Server reboot automatisch en hangt?
Voor een vriend van me...
zijn server (raq4) reboot na +/- 2 uur (na de reinstall) en dan hangt ie bij "booting"
kijk eens naar het volgende (commando door mij gegeven!)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
[root /etc]# /etc/rc.d/rc.sysinit
Activating swap partitions swapon: /dev/hda6: Device or resource busy
Setting hostname localhost
Checking root filesystem
e2fsck 1.18, 11-Nov-1999 for EXT2 FS 0.5b, 95/08/09
/dev/hda1 is mounted.
WARNING!!!  Running e2fsck on a mounted filesystem may cause
SEVERE filesystem damage.
Do you really want to continue (y/n)? no
check aborted.
ok
mount: proc already mounted
Remounting root filesystem in read-write mode
Finding module dependencies
Starting up RAID devices...
-- System configuration........... /etc/raidtab
-- System status.................. /proc/mdstat
-- RAID status.................... OK
Checking filesystems
/dev/hda3 was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Block bitmap differences:  -33067 -33068 -33069 -33070 -33073 -33074 -33075 -33076 -33077 -33078 -33080 -33081 -33082 -33083 -33084 -33085 -33086 -33090 -33091 -33092 -33093 -33094 -33095 -33096
Fix? yes
Free blocks count wrong for group #4 (7873, counted=7897).
Fix? yes
Free blocks count wrong (189839, counted=189863).
Fix? yes
/dev/hda3: ***** FILE SYSTEM WAS MODIFIED *****
/dev/hda3: 276/51376 files (12.0% non-contiguous), 15265/205128 blocks
/dev/hda4 was not cleanly unmounted, check forced.
/dev/hda4: 2807/9488384 files (0.4% non-contiguous), 1963124/37947168 blocks
ok
Mounting local filesystems mount: /dev/hda3 already mounted or /var busy
mount: /dev/hda4 already mounted or /home busy
mount: none already mounted or /dev/pts busy
mount: according to mtab, none is mounted on /proc
Setting clock  (utc): Thu Jul 25 00:50:26 PDT 2002 Thu Jul 25 00:50:26 PDT 2002
Enabling swap space
wat zou dit kunnen zijn? defecte schijf? defect geheugen? iemand een idee?
/me *edit*
dit stond er overigens al VOORDAT ik dit commando gaf...
[root /etc]# tail -f /var/log/messages
Jul 25 11:51:06 lease150 syslogd 1.3-3: restart.
Jul 25 00:00:05 lease150 init: Switching to runlevel: 0
Jul 25 00:00:08 lease150 exiting on signal 15
Jul 25 00:37:26 localhost syslogd 1.3-3: restart.
Ok, eerst even de magische woorden. Wie, wat, waar, hoe?
Oftewel: Wat voor distro, nieuwe hardware, oude hardware, wat voor soort server, wat voor reinstall (eroverheen / alles schoon).
De meldingen van fsck komen doordat de server hing. Dus hoeft het niet perse de hdd te zijn.
Nogmaals, please more info.
nou...
ik heb toch info gegeven:
raq4...
dat is dus een RH6.2 flavoured (licht aangepast) OS...
nieuwe server...
