[REGEX] Domeinnaam
  • vinnux
Nu breien we een eind aan wat een domein is en welke regex daar goed voor is!
In rfc1034.txt staat duidelijk omschreven wat het is, bij deze dus :
3. DOMAIN NAME SPACE and RESOURCE RECORDS
3.1. Name space specifications and terminology
The domain name space is a tree structure. Each node and leaf on the
tree corresponds to a resource set (which may be empty). The domain
system makes no distinctions between the uses of the interior nodes and
leaves, and this memo uses the term "node" to refer to both.
Each node has a label, which is zero to 63 octets in length. Brother
nodes may not have the same label, although the same label can be used
for nodes which are not brothers. One label is reserved, and that is
the null (i.e., zero length) label used for the root.
The domain name of a node is the list of the labels on the path from the
node to the root of the tree. By convention, the labels that compose a
domain name are printed or read left to right, from the most specific
(lowest, farthest from the root) to the least specific (highest, closest
to the root).
Internally, programs that manipulate domain names should represent them
as sequences of labels, where each label is a length octet followed by
an octet string. Because all domain names end at the root, which has a
null string for a label, these internal representations can use a length
byte of zero to terminate a domain name.
By convention, domain names can be stored with arbitrary case, but
domain name comparisons for all present domain functions are done in a
case-insensitive manner, assuming an ASCII character set, and a high
order zero bit. This means that you are free to create a node with
label "A" or a node with label "a", but not both as brothers; you could
refer to either using "a" or "A". When you receive a domain name or
Mockapetris [Page 7]
RFC 1034 Domain Concepts and Facilities November 1987
label, you should preserve its case. The rationale for this choice is
that we may someday need to add full binary domain names for new
services; existing services would not be changed.
When a user needs to type a domain name, the length of each label is
omitted and the labels are separated by dots ("."). Since a complete
domain name ends with the root label, this leads to a printed form which
ends in a dot. We use this property to distinguish between:
- a character string which represents a complete domain name
(often called "absolute"). For example, "poneria.ISI.EDU."
- a character string that represents the starting labels of a
domain name which is incomplete, and should be completed by
local software using knowledge of the local domain (often
called "relative"). For example, "poneria" used in the
ISI.EDU domain.
Relative names are either taken relative to a well known origin, or to a
list of domains used as a search list. Relative names appear mostly at
the user interface, where their interpretation varies from
implementation to implementation, and in master files, where they are
relative to a single origin domain name. The most common interpretation
uses the root "." as either the single origin or as one of the members
of the search list, so a multi-label relative name is often one where
the trailing dot has been omitted to save typing.
To simplify implementations, the total number of octets that represent a
domain name (i.e., the sum of all label octets and label lengths) is
limited to 255.
A domain is identified by a domain name, and consists of that part of
the domain name space that is at or below the domain name which
specifies the domain. A domain is a subdomain of another domain if it
is contained within that domain. This relationship can be tested by
seeing if the subdomain's name ends with the containing domain's name.
For example, A.B.C.D is a subdomain of B.C.D, C.D, D, and " ".
for constructing domain names. The idea is that the name of any
existing object can be expressed as a domain name with minimal changes.
However, when assigning a domain name for an object, the prudent user
will select a name which satisfies both the rules of the domain system
and any existing rules for the object, whether these rules are published
or implied by existing programs.
For example, when naming a mail domain, the user should satisfy both the
rules of this memo and those in RFC-822. When creating a new host name,
the old rules for HOSTS.TXT should be followed. This avoids problems
when old software is converted to use domain names.
The following syntax will result in fewer problems with many
applications that use domain names (e.g., mail, TELNET).
<domain> ::= <subdomain> | " "
<subdomain> ::= <label> | <subdomain> "." <label>
<label> ::= <letter> [ [ <ldh-str> ] <let-dig> ]
<ldh-str> ::= <let-dig-hyp> | <let-dig-hyp> <ldh-str>
<let-dig-hyp> ::= <let-dig> | "-"
<let-dig> ::= <letter> | <digit>
<letter> ::= any one of the 52 alphabetic characters A through Z in
upper case and a through z in lower case
<digit> ::= any one of the ten digits 0 through 9
Note that while upper and lower case letters are allowed in domain
names, no significance is attached to the case. That is, two names with
the same spelling but different case are to be treated as if identical.
