[OC] Hoogste 3Dmark score ooit
  • 101 views sinds 30-01-2008
  • jazz
  • Laatst online: 23-08 01:58
PPL... Check dis out!! :O (van [url="http://www.vr-zone.com"]VR-Zone[/url]) ([url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/"]originele link[/url])
Introduction
Prior to use the system for 3DMark2001SE benchmarking session there are lots of preparation involved before you can get some real satisfying results. First you will need to select the hardware you are going to use for the setup and choices must be good so they can yield the highest performance. For motherboard, i have selected ASUS P4T533-C based on i850E board since the RDRAM motherboard will give the best 3DMark score. The choice of graphics card is important too and i have selected using MSI GeForce4 Ti4600 for benchmarking. I have modified the motherboard and graphics card to increase the voltages for better overclockability and also employ LN2 cooling to the CPU and GPU to push their frequencies much higher than default.
Modifying ASUS P4T533-C
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/vcore.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/vcore-m.jpg[/url]
VCore Mod
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/vrimm.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/vrimm-m.jpg[/url]
VRIMM Mod
Vcore-modification is quite easy to accomplish. Beside the Socket 478-base we can find the R3217 resistor which is replaced with 56kohm adjustable resistor. When the resistors value is decreased the processors operating voltage is increased.
Luckily also RDRAM operating voltage is easily increased with help of little modification. Near the ATX-connector we can find the R2300 resistor which is replaced with 1kohm adjustable resistor when the value is decreased the memory voltage increased.
Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/turbopll.jpg
The main purpose of using a Turbo PLL is to overcome the FSB limitation of the motherboard especially that i850E boards usually has a maximum of 156Mhz FSB.
For the TurboPLL connection you must get external clock circuit and 14,3MHz crystal. This is best done by sawing up those apart from old broken motherboard. It is worthwhile to get such clock circuit which you can get datasheets from the internet. From the external clock circuit you must know the following connectors: 3,3V operating voltage, GND and 14,3MHz output. When above-mentioned factors have been sorted out, you must remove the 14,3MHz reference crystal from the Asus P4T533-C motherboard. It is worthwhile to connect base so you can easily change different kind of crystals. After this you have to disconnect resistors R143 and R144 near the clock circuit. The outer clock circuit feeds 14,3MHz reference frequency to the motherboard. Wires (in the picture red and yellow) are connecter into the disconnected resistors outer pins (when you look from the clock circuit).
Blue wires feed the operating voltage +3,3V and GND to the external clock circuit. Motherboards 14,3MHz crystal was replaced by 16,93MHz crystal. With fast calculations we get the motherboards smallest possible channel frequency of 118,39MHz and the largest possible channel frequency of 177,58MHz.
(16,93MHz / 14,3MHz) * 100MHz = 118,39MHz
With different kind of crystals you get different kind of channel speeds of course. For example 20MHz crystal the 150MHz channel speed is 209MHz.
Modifying MSI GeForce4 Ti4600
Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/1.jpg
First I did some testing using standard configuration: A P4 2.4Ghz, EPoX EP-4T2A3 motherboard and Win 98 OS. I tested all possible settings with RivaTuner software. After inital tests, it was time to start overclocking with Pentium 4 2.4Ghz, Windows XP, ASUS P4T533-C and Microstar GF4 Ti4600 motherboard. After testing a few versions of drivers, i have discovered that Detonator 29.42 works the best. I have tested graphics card maximum core/mem clock frequencies with standard cooling and voltage which is found to be 325/730MHz.
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/2.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/2-m.jpg[/url]
RAM Sinks
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/3.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/3-m.jpg[/url]
VMem Mod
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/4.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/4-m.jpg[/url]
VGPU Mod
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/8.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/8-m.jpg[/url]
Final
I have attached some RAM sinks to the memory and apply the VMem mod ( by adding a 1Kohm resistor to increase the voltage from 2.80V to 2.95V. After applying the VMem mod, i am able to overclock the memory from 735Mhz to 775-777MHz which is an improvement of 40Mhz. Although i have changed the default cooler on the card to a better heatsink but it didn't really help much so i have to resort to LN2 cooling. I have applied the VGPU mod by adding a 5KOhm resistor to increase the voltage from 1.66V to 1.93V.
