Ik heb een leechserverke opgezet om mee te nemen naar een lan-party, dit is mijn proftpd.conf:
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use. It establishes a single server
# and a single anonymous login. It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName "Debian"
ServerType standalone
DeferWelcome off
ShowSymlinks on
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
AllowOverwrite on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayFirstChdir .message
LsDefaultOptions "-l"
DenyFilter \*.*/
# Uncomment this if you are using NIS or LDAP to retrieve passwords:
#PersistentPasswd off
# Port 21 is the standard FTP port.
Port 21
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 30
# Set the user and group that the server normally runs at.
User nobody
Group nogroup
# Normally, we want files to be overwriteable.
<Directory /*>
# Umask 022 is a good standard umask to prevent new files and dirs
# (second parm) from being group and world writable.
Umask 022 022
AllowOverwrite on
</Directory>
# A basic anonymous configuration, no upload directories.
# These lines are marked with ##proftpd.deb anon access## so that they
# can be recognized, and edited by postinst. You can remove them once
# you're sure you don't want to keep them around.
<Anonymous ~ftp>
User ftp
Group nogroup
# We want clients to be able to login with "anonymous" as well as "ftp"
UserAlias anonymous ftp
RequireValidShell off
# Limit the maximum number of anonymous logins
MaxClients 10
# We want 'welcome.msg' displayed at login, and '.message' displayed
# in each newly chdired directory.
# Limit WRITE everywhere in the anonymous chroot
<Directory *>
<Limit WRITE>
AllowAll
</Limit>
</Directory>
<Directory *>
<Limit DELE>
DenyAll
</Limit>
</Directory>
# Uncomment this if you're brave.
<Directory incoming>
Umask 022 022
<Limit READ WRITE>
DenyAll
</Limit>
<Limit STOR>
AllowAll
</Limit>
</Directory>
</Anonymous>
Ziet er iemand dingen die nog beter of veiliger kunnen? Ik zou namelijk niet graag ongewenst bezoek hebben op mijn server. ( Ik ga nog een firewall schrijven die alles blokkeert behalve ftp. )
ServerName "Debian"
DeferWelcome off
ShowSymlinks on
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
AllowOverwrite on
TimeoutStalled 600
TimeoutIdle 1200
DenyFilter \*.*/
Port 21
# (such as xinetd)
MaxInstances 30
User nobody
Group nogroup
<Directory /*>
Umask 022 022
AllowOverwrite on
</Directory>
<Anonymous ~ftp>
User ftp
Group nogroup
MaxClients 10
<Directory *>
<Limit WRITE>
AllowAll
</Limit>
</Directory>
<Directory *>
<Limit DELE>
DenyAll
</Limit>
</Directory>
Umask 022 022
<Limit READ WRITE>
DenyAll
</Limit>
<Limit STOR>
AllowAll
</Limit>
</Directory>
</Anonymous>
