oss driver moet je voor dokken
En ff oss drivers installed, werkt perfect, krijg goed geluid bij mijn filmpjes, jah, voor 20 minuten, dan is trial tijd om
Dit is de output met oss drivers:
demux_avi: input capabilities = 649
demux_avi: AVI_init failed (AVI_errno: 9)
system layer format 'MPEG' detected.
metronom: audio discontinuity #2, type is 0, disc_off 0
metronom: waiting for video_discontinuity #2
metronom: video discontinuity #2, type is 0, disc_off is 0
metronom: video vpts adjusted with prebuffer to 596108
video_decoder: using decoder >mpeg2dec<
using video decoder plugin 'mpeg2dec'
libmpeg2: frame size is 320 x 240
libmpeg2: frame size 320 x 240
metronom: audio vpts adjusted with prebuffer to 596169
audio_decoder: using audio decoder plugin 'mad'
video_decoder: new pts 12016
metronom: video discontinuity #3, type is 2, disc_off is 12016
metronom: waiting for audio discontinuity #3
metronom: audio discontinuity #3, type is 2, disc_off 12016
metronom: waiting for in_discontinuity update #3
metronom: video vpts adjusted to 596169
yuv2rgb: using 2*zoom optimized scale_line
audio_out: stream audio format is 32000 kHz sampling rate, 16 bits. mode is 8.
audio_oss_out: ao_open rate=32000, mode=8, dev=/dev/dsp
audio_oss_out: audio rate : 32000 requested, 32000 provided by device/sec
audio_oss_out : 2 channels output
audio_out: output sample rate 32000
audio_out: thread created
audio_out: inserting 3219 0-frames to fill a gap of 9056 pts
video_out: freeing frame backup
xine_stop
audio_oss_out: AO_CTRL_FLUSH_BUFFERS
audio_out: inserting 7118 0-frames to fill a gap of 20027 pts
audio_out: inserting 3897 0-frames to fill a gap of 10963 pts
audio_oss_out: AO_CTRL_PLAY_RESUME
xine_stop: stopping demuxer
demux_mpeg: demux thread finished (status: 1, buf:1b9)
xine_stop: stopped demuxer
xine_stop: done
xine_exit: shutdown audio
audio_out: stopping thread...
audio_out: thread stopped, closing driver
xine_exit: shutdown video
video_out: possible still frame (old)
libmpeg2: blasting out current frame on close
libmpeg2: blasting out backward reference frame on close
xine_exit: bye!
xine's profiler is unavailable.