Conducting The Tests
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/9.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/9-m.jpg[/url]
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/10.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/10-m.jpg[/url]
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/6.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/6-m.jpg[/url]
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/7.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/7-m.jpg[/url]
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/5.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/5-m.jpg[/url]
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/11.jpg"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/11-m.jpg[/url]
During the initial testing, the core frequency limitation is at 378Mhz but after some time, the GPU is completely frozen on both sides and i could even complete the 3DMark tests at 400Mhz core frequency. Not only i have applied LN2 cooling to the graphics card, i have done the same thing to the motherboard too. From the previous testing, I knew that Pentium 4 at 3860MHz (24x160.85MHz) was solid as a rock. For the first test, i have set the core/mem frequency to 395/775MHz and got the initial result of 16636 3dmarks. I have put in more Liquid Nitrogen and continue to run 3DMark tests again and got a score of 17100 3dmarks.
[url="http://www.vr-zone.com/guides/Madonion/3DMark2001SE/12.gif"]Afbeeldingslocatie: http://www.vr-zone.com/guides/Madonion/3DMark2001SE/12-m.gif[/url]
For the final showdown for the highest 3DMark score, i have applied LN2 cooling to the graphics memory even and increased the VMem to 3V but there was no improvement from doing so. I also raised the GPU voltage to 1.98V and the 3DMark tests went through at 409MHz core frequency. At the same time I have further increase the CPU frequency to 3917MHz (24x163.20MHz) and i have set a record of 17230 3dmarks! You can compare your results with mine [url="http://service.madonion.com/compare?2k1=3990219"]here[/url]. It will be interesting to benchmark with a RADEON 9700 too since it is about 20% faster than GeForce4 Ti4600 so a score of 20,000 3dmarks and above will be attainable.
  • Xtuv
  • Laatst online: 02:03
Tsja, het kan altijd beter.. :P
mijn god, ik heb 2850 ...... naja binnen kort ati radeon 8500 duzzz :D
  • jazz
en dat doet ie met een P4 2.4 GHz he :P met een 2.53 GHz komt ie ws nog hoger.. en how about een 2.53 GHz icm een Radeon 9700... :o
3dmarkje van 21000? o m f g ...
hij heeft nu een OC van ruim 163 procent...
  • FMS
FMS
duron_dude heeft weer extra concurrentie ;)
  • Yuri de Jager
  • Laatst online: 03-09 17:15
Yuri de Jager
Assume good intent
Ja, baas boven baas... Maar, wat ie zelf al zegt, over een maand kan je dat gewoon met de nieuwste videokaart halen :-/ En begin 2003 haalt de helft van de tweakers dit ook....
[/ouwelullenmodus]
KEWL! Dit is het echte tweaken :9~ :P
5950@CTR3,85-4,875GHz|64GB 3600C14|32TB HDD|2.2TB SSD|RTX2070-XC-ULTRA|Alienware M17xR2 FTW!|i7 920XM(ES)|16GB DDR1333|750GB 7.2K HDD|256GB Crucial M4 SSD|3DV:P7671
Op woensdag 24 juli 2002 18:14 schreef FMS het volgende:
Men zou dringend JC (aka durondude) eens LN2 in zijn handen moeten stoppen ;)
  • jazz
voor vergelijking: [topic=508445]
oke hij kwam procentueel hoger :P
Maar deze OC is stabiel, en die van durondude niet..
durondude:
Afbeeldingslocatie: http://users.pandora.be/JCviggen/WCPUIDpro3.JPG
Heel mooi allemaal, alleen een klein puntje; kijk eens naar zen 3dmark score, daaronder staat: the test was not run using default blablabla, misschien hebbie em ook nog een stukje lager gezet qua resolutie enzo...
