[CS] Ben jij een config lamer?
Pagina: 1 2 Laatste
  • 840 views sinds 30-01-2008
  • A1ex
Als jij zo'n elied heksor bent, waarom zien we jouw config dan niet in dit topic staan? :r :Z
Variables: 46
Allowed: 38
Not allowed: 1
gamma (You have 2.500000, default is 3 and CPL is 3).
Not recognised: 7
'_windowed_mouse' '0.000000'
'cl_minmodels' '1'
'cl_corpsestay' '180'
'cl_dynamiccrosshair' '1'
'_cl_autowepswitch' '0'
'setinfo' '_ah'
'setinfo' '_vgui_menus'
  • McFlipp
  • Laatst online: 22-04-2023
McFlipp
24...
Op maandag 22 juli 2002 22:28 schreef Catch22 het volgende:
29
30
31
32
33
Not allowed: 30
gl_lightholes (You have 0, default is 1 and CPL is not allowing this command).
gl_palette_tex (You have 0, default is 1 and CPL is not allowing this command).
gl_keeptjunctions (You have 0, default is 1 and CPL is not allowing this command).
gl_playermip (You have 10, default is 0 and CPL is not allowing this command).
gl_wateramp (You have 0, default is 0.300 and CPL is not allowing this command).
gl_clear (You have 1, default is 0 and CPL is not allowing this command).
brightness (You have 6.000000, default is 1 and CPL is 1).
gamma (You have 6.000000, default is 3 and CPL is 3).
s_refgain (You have 0, default is 0.400 and CPL is not allowing this command).
s_refdelay (You have 0, default is 4 and CPL is not allowing this command).
s_polykeep (You have 0, default is 1000000000 and CPL is not allowing this command).
s_polysize (You have 0, default is 10000000 and CPL is not allowing this command).
s_numpolys (You have 0, default is 200 and CPL is not allowing this command).
s_geometry (You have 0, default is 1 and CPL is not allowing this command).
s_reflect (You have 0, default is 1 and CPL is not allowing this command).
s_reverb (You have 0, default is 1 and CPL is not allowing this command).
s_usepvs (You have 0, default is 1 and CPL is not allowing this command).
s_verbwet (You have 0, default is 0.250 and CPL is not allowing this command).
s_occlude (You have 0, default is 1 and CPL is not allowing this command).
s_occ_epsilon (You have 0, default is 1 and CPL is not allowing this command).
s_occfactor (You have 0, default is 0.250 and CPL is not allowing this command).
loadas8bit (You have 1, default is 0 and CPL is not allowing this command).
snd_noextraupdate (You have 1, default is 0 and CPL is not allowing this command).
mp_decals (You have 50, default is 2000 and CPL is 300).
cl_updaterate (You have 50, default is 20 and CPL is 101).
cl_cmdrate (You have 60, default is 30 and CPL is 101).
mp_decals (You have 5, default is 2000 and CPL is 300).
r_decals (You have 5, default is 4096 and CPL is not allowing this command).
fps_max (You have 99, default is 72 and CPL is 100).
hihi >:)
Vandaar dat Pamf zo goed is >:) :P
Mijn Airliners.net foto's
A bird in the hand is worth two in the bush - Aesop
  • Captain Pervert
  • Laatst online: 01-10 15:13
fps_max (You have 150, default is 72 and CPL is 100).
Flikker op, ik haal niet meer dan 60 fps als ik hem op 100 zet, en als ik hem op 150 zet heb ik 100 fps (:?)
Duuuhs.
Porsche 928 - It's about as fast as you can go without having to eat airline food.
  • datwainer
datwainer
#tweakers.net @ sorcery
Op maandag 22 juli 2002 22:52 schreef Peertje het volgende:
Omdat ik het altijd leuk vind om vanalles te testen. Het helpt een stuk als je weet wat de mensen kunnen horen die het wel hebben.
