Een heleboel meldingen
  • 69 views sinds 30-01-2008
Ik krijg de volgende meldingen 1 op de 3 keer te zien als ik iets open oid.
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /mnt/atlas/web/react/got/react/global/non-www/classes/user.class.inc.php on line 449
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /mnt/atlas/web/react/got/react/global/non-www/classes/user.class.inc.php on line 459
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /mnt/atlas/web/react/got/react/global/non-www/classes/user.class.inc.php on line 513
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /mnt/atlas/web/react/got/react/global/non-www/classes/user.class.inc.php on line 525
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /mnt/atlas/web/react/got/react/global/non-www/classes/user.class.inc.php on line 537
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in /mnt/atlas/web/react/got/react/global/non-www/classes/topic.class.inc.php on line 318
Ik weet niet hoe of wat maar het is nogal wat.
  • Joror
  • Laatst online: 11-03-2017
Joror
the eternal lurker
Klopt, error_reporting was in de update even aangezet, heb hem nu weer uit gezet.
nada aka zilch, formerly known as zip
  • Joror
Joror
the eternal lurker
Alhoewel hij soms mij koppig negeert, dus zeg vooral als je ze nogmaals tegenkomt.
Dan zijn dat nogal wat errors niet? :D
  • Joror
Joror
the eternal lurker
Zelfde warning (niet error) meerdere keren gemeld :)
  • D2k
  • Laatst online: 31-08 10:19
D2k
dit lijkt wel afgehandeld. volgende melding svp met verwijzing naar hier
Doet iets met Cloud (MS/IBM)
