ja, ik blijf een beetje doorzeuren...
ik ben iig niet de enige met dit probleem. op het tvtool forum wordt ook melding gemaakt van vlekken die na een seconde of tien op het tv-scherm verschijnen, maar een oplossing wordt nooit gegeven
So far so good... i've got colour but... after 15 to 20 seconds i can se two spots starting to grow on the screen...
One on each side of the screen (one blue and one yellow)...
I've tried to change to another capacitor with same size but its the same behaivor as before.
I've been trying TV-tool 5.5 and 6.0 beta with the same results...
Can anyone give me a solution to get rid of those spots?
I've got a TVOut problem. My TV displays strange distorted color areas in the left and in the right part of the TV screen. It looks like a magnetic interference, but I don't know what it really is.
I've noticed two other people described the same or similar problem (Bjarne Lindqvist and GoobCow).
The interference appears after I connect the video cable to the TV (doesn't matter which input/output - Composite or SVideo works all the same). The intereference is visible the best, when a single color window is displayed on the TV. It slowly disappears when I disconnect the video cable from the TV.
I still can watch a movie, because the interference is not visible so much, when there's something going on the screen. However, I'm worried about my TV set; I'd hate to damage it.
I've got GeForce2 MX 400 and a 50Hz Pal/NTSC TV set; and I've tried all sorts of setting, including TwinView and TVTool.
Please, help me identify what the problem really is and remove it.
Have you ever tried disconnecting all cables except that coming from the TV-Out of your card?
CU Endurance
I sometimes have strange colors to the left and to the right in the picture. It's really easy to see if i display a white picture. If i turn off/restart the comp its gone.
There are no speakers or other magnetic things in the area of the tv but it looks very much like magnetic interference.
I have a Asus card with the CX25871 chip.
I have that same problem on my TV..I was very scared at first (its a quite expensive TV) but every time i turn off and then on again, the spots are gone, and they slowly start to come back as TVtool runs.
I also have the strange color-changed areas on both left and right side of the TV. It looks much like magnetic interference, but there are no devices around that could cause it.
I've tried all combinations of cable connection: VHS/SVHS - VHS/SVHS/SCART. It's the same all the time.
I'm kind of worried thet it might damage the TV. If anybody knows what the reason is and/or how to remove it, I'd love you to let me know.
Hallo, ich hab ein komisches Problem.
TV Tool laueft ansich einwandfrei aber es gibt auf dem tv bild staendig diagonale blaue streifen die langsam ueber den bildschirm wandern. ich konnte es nicht austellen, liegt es vielleicht am kabel?
Hi!
Ich benutze eine LEADTEK WinFast A250 TD GeForce 4 TI 4200. Wenn ich jetzt über das TV Tool 6.5 die Ausgabe auf dem Fernseher aktivere bekomme ich ein super Bild, aber nach ca 5-10 Sekunden kommt ein komisches Flimmern auf dem Monitor. Das Bild auf dem TV läuft aber ganz normal weiter. Wenn ich dann zurück auf den Monitor schalte hab ich auch da wieder ein normales Bild. Eigentlich ist es ja wurscht, aber mich stört es trotzdem ein bisschen.
Hat einer Rat?
Danke!
hallo!
das ist so, wenn du "dual view" eingeschaltet hast, dann reduziert der monitor seine wiederholfrequenz auf mörderische 31khz oder so, schalt das mal aus, dann ist zwar auch der monitor aus, während die tv-ausgabe läuft, aber du schonst deine augen!
mfg, pir187