Het is ook een stuk makkelijker om tegen cheaters te spelen als je weet hoe de cheats in elkaar zitten en wat ze dus wel en niet kunnen.
aha ok, :)
Under Construction
Ja
Op dinsdag 23 juli 2002 17:36 schreef FuTaL het volgende:
Ja
durft m zelfs niet eens te posten? ;)
erm uuh hij speelt gewoon standaard
heb zijn config wel gezien >:)
diwk de l337 default configger >:)
Verder klikken dan het draad van je muis lang is
[url="http://members.home.nl/vanklinken/CS%20config/"]http://members.home.nl/vanklinken/CS%20config/[/url]
[edit]
en wtf is dit dan nou weer
ex_diminishextrap
  • Hoyden
  • Registratie: December 1999
  • Laatst online: 27-10 19:01
Not allowed: 30
hihi >:)
Ej, hoe kom je daar aan :D
eMMen he :D :?
:o
  • Hoyden
Op woensdag 24 juli 2002 00:10 schreef ThePreatorian het volgende:
[edit]
ex_diminishextrap
eMMEn ownage :D :D :D :o :o :o
  • 418O2
418O2
u mad?
emmen is geen cfg-lamersdorp >:)
  • buzz
  • Laatst online: 25-10 19:31
Ach zo worden ze vaak wel gezien :)
  • Fried
  • Laatst online: 26-10 11:08
Not allowed: 4
gamma (You have 2.400000, default is 3 and CPL is 3).
brightness (You have 0.000000, default is 1 and CPL is 1).
gl_polyoffset (You have 4, default is 0.100 and CPL is not allowing this command).
cl_timeout (You have 60, default is 35 and CPL is not allowing this command).
Not recognised: 11
'voice_forcemicrecord' '1.000000'
'MP3Volume' '0.800000'
'cl_corpsestay' '600.000000'
'_cl_autowepswitch' '1'
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '0'
'setinfo' '_cm_pw'
'setinfo' '_ah'
Alias: 0
Binds: 84
't gaat dus weer nergens over....
  • spokje
  • Laatst online: 10:12
Not allowed: 8
fps_max (You have 90, default is 72 and CPL is 100).
gamma (You have 4.000000, default is 3 and CPL is 3).
brightness (You have 0.600000, default is 1 and CPL is 1).
mp_decals (You have 100.000000, default is 2000 and CPL is 300).
gl_polyoffset (You have -0.001, default is 0.100 and CPL is not allowing this command).
gl_overbright (You have 1, default is 0 and CPL is not allowing this command).
s_a3d (You have 1.000000, default is 0 and CPL is not allowing this command).
hud_classautokill (You have 0, default is 1 and CPL is not allowing this command).
Not recognised: 5
'tfc_newmodels' '1'
'hud_draw' '1'
'setinfo' 'pw_home'
  • NaLiN
NaLiN
Muziek moet ragge
Not allowed: 5
mp_decals (You have 10, default is 2000 and CPL is 300).
voice_enable (You have , default is 1 and CPL is not allowing this command).
cl_cmdrate (You have 50, default is 30 and CPL is 101).
hallo
  • Hielko
  • Laatst online: 11:04
Ik ben bijna clean:
Not allowed: 2
Not allowed: 3
sv_aim (You have 1.000000, default is 0 and CPL is not allowing this command).
Not recognised: 8
'cl_corpsestay' '600'
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '0'
Alias: 0
Binds: 58
Khad gister een clean cs install gedaan+clean config en komen ze met deze bs
Bartjeuhz schreef op 20 juli 2002 @ 14:03:
gamma (You have 999.000000, default is 3 and CPL is 3).
brightness (You have 999.000000, default is 1 and CPL is 1).
Standaard waarden zijn 3 en 1, en je hebt 999??? Een supernova geeft minder licht dan dat man! :X :D
  • Hahn
  • Laatst online: 10:38
Config Validater
Variables: 102
Allowed: 88
Not allowed: 3
brightness (You have 0.300000, default is 1 and CPL is 1).
cl_updaterate (You have 40, default is 20 and CPL is 101).
fastsprites (You have 1, default is 0 and CPL is not allowing
this command).
