Probleem is dat ik nietmeer kan updaten met het programma van Redhat (up2date), ik krijg de volgende melding:
Updaten van openssl levert het volgende op:
Ik heb schijnbaar libcrypto.so.1 en libcrypto.so.2 beiden nodig. Maar kan dus niet.
Huidige versie van openssl -> openssl-0.9.6b-8, openssl-devel-0.9.6b-8
voor zover ik weet levert openssl dat bestandje aan.Testing package set / solving RPM inter-dependencies...
There was a package dependency problem. The message was:
Unresolvable chain of dependencies:
bind 9.2.1-0.70 requires libcrypto.so.1
bind-utils 9.2.1-0.70 requires libcrypto.so.1
wat nu?# rpm -Uvh openssl-0.9.6-9.i386.rpm openssl-devel-0.9.6-9.i386.rpm
error: failed dependencies:
libcrypto.so.2 is needed by cyrus-sasl-md5-1.5.24-23
libcrypto.so.2 is needed by bind-utils-9.1.3-4
libcrypto.so.2 is needed by bind-9.1.3-4
libcrypto.so.2 is needed by pine-4.44-1.72.0
libcrypto.so.2 is needed by nss_ldap-172-2
libcrypto.so.2 is needed by autofs-3.1.7-21
libcrypto.so.2 is needed by stunnel-3.22-1
libcrypto.so.2 is needed by links-0.96-2
libcrypto.so.2 is needed by pidentd-3.0.14-1
libcrypto.so.2 is needed by ucd-snmp-4.2.3-1.7.2.3
libcrypto.so.2 is needed by ucd-snmp-utils-4.2.3-1.7.2.3
libcrypto.so.2 is needed by curl-ssl-7.9.5-1
libssl.so.2 is needed by pine-4.44-1.72.0
libssl.so.2 is needed by nss_ldap-172-2
libssl.so.2 is needed by autofs-3.1.7-21
libssl.so.2 is needed by stunnel-3.22-1
libssl.so.2 is needed by links-0.96-2
libssl.so.2 is needed by curl-ssl-7.9.5-1
Taaaa taa taa taaaa taa taa ta taaataaaaa.
