[RC5-pproxy] buffers omhoog
Ik heb thuis een perproxy en nou wil ik mijn in buffer wat hoger maar dat wil perprox blijkbaar niet want die wilt niet hoger dan 1000
de ini
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
[KeyServer]
ipaddress=66.164.240.119
port=5000
connectperiod=600
connectivity=normal
;bindip=                ; IP to talk out to keyserver from
;uuehttpmode=0
; 0=normal,1=uue,2=http,3=http+uue
; 4=socks4,5=socks5,6=genproxy,7=genproxy+uue
;httpproxy=wwwproxy.corporation.com
;httpport=8080
;httpid=
[ports]
;listenaddress=          ; IP to accept clients on
port=2064
;port2=23                ; must be root for ports < 1000
;port3=80
testport=3064
timeout=30
[console]
logfileconsole=
logfileconsolerotation=daily
consoleverbosity="general stats keyblock server client buffers timestamp attention errlow errsevere"
timestampflags=130
[rc564]
logfilekeyblock=pproxyrc5
logfilekeyblockrotation=daily
minkeysready=10000
maxkeysready=10001
minkeysdone=30000
maxkeysdone=30001
[misc]
proxymessage="rc5des Personal Proxy!"
pidfile=rc5desproxy.pid
statusperiod=30
periodicperiod=120
;logfilecompressor=logcompressor.sh
[ignoredip]
[allowedip]
[desII]
contestclosed=1
[csc]
contestclosed=1
de console
[2002-07-27 11:05:44] distributed.net Personal Proxy (build 319)
[2002-07-27 11:05:44] Visit http://www.distributed.net/ for details.
[2002-07-27 11:05:44] Proxy starting up.
[2002-07-27 11:05:44] Verbosity set to: general stats keyblock server cl
fers timestamp attention errlow errsevere (3519)
[2002-07-27 11:05:44] rc564-in: limits adjusted to min 49, max 1000
[2002-07-27 11:05:44] desII-in: limits adjusted to min 20, max 50
[2002-07-27 11:05:44] csc-in: limits adjusted to min 20, max 50
[2002-07-27 11:05:44] Notice: connectivity mode is normal
[2002-07-27 11:05:44] Notice: Loaded 0 ignoredip addresses from ini file
[2002-07-27 11:05:44] Notice: Loaded 0 allowedip addresses from ini file
[2002-07-27 11:05:45] Notice: Primary listener bound to (all devices):20
[2002-07-27 11:05:45] Notice: Test listener bound to (all devices):3064
[2002-07-27 11:05:45] Status: Uplink needed... (thresholds exceeded)
[2002-07-27 11:05:45] Status: Creating uplink (outgoing server) connecti
[2002-07-27 11:05:45] rc564 r=1009/1000, d=7/30001, 0.0 Mkeys/sec, tot=0
[2002-07-27 11:05:45] ogr r=0/50, d=0/20, 0.0 Mnodes/sec, tot=0 stubs
[2002-07-27 11:05:45] Status: Uptime: 0.00:00:01, 2 listeners, 0 uplinks
[2002-07-27 11:05:45] Status: 0 active clients (peak: 0, mean: 0.00)
[2002-07-27 11:05:46] Uplink: [1] connection to 66.164.240.119 changed s
                    from 0 (ESTNONE) to 1 (ESTCONNWAIT)
                    from 1 (ESTCONNWAIT) to 50 (ESTREADY)
staat er iets niet goed laat het a.u.b. weten
Alvast bedankt,
  • Chaos
Zoek eens op expertmode in de readme. :)
  • stappel_
  • Laatst online: 30-08 17:27
lees het readme bestand eens.
(er zit een optie in voor experts, maar dan moet je wel eerste een exame als expert afleggen en het bestand doorlezen >:) )
Ubero: #2, Euler: #1, GOT: #1, Des: #1, Zeta: #1, Eon: #3, OGR-24: #3, OGR-25: #7,
LM: #7, AP: #5, DF: #19, D2OL: #37, SOB: #50, TSC: #63, RC5: #96
This automatic behavior is recommended for almost all people. The
proxy will adjust its buffer so there's always enough blocks for a
couple of days. People who use the proxies buffers to sneakernet need
be to able to download large numbers of blocks. For this purpose a
ini-setting [rc564]/expertmode and [desII]/expertmode is added. If
this option is set to 1 (one), the proxy will obey your settings of
maxkeysready and minkeysready.
dit stukje bedoelen jullie :P
dat staat nu aan maar nog steeds krijg ik niet meer dan 1k binnen en ja ik heb ook al langer dan een half uur gewacht. :D
  • Chaos
In de config die je minder dan een half uur geleden postte staat nog niets. Post je config dan eens zoals die er nu uitziet.
te vroeg gezuurt het werkt al.
:o
vergeten proxy te herstarten
  • stappel_
Hmmm dit lijkt op een 6min als eindcijfer. Moeten we nog even over nadenken.
goh toch nog een 6min best goed eigenlijk :P