  • FMS
FMS
Op woensdag 24 juli 2002 19:09 schreef Lomu het volgende:
nee hoor, alles klopt.
vergelijk het maar: [url="http://service.madonion.com/compare?2k1=3990219"]http://service.madonion.com/compare?2k1=3990219[/url]
Op woensdag 24 juli 2002 18:33 schreef overklokje het volgende:
durondude:
[url="http://users.pandora.be/JCviggen/WCPUIDpro3.JPG"][afbeelding][/url]
ja, stabiel tot de LN2 op is ja |:( Die van DuronDude loopt iets lager wel stabiel en continu.
Is omdat hij alleen de games heeft gedraaid, het zijn ook die die voor de punten zorgen, die andere tests veranderen daar nix aan...
  • jfeelders
  • Laatst online: 10-09 06:45
jfeelders
Kwaliteit voor kwantiteit...
Dan moet je deze ook eens zien:
[url="http://www.sysopt.com/cgi-bin/overc/readfull.cgi?record=12074"]http://www.sysopt.com/cgi-bin/overc/readfull.cgi?record=12074[/url]: 18920 in 3DMark2001
En als we dan toch bij sysopt zitten dan kan ik ook wel ff het hele lijstje geven:
[url="http://www.sysopt.com/cgi-bin/database.cgi?go=1&p4=Pentium+4&manufac=All&sort=O.C.+CPU+Speed&rperpage=10&theview=standard&k="]http://www.sysopt.com/cgi-bin/database.cgi?go=1&p4=Pentium+4&manufac=All&sort=O.C.+CPU+Speed&rperpage=10&theview=standard&k=[/url]. Let vooral ff op plaats 7! :P
Op woensdag 24 juli 2002 22:59 schreef jfeelders het volgende:
lekker fak die lijst zie nr 1 een wilmete 2,2ghz op 5,2 tuurlijk met een 320 mhz bus dat geloven we allemaal ennne een i845DX chipzet :D
  • SmokeyTheBandit
  • Laatst online: 17-06 10:20
SmokeyTheBandit
DOCer met Pensioen
Op woensdag 24 juli 2002 23:14 schreef gpvelzen het volgende:
lekker fak die lijst zie nr 1 een wilmete 2,2ghz op 5,1 tuurlijk met een 320 mhz bus dat geloven we allemaal
LOL idd :P
Dis wel een leuk pctje maar totaal niet voor normaal gebruik.
Turn it off and on again.
  • Daan
  • Laatst online: 08-09 22:52
Waarom staat er op die screenshot "The benchmark was not run using default settings :?
  • SmokeyTheBandit
SmokeyTheBandit
DOCer met Pensioen
Op woensdag 24 juli 2002 23:23 schreef Phreak het volgende:
Hmmmm
You got a point there :P !
jah, maar eigenlijk gaat het gewoon lekker om het tweaken :)
kijk naar mijn vorig bericht...
  • Barreljan
  • Laatst online: 04-09 16:52
Barreljan
...Zoom-Zoom...
en wat als die gochem nou zo'n nieuwe ATI 9700 erin knalt???
hij zegt het zelf al wel maar ik ben eeeerrrgg benieuwd! over de 21000.... tssss
best wel :9~ die bench... ik heb net de 2100 :P
Time Attacker met de Mazda 323F 2.5 V6 J-spec | PV output
  • porn*
  • Laatst online: 22:57
porn*
...take on the world!
En toch blijf ik het een beetje nep vinden... kan me wel voorstellen dat het een kick is om een zo hoog mogelijke score te halen, maar een LN2 systeem is nou niet echt wat je dagelijks gebruikt.
Vind het veel spannender als hij hem een beetje in de buurt van die score kan krijgen met koeling die lang mee gaat (WC+TEC oid), en niet binnen een paar uur verdampt is :P
Bnet pindle#2913
durondude:
die van duron dude heeft 800mhz minder :+ als die een 2.4 in de handen krijgt >:)
Voodoo_man schreef op 25 juli 2002 @ 10:22:
Cker! Binnenkort mag NV30 die ati wegknallen, en ik ben zeer benieuwd als hij NV30 erin knalt W00t raad dan zijn score.
