Beste tweakers
als ik OSS start via soundon dan krijg ik het volgende bericht:
This Open Sound System copy is licensed for limited evaluation use only.
You can order the permanent OSS license using the 'Order permanent OSS license'
function of soundconf command. Alternatively use our ordering page at
[url="http://www.opensound.com/order.html"]http://www.opensound.com/order.html[/url].
*** The evaluation time is limited to 20 minutes ***
IMPORTANT!
The following OSS drivers required for your current
hardware configuration: SBLIVE
While these drivers _are_ included in this evaluation version
they don't belong to the base price of OSS software.
Remember to select them while ordering the permanent OSS license.
*** OSS will _NOT_ work in your system without these drivers. ***
To make the ordering process easier we have created a prefilled
HTML order form in /usr/lib/oss/order.html.
Use the 'Order permanent OSS license' function of soundconf
to order the license.
Open Sound System started OK.
Als OSS draait sluit hij ze eigen weer af na 20 minuten dus, hoe kan ik ervoor zorgen dat ie dat niet doet? er staat dat ik hem moet bestellen, moet dit echt of is dit onzin?
het gaat om OSS397b
IMPORTANT!
het gaat om OSS397b
