Als ik via de netwerkomgeving op mijn Linux/Samba bak wil komen krijg ik de volgende melding:
M'n smb.conf
Ik heb de configfile van een internetsite afgehaald en een beetje aangepast. [url="http://bovendelft.xs4all.nl/linux/samba_windows2000.php"]http://bovendelft.xs4all.nl/linux/samba_windows2000.php[/url]\\Pluto is niet toegangkelijk. U hebt mogelijk niet de juiste machtigingen voor deze netwerkbron. Neem contact op met de beheerder van de server op als u wilt weten of u toegangsmachtigingen hebt.
Kan het netwerkpad niet vinden.
M'n smb.conf
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options (perhaps too
# many!) most of which are not shown in this example
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentry and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command "testparm"
# to check that you have not many any basic syntactic errors.
#======================= Global Settings =====================================
[global]
null passwords = no
log file = /var/log/samba/log.%m
loglevel = 2
debug timestamp = yes
bind interfaces only = yes
max log size = 250
interfaces = 192.168.0.3/255.255.255.0
domain master = yes
#add user script = /usr/sbin/adduser -g machines -c NTMachine -d /dev/null -s /bin/false -n '%m$'
#delete user script = /usr/sbin/userdel %m$
locking = yes
domain logons = yes
preferred master = yes
encrypt passwords = yes
password level = 0
logon path = \\Pluto\profile\%U
serverstring = Samba on %L
socket address = 192.168.0.5
hosts allow = 192.168.0.3 localhost
workgroup = HOME
smb passwd file = /etc/samba/smbpasswd
logon script = %U.bat
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_SNDBUF=8192 SO_RCVBUF=8192
read raw = yes
write raw = yes
netbios name = PLUTO
load printers = no
local master = yes
security = user
os level = 65
oplocks = True
deadtime = 1
lock directory = /tmp/samba
[netlogon]
#allow hosts = 192.168.xxx.
max connections = 8
comment = The domain logon service
path = /home/netlogon
browseable = no
[profile]
comment = User profiles
path = /home/profiles
create mode = 0600
directory mode = 0700
writeable = yes
browseable = no
[htdocs]
comment = Apache
writable = yes
path = /usr/local/apache/htdocs
public = yes
write list = root, @usersgroup
valid users = root, @usersgroup
admin users = root
create mode = 0774
directory mode = 0775
force group = usersgroup
[Rootdir]
comment = Root directory off server, stay away!
writable = yes
path = /
valid users = root, user1
admin users = root, user1
create mode = 0744
directory mode = 0755
public = no
write list = root, user1
force user = root
force group = root
The NS has launched a new space transportation service, using German trains which were upgraded into spaceships.