  • Dextourius
  • Laatst online: 14-03-2025
Verwijderd schreef op 24 juli 2002 @ 19:09:
mja, bij mij staat dat ook terwijl ik alles gewoon default heb enzo... ik heb 3dmark al een paar keer opnieuw geinstalleerd maar hij blijft maar komen.... (en ik doe gewoon al die benchmarks he)
http://service.madonion.com/compare?2k1=4768218
hmm, ik zie dat er bij mijn FSB 0 staat? :?
Hey Corc, versene borc olmaz Maykil bendede yok!
Beetje oud topic schoppen :P
  • ReseT
Phreak schreef op 24 juli 2002 @ 23:23:
Dat is normaal, want hoe ik ook klik op het 'default' knopje van 3dmark2k2SE, aan het einde staat er gewoon "The benchmark was not run using default settings". Ligt denk ik gewoon aan 3dmark2k2SE.
ID7T GTX. WP: PUZ-SWM60VAA+ERST30F-VM2EE (cylinder unit)
  • Brazza
  • Laatst online: 14-08 00:48
Brazza
Byte me!
OMG , wat een gast. Mooie dampen in zijn pc btw..
  • Cassius
Cassius
Moogles!
Jezus, 3DMark2001 is toch al enorm onnauwkeurig ondertussen ??? Ik dacht dat de makers zeiden dat het proggie over zijn nek ging boven de 15000 ... Nou, daar zijn we al lang overheen :D
De meeste mensen deugen!
wat is dat voor een klein printje met die draadjes??
loop dat systeem op http://www.sysopt.com/cgi...readfull.cgi?record=12074 op 5.2 Ghz.. weetje hoeveel.. :?
Daar hadden ze een ati 9700 pro op moeten zetten nou dan was er wel een andere score komen te staan :)
  • Unagi
  • Laatst online: 08-09 22:37
Unagi
Always aware...
Verwijderd schreef op 17 oktober 2002 @ 14:39:
ze zeggen n turbo pll, maar is volgens mij n stukje van n ander mobo, ennuh t plaatje ziet r ook erg gephotoshopped uit
  • Unagi
Unagi
Always aware...
dubbelpost |:(
  • Rick2001
  • Laatst online: 09-08 01:10
Rick2001
9950X delidded en direct die
Dat is inderdaad een turbo pll en is absoluut geen fotosoep.
Ze hebben gewoon een stuk print met het pll ic van een oud mainboard genomen en hieraan de draden voor de spanning, in en uitgangen aangesloten.
Er kan natuurlijk ook 'geknutselt' worden met een experimenteer print, maar kost natuurlijk veel meer moeite.
MESHIFY 2XL - MSI X670E CARBON - 9950X - 32GB DDR5 LEXAR 6400 - RX 9070 - GIGABYTE M32UC 4K 160HZ - ALPHACOOL UT60 420 & 360 & 1080 - LAING DDC1+ - TECHN CPU - CORSAIR AX850 - 3x9100PRO 4TB - 2x850PRO 2TB - U.2 7.68TB + OPTANE P5800X + KINGSTON G5 8TB
  • Solid Seal
  • Laatst online: 26-08 15:29
Solid Seal
Drones, 3D printen
ik vind die score verdacht hoog... het zal best wel waar zijn... ik bedoel ik wil ook wel eens weten hoeveel info hij op z'n HD heeft staan....
Ik bedoel als je HD alleen Windows en 3dmark bevat is je score altijd hoger dan dat je hele HD bijna vol is...
In dit geval is die persoon dus enkelt bezig met het tweaken van zijn compu en videokaart......
www.dronepilotennederland.nl
  • 418O2
418O2
u mad?
ja d'oh het is een wereldrecordpoging om zo hoog mogelijk te komen, dan ga je toch ALLES dat je record in de weg kan staan uit diezelfde weg ruimen ?