Not recognised: 11
'cl_corpsestay' '25.000000'
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '0'
'setinfo' 'v'
'setinfo' '_ah'
Alias: 0
Binds: 71
Oeps :X
Maar wat is er nou precies fout :?
The devil is in the details.
29
30
31
32
33
34
35
36
37
Config Validater
Variables: 99
Allowed: 84
Not allowed: 5
brightness (You have 22, default is 1 and CPL is 1).
fastsprites (You have 2, default is 0 and CPL is not allowing this command).
Not recognised: 10
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '0'
'setinfo' '_ah'
Alias: 0
Binds: 77
Brightness beetje hoog :+
Whahahaha sorry moet ff lachen stiekem tweak je wel nalin :)
maar goed dat doet iedereen op een niet based cpl war en watttan nog iedereen speelt zoals hij graag speelt ik speel default veel beter dan al dat getweak
Config Validater
Variables: 99
Allowed: 85
Not allowed: 4
brightness (You have 2.000000, default is 1 and CPL is 1).
mp_decals (You have 100, default is 2000 and CPL is 300).
cl_updaterate (You have 22, default is 20 and CPL is 101).
cl_cmdrate (You have 22, default is 30 and CPL is 101).
Not recognised: 10
'voice_forcemicrecord' '0.000000'
'cl_corpsestay' '0.0000000'
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '1'
'cl_dynamiccrosshair' '0'
'setinfo' '_ah'
Alias: 0
Binds: 63
wat betekent die extrapmax dan niet dat ik het ga gebruiken
knowledge is power ;)
  • BOCmetalhead
  • Laatst online: 19-08 15:22
Verwijderd schreef op 19 juli 2002 @ 21:44:
Totdat overal WWCL plugin geinstalleerd is :P
WWCL forceert bepaalde settings naar een default waarde zoals a3d en 90% van de andere settings.
Op rG zenith illusion en o8s servers is deze plugin geinstalleerd.
op illusion zijn zelfs alle settings geblokt zelfs cl_bob >:)
waar kan je die plugin downen??? ff ook bij mij op mijn server neer zetten
Metal to the bone
  • BOCmetalhead
Verwijderd schreef op 24 juli 2002 @ 00:10:
en als je nou eens een draadloze muis heb :P >:)
Metal to the bone
Config Validater
Variables: 98
Allowed: 86
Not allowed: 4
fastsprites (You have 1.000000, default is 0 and CPL is not allowing this command).
Not recognised: 8
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '0'
Alias: 0
Binds: 70
beetje vaag, ik heb volgens mij nog nooit wat veranderd..
  • RAJH
Config.cfg
29
30
31
32
33
34
35
Variables: 97
Allowed: 83
Not allowed: 4
cl_timeout (You have 999999, default is 35 and CPL is not allowing this command).
cl_cmdrate (You have 51, default is 30 and CPL is 101).
Not recognised: 10
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '0'
'setinfo' '_ah'
Alias: 0
Binds: 78
Autoexec.cfg
Variables: 4
Allowed: 4
Alias: 102
Binds: 0
Dit is dus mijn nieuwe config. Mijn oude was iets anders :+
BOCmetalhead schreef op 19 augustus 2002 @ 14:31:
uuuuuuuuuuh ja :)
verder klikken dan je arm reikt ;)
maar goed wwcl plugin hoeft niks hiero te forceren allemaal cpl :O
en dat cl_b0b wat schiet je ermee op
  • Wiebbe
  • Laatst online: 23-10 23:04
Wiebbe
<none />
hmmm :P
29
30
31
32
33
34
35
36
37
38
39
40
41
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /aux2/info/www.sogamed.com/include/db.inc on line 43
Variables: 52
Allowed: 29
Not allowed: 17
hud_deathnotice_time (You have 10, default is 6 and CPL is not allowing this command).
