[C] ik raak variabelen zomaar kwijt :o
  • 57 views sinds 30-01-2008
Ziehier een simpele functie in mijn IRC botje die ik probeer te schrijven:
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
IrcUser *
irc_user_new_from_mask (IrcConnection *irc_connection,
                        gchar         *hostmask)
    IrcUser *irc_user;
    gchar *nickname = NULL, *hostname = NULL, *username = NULL;
    gint i = 0;
    g_return_val_if_fail(hostmask != NULL, NULL);
    /* parse the hostmask */
g_print("Mask: %s\n", hostmask);
    while (1) {
        if (hostmask[i] == '!' || hostmask[i] == '\0') {
            nickname = g_strndup(hostmask, i);
            if (hostmask[i] == '!')
                i++;
            if (hostmask[i] == '~')
                i++;
            hostmask = &hostmask[i];
g_print("Nickname found: %s\n", nickname);
            break;
        } else
            i++;
    i = 0;
    while (1) {
        if (hostmask[i] == '@' || hostmask[i] == '\0') {
            if (i != 0) {
                username = g_strndup(hostmask, i);
                if (hostmask[i] == '@')
                    i++;
g_print("Username found: %s\n", username);
            break;
        } else
            i++;
    i = 0;
    if (hostmask[i] != '\0')
        hostname = g_strdup(hostmask);
g_print("Hostname: %s\n", hostname);
    irc_user = irc_user_new_from_nick(irc_connection, nickname);
    if (irc_user->username)
        g_free(irc_user->username);
    irc_user->username = username;
    if (irc_user->hostname)
        g_free(irc_user->hostname);
    irc_user->hostname = hostname;
g_print("Nick: %s, user: %s, host: %s\n",
    nickname, username, hostname);
    return irc_user;
Hier is mijn output:
Mask: BBB!rbultje@csop.nixhelp.org
Nickname found: BBB
Mask: rbultje@csop.nixhelp.org
Username found: rbultje
Mask: csop.nixhelp.org
Hostname: csop.nixhelp.org
Name: BBB, User: (null), Host: (null)
Met andere woorden, ik raak de variabelen username en hostname kwijt (die worden weer NULL) tussen regel 45 en regel 54, terwijl ik er niets mee doe! De output bewijst dat voor regel 45 deze variabelen wel bestaan. Hoe kan dat? :/.
  • D2k
  • Laatst online: 31-08 10:19
D2k
hmmz???
ff nix zinnigs helaas
strange
heb je geheugen gealloceerd?
Doet iets met Cloud (MS/IBM)
  • whoami
  • Laatst online: 13:00
Al eens gedebugged?
Ik zie daar regeltjes staan g_free (username) ed, wat doen die precies?
https://fgheysels.github.io/
Gokker de gok irc_user->username en username wijzen naar het zelfde stuk geheugen wat je net vrij gegeven hebt..
whoami schreef op 05 augustus 2002 @ 20:23:
Al eens gedebugged?
g_free is ongeveer hetzelfde als free(). Evenzo is g_strdup() hetzelfde als strdup() (geheugen is dus gealloceerd). :/.
Waah! Ik zit net een kop koffie te pakken... :X.
Verwijderd schreef op 05 augustus 2002 @ 20:14:
PHP:
Dat is dus de output van een andere functie (die door irc_user_new_from_nick() wordt aangeroepen). |:(. 8)7.}:O.
/me voelt zich dom. :'(.
  • D2k
D2k
dat ben je ook >:)