  • Termy
  • Laatst online: 00:38
Termy
valt er nog wat te fragge?
ut kan aan mij liggen maar ik zag laatst toch echt een score van 21000 of zo? waarom is iedereen zo onder de indruk van deze score? leuk voor z'n LN2 maar ik zou het knapper hebben gevonden met minder drastische middelen.
[qoute]
[/qoute]
deze score was ook al in juli gehaald!!!
  • Demo
  • Laatst online: 10-09 13:14
Demo
Probleemschietende Tovenaar
Solid Seal schreef op 17 oktober 2002 @ 22:36:
Ongetwijfeld...
Maar snelheidsrecords met een auto doe je toch ook niet in een woonwijk met een aanhanger achter de auto?
Unix doesn't prevent a user from doing stupid things, because that would necessarily prevent them from doing brilliant things.
while true ; do echo -n "bla" ; sleep 1 ; done
  • Fed-Ex
  • Laatst online: 15-08 12:29
Fed-Ex
Hakuna Matata
jah die scores worden natuurlijk steeds beter...... ik vin die scores niet super ..... 3D mark 2001 ... :S vid kaart. proc. etc allemaal uit 2002 natuurlijk liggen die scores hoog, die 3dmark is voornamelijk gemaakt voor videokaarten die toen super waren enzo ik ben niet onder de indruk van die scores en iedereen ik haal met 3dmakr hoog en UT2003 is bagger... jah duh ut2003 is gebasseerd op de videokaarten en computers van NU 3dmark van 1/2 jaar geleden.
Soms zit het mee, Soms zit het tegen.
  • Demo
Demo
Fed-Ex schreef op 18 oktober 2002 @ 13:27:
En nou in het Nederlands... :?
oud topic
  • gangsterjoey
  • Laatst online: 29-11-2021
|| Specs ||
We don't see the things as they are, but as we see them!
  • blunt
  • Laatst online: 25-06-2023
jazz schreef op 24 juli 2002 @ 18:13:
als je die 2,4 Ghz tot het uiterste overclocked dan komt 'ie hoger dan een 2,53 Ghz, dat komt omdat de 2,4 op 400Mhz FSB loopt en de 2,53 Oop 533 FSB
je kunt beter over je fiets lullen, dan over je lul fietsen :X
  • robbert
  • Laatst online: 21:45
Ik begrijp er niks van :? :?
  • Optical
  • Laatst online: 02-06-2025
Kijk hier :
http://www.muropaketti.com/artikkelit/cooling/r300_ln2/
zie je hoe ze het bij 'Team Finland' hebben gedaan ;
mn fins is niet zo best gelukkig staat er een Engelse summary bij :P
If at first you don't succeed, cheat. Repeat until caught. Then lie .
  • AtomicShockwave
  • Laatst online: 20:59
AtomicShockwave
Hadde maar een vak moette lere
maar wat is nou et absolute record?
AtomicShockwave schreef op 21 oktober 2002 @ 00:01:
Waarom wordt er doorgelult in zo'n oud topic. En wie kickt er zo'n topic?
Maar het absolute record veranderd iedere keer, check eens bij madonion...
  • sleeping_hollow
sleeping_hollow
We want your soul.
wow, das een hoege score!. Daar kanik (nog) niet tegenop.
You are free to do as we tell you to
Dus, het bereiken van lage temperaturen is hier de beslissende factor? Dan zou ik willen voorstellen het moederbord met grafische kaart voor de volgende test in een baan om de aarde te brengen, waar zoals bekend mag worden verondersteld, de helft van de tijd ijzige koude heerst.
  • Macros
  • Laatst online: 24-08 21:59
Macros
I'm watching...
Verwijderd schreef op 21 oktober 2002 @ 12:50:
En straling die je computer om zeep helpt.
"Beauty is the ultimate defence against complexity." David Gelernter
