usr/src/linux/include -I/usr/src/linux-2.2/include -I /usr/src/linux-2.0/include -DVERSION=\"3.0.
2\" -DAPMD_PROXY_NAME=\"/etc/apmd_proxy\" apmlib.c
ar rv libapm.a apmlib.o
a - apmlib.o
ranlib libapm.a
2\" -DAPMD_PROXY_NAME=\"/etc/apmd_proxy\" apm.c
gcc -o apm apm.o -L. -lapm
2\" -DAPMD_PROXY_NAME=\"/etc/apmd_proxy\" apmd.c
gcc -o apmd apmd.o -L. -lapm
2\" -DAPMD_PROXY_NAME=\"/etc/apmd_proxy\" -DNARROWPROTO xapm.c
gcc -o xapm xapm.o -L. -lapm -L/usr/X11R6/lib -lXaw -lXmu -lXt -lXext -lSM -lICE -lX11
2\" -DAPMD_PROXY_NAME=\"/etc/apmd_proxy\" apmsleep.c
In file included from apmsleep.c:49:
/usr/src/linux/include/asm/spinlock.h: In function `spin_lock':
/usr/src/linux/include/asm/spinlock.h:137: parse error before `LOCK_SECTION_START'
/usr/src/linux/include/asm/spinlock.h: In function `read_lock':
/usr/src/linux/include/asm/spinlock.h:188: parse error before `LOCK_SECTION_START'
/usr/src/linux/include/asm/spinlock.h:188: warning: implicit declaration of function `LOCK_SECTION_START'
/usr/src/linux/include/asm/spinlock.h:188: parse error before string constant
/usr/src/linux/include/asm/spinlock.h: In function `write_lock':
/usr/src/linux/include/asm/spinlock.h:197: parse error before `LOCK_SECTION_START'
/usr/src/linux/include/asm/spinlock.h:197: parse error before string constant
apmsleep.c: At top level:
apmsleep.c:64: warning: `rcsid' defined but not used
make: *** [apmsleep.o] Error 1
rm apm.o apmd.o |
Rebooten onder 2.4.18, symlink van /usr/src/linux naar de sources van 2.4.18 zetten en dan compilen lukt wel. Daarna weer gereboot naar 2.4.19, symlink omgezet en de binary gedraait, geen probleem. Lijkt dus een 2.4.19 probleem.
hmm... die edit knop werkt vast nie