The labels must follow the rules for ARPANET host names. They must
start with a letter, end with a letter or digit, and have as interior
characters only letters, digits, and hyphen. There are also some
restrictions on the length. Labels must be 63 characters or less.
For example, the following strings identify hosts in the Internet:
A.ISI.EDU XX.LCS.MIT.EDU SRI-NIC.ARPA
te vinden op : http://www.ietf.org/rfc/rfc1034.txt
Als iemand hier nou een mooie regex van maakt dan zijn we eruit !
  • Grum
[0-9]
<letter> ::= any one of the 52 alphabetic characters A through Z in upper case and a through z in lower case
[a-zA-Z]
([a-zA-Z]|[0-9])
(([a-zA-Z]|[0-9])|-)
(([a-zA-Z]|[0-9])|-){1,}
[a-zA-Z](((([a-zA-Z]|[0-9])|-){1,})?([a-zA-Z\|[0-9]))?
[a-zA-Z](((([a-zA-Z]|[0-9])|-){1,})?([a-zA-Z\|[0-9])(\.([a-zA-Z](((([a-zA-Z]|[0-9])|-){1,})?([a-zA-Z\|[0-9]))?)){0,}
Fijn huh ?
Dit vereenvoudigen:
Label: [a-z]([a-z\d-]*[a-z\d])?
domain: [a-z]([a-z\d-]*[a-z\d])?(\.[a-z]([a-z\d-]*[a-z\d])?)*
en wonderbaarlijk komt de valid site: www.9292ov.nl er niet door.
Goed huh ? die RFC's >:)
[ Voor 0% gewijzigd door Grum op 02-08-2002 12:40 . Reden: Klein foutje ]
  • vinnux
Nee mogen niet beginnen met cijfers he!
Ja das wat minder natuurlijk. Kunnen ze zich niet gewoon eens aan de RFC houden, stelltje minkuikels. Ik ga ze een mailtje sturen dat ze volgens de RFC een naam hebben die niet mag !!
Zal kijken naar een uptp dater RFC, maar inderdaad, waarom zou je RFC's maken als niemand zich er aan houd ?
Je bent alleen vergeten dat een leaf maar 63 lang mag zijn en de totale lengte maar 255. :)Nou is dat ook wat moeijlijk in te bouwen in een regex, die 63 zou nog kunnen, maar die 255.
  • vargo
  • Laatst online: 01-09 14:44
Wie bepaalt dan wat in de praktijk aan domeinnamen wereldwijd wordt toegestaan?
SIDN verwijst ook vrolijk naar RFC 1591, maar zij hebben toch bovenstaande domeinnaam toegestaan.
  • Grum
Voor ons internet is het denk ik:
<letter> ::= [a-zA-Z]
<digit> ::= [0-9]
<letter-digit> ::= <letter> | <digit>
<letter-digit-hyphen> ::= <letter-digit> | "-"
<letter-digit-hyphen-string> ::= <letter-digit-hyphen> | <letter-digit-hyphen-string> <letter-digit-hyphen>
<label> ::= <letter-digit> [ [ <letter-digit-hyphen-string> ] <letter-digit> ]
<subdomain> ::= <label> "." | <subdomain> <label> "."
<top-level-domain> ::= <letter> <letter> [ <letter> [ <letter> ] ]
<second-level-domain> ::= <letter> <letter> [ <letter> ] "."
<domain> ::= [ <subdomain> ] [ <second-level-domain> ] <top-level-domain>
ofzo :P
[ Voor 0% gewijzigd door Grum op 02-08-2002 13:27 . Reden: Yeah [code] htmlentitied ]
  • vinnux
en het - dan ? :P
Ik kan niet lezen !
Ik ben er een weekje vantussen, cu.