max_shells (You have 0, default is 120 and CPL is not allowing this command).
max_smokepuffs (You have 20, default is 120 and CPL is not allowing this command).
cl_updaterate (You have 25, default is 20 and CPL is 101).
cl_cmdrate (You have 35, default is 30 and CPL is 101).
brightness (You have 2, default is 1 and CPL is 1).
ambient_fade (You have 0, default is 100 and CPL is not allowing this command).
gamma (You have 4, default is 3 and CPL is 3).
r_decals (You have 100, default is 4096 and CPL is not allowing this command).
r_shadows (You have 1, default is 0 and CPL is not allowing this command).
hisound (You have 0, default is 1 and CPL is not allowing this command).
gl_dither (You have 0, default is 1 and CPL is not allowing this command).
gl_polyoffset (You have 4.0, default is 0.100 and CPL is not allowing this command).
pushlatency (You have -200, default is -50 and CPL is not allowing this command).
Not recognised: 6
'echo' '[DEU]Wiebbe's'
'gl_linear_mipmap_linear' ''
'setinfo' 'cl_observercrosshair'
'setinfo' 'ghosts'
'setinfo' 'admin_pw'
'echo' 'Script'
Alias: 24
Binds: 51
en deze was gebruikt door men roommate, tijdens de Netgamez 2k, Cpl Event. Dus een een event van CPs zelf, en deze Config was door hun goed gekeurd:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
Variables: 60
Allowed: 32
Not allowed: 22
max_smokepuffs (You have 0, default is 120 and CPL is not allowing this command).
cl_lw (You have 0, default is 1 and CPL is not allowing this command).
cl_nopred (You have 1, default is 0 and CPL is not allowing this command).
r_drawviewmodel (You have 0, default is 1 and CPL is not allowing this command).
gl_max_size (You have 512, default is 256 and CPL is not allowing this command).
gl_alphamin (You have 0,25, default is 0.250 and CPL is not allowing this command).
Not recognised: 6
'echo' '[DEU]QBane's'
'setinfo' 'ghosts'
'gl_monolight' '0'
'echo' 'Script'
Alias: 12
Binds: 49
vaaaaag ;)
Oh noes.. No more TreinTijden :(
  • Wiebbe
Wiebbe
<none />
Verwijderd schreef op 19 augustus 2002 @ 16:32:
uuuuuuuuuuh ja :)
gaat je pistooltje niet zo op en neer?
:P
WWCL Plug-in zuigt als je hem klakkeloos op je server installeert. WWCL is een LAN plugin en als je hem niet aanpast aan Online behoeften zuigt die plugin zwaar.
Zet iig ex_interp op 0.05 als je hem installeert. Als je dan toch CPL standaard op je online server wilt hebben.
  • Reefer
  • Laatst online: 21-02-2025
Reefer
madness
Config Validater
Variables: 101
Allowed: 86
Not allowed: 5
gamma (You have 5.000000, default is 3 and CPL is 3).
brightness (You have 4.000000, default is 1 and CPL is 1).
mp_decals (You have 20.000000, default is 2000 and CPL is 300).
gl_overbright (You have 1.000000, default is 0 and CPL is not allowing this
command).
fastsprites (You have 1, default is 0 and CPL is not allowing this command).
Not recognised: 10
A Breakbeat A Day Keeps Religion Away.
Variables: 97
Allowed: 83
Not allowed: 5
gamma (You have 2.300000, default is 3 and CPL is 3).
29
30
Config Validater
Variables: 96
Allowed: 86
Not allowed: 2
Not recognised: 8
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '0'
Alias: 0
Binds: 66
wat mag er nie dan
Aha daarom ben ik niet goed in CS. Ik moet effe aan mijn CFG kloten :P .
  • Tripp
  • Laatst online: 16-03-2024
Tripp
Wreah
kick :).
