Ok sorry voor de titel van deze post
Ik wil gebruik maken van een template.. alleen dan krijg ik deze fout??:
Error Type:
Server.MapPath(), ASP 0174 (0x80004005)
An invalid '/' or '\' was found in the Path parameter for the MapPath method.
/afmp.nl/functions/asptemplate.asp, line 135
de volgende code die daaraan hangt:
Main.asp:
asptemplate.asp
Weet iemand wat ik fout doe???
tnx in advance
Error Type:
Main.asp:
| 'main template file t.SetTemplateFile "/template/main.html" |
asptemplate.asp
| public sub SetTemplateFile(inFileName)
if len(inFileName) > 0 then
dim FSO, oFile
set FSO = createobject("Scripting.FileSystemObject")
if FSO.FileExists(server.mappath(p_templates_dir & inFileName)) then
set oFile = FSO.OpenTextFile(server.mappath(p_templates_dir & inFileName))
p_template = oFile.ReadAll
oFile.Close
set oFile = Nothing
else
response.write "<b>ASPTemplate Error: File [" & inFileName & "] does not exists!</b><br>"
end if
set FSO = nothing
else
response.write "<b>ASPTemplate Error: SetTemplateFile missing filename.</b><br>"
end if
end sub |
tnx in advance