Ik snap nou echt niet dat een config je zoveel beter kan maken :?
Je moet gewoon raak schieten that's all >:).
Zou je met een bepaalde config meer headshots hebben of meer raken :?. Maakt toch geen drol uit allemaal }:O.
specs
  • buzz
executor schreef op 29 augustus 2002 @ 20:05:
kick :).
Uhm ik kan je verzekeren dat een config een hele wereld van verschil maakt. Geef mij 2 identieke systemen en 2 identieke spelers, en ik kan zorgen dat dmv de config de ene speler een voordeel over de ander heeft. DWZ dus dat het wel uitmaakt :)
  • Desolation Angel
  • Laatst online: 16-12-2023
Idd , als je bv Move forward aan A bindt , move backward aan enter , strafe left aan r-ctrl en strafe right aan numpad + .
Speel dan nog maar eens degelijk
  • ThaHandy
  • Laatst online: 22-10 03:04
ThaHandy
Discovery Channel
de ergste vind ik nog wel die a la AWM-pistol script }:O }:O }:O }:O
  • Tripp
Tripp
Wreah
dubbel :O
specs
  • Tripp
Tripp
Wreah
BuzzerCrAsH schreef op 30 augustus 2002 @ 02:53:
pass me dat script dan maar :P.
Desolation Angel schreef op 30 augustus 2002 @ 04:27:
R :) FL
ThaHandy schreef op 30 augustus 2002 @ 05:44:
die vind ik ook uitermate triest. Zodra ze geschoten heb met awp paktie pistool :X.
Ik speel gewoon met de pijtjes+numpad. Ik wissel sneller van wapen dan iemand met een scrollmuis.
specs
  • Oefening
executor schreef op 30 augustus 2002 @ 14:20:
Mz, daar heb ik geen script voor nodig hoor.
Me to :)
bij mij in CS staat het spel als linkshandig ingesteld terwijl ik rechts ben :( waar/hoe kan ik hem instellen dat hij rechthandig speelt? dus dat het wapen rechts staat ipv links
  • Oefening
Was ut niet iets van left_hand 1 of left_weapon 1 ofzo in console? Btw, je kan dat nu ook gewoon instellen in je hl/cs-menu (bij options/controls ofzo) :)
Nelis schreef op 30 augustus 2002 @ 14:56:
dat werkt niet :( en in het menu staat het ook niet :(
Config Validater
Variables: 95
Allowed: 86
Not allowed: 1
Not recognised: 8
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '0'
Alias: 0
Binds: 68
1 hax mja dat mag toch wel ? :P
  • Sv3n
  • Laatst online: 27-10 16:39
Variables: 102
Allowed: 92
Not recognised: 10
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '0'
'setinfo' '_ah'
Alias: 0
Binds: 66
Ik ben netjes :)
Last.fm
Films!
Variables: 102
Allowed: 87
Not allowed: 3
cl_forwardspeed (You have 700, default is 400 and CPL is not allowing this command).
Not recognised: 12
'hud_draw' '1'
'cl_righthand' '1'
'cl_minmodels' '0'
'setinfo' '_cm_pw'
'setinfo' '_ah'
Alias: 0
Binds: 76
ben ook niet echt clean
wat is trouwens: gl_polyoffset ??
  • ThaHandy
ThaHandy
Discovery Channel
Verwijderd schreef op 30 augustus 2002 @ 14:50:
+commandmenu (met of zonder +) in console typuh
dan krijg je een menu en daar kan je L/R instellen
* ThaHandy doet ook alles op de "echt" manier :P
op de buy-script na :Y)
  • chromeeh
  • Laatst online: 27-10 14:42
chromeeh
the Gnome
LOL :) Met fatsoenlijke TFC configs kan die nie om gaan :D
*WARNING* Your config file is too large!
"Some day, I hope to find the nuggets on a chicken."
Pagina: 1 2 Laatste
