[HIFI] De mooiste speakerkabels
  • 130 views sinds 30-01-2008
Ik vroeg me af wat de mede tweaker nou een mooie speakerkabel vindt. Let op het gaat er dus om hoe hij eruit ziet en niet hou hij klinkt!!
Ikzelf vind de zilvere kabel van JK erg mooi om te zien
Afbeeldingslocatie: http://www.hear.nl/merken/jkacoustics/products/interlinkkabeltype3.jpg
IXOS.. schijnt wel duur te zijn
  • Fireman
  • Laatst online: 21-10-2025
Fireman
We talk about luxury problems
Ik vind deze wel aardig.
Afbeeldingslocatie: http://www.nordost.com/jpegs/red_dawn.jpgAfbeeldingslocatie: http://www.nordost.com/jpegs/RedDawn.jpg
Dat zijn de:
red dawn cables
Red Dawn speaker cable consists of thirty-eight conductors of 99.999999% OFC, which is plated with extruded silver. Each conductor is separately encapsulated in extruded Teflon.
Red Dawn is normally terminated with 19 conductors per channel. This cable can be ordered terminated for bi-wiring. It provides a level of detail that is outstanding.Its ability to properly control loudspeaker performance is superb. It transmits signals at over 95% the speed of light. Every fine nuance of the musical performance is revealed with Red Dawn.
Red Dawn interconnects herald a new era in interconnect performance and define state of the art standards. Uncompromising in its performance, this cable totally involves the listener in the musical experience. It uses 20 conductors of 99.999999% oxygen free copper with an extruded silver surface. Each conductor size is varied and balanced for optimum performance. Each cable is terminated with the highest quality, precision crafted connectors, which are made with a hard alloy that is gold plated. Red Dawn can also be ordered as a balanced interconnect with gold-plated XLR connectors.
Red Dawn is available in 0.6m (2ft), 1m (3ft 4 ins) and 1.5m (4ft 9ins). Other lengths are available on request.
speaker cable
insulation Extruded Teflon®
conductor x40 varied and balanced
material 60 microns extruded silver over 99.999999% OFC
capacitance 8.7pF/ft
inductance 0.13uH/ft
propagation delay 94% speed of light
interconnect
conductor x20 varied and balanced
capacitance 8.9pF/ft
inductance 0.12uH/ft
Naim Audio SN2 + NDX + Soup (accuton/Thiel)
Op donderdag 18 juli 2002 09:20 schreef Fireman het volgende:
[afbeelding][afbeelding]
Dat ziet er zonder meer goed uit zeg. Deze vind ik volgens mij ook beter dan dat ketelaar vlosdraad.
  • Duck-Twacy
  • Laatst online: 12-10 22:23
Duck-Twacy
I'm hit!
Wist niet dat speakerkabel "mooi" moest zijn. :)
Overweeg zelf mijn huidige no-name kabels te vervangen door Kimber kabel (omdat iedereen die goed schijnt te vinden en ook de prijs/kwaliteit in orde is)
bv deze
Afbeeldingslocatie: http://www.kimber.com/8pr-b.jpg
iets van 13,50 euro/meter (is 1 van hun goedkoopste soorten)
2 crush your enemies, 2 win the Tournament
  • Fireman
Fireman
Op donderdag 18 juli 2002 12:47 schreef Duck-Twacy het volgende:
(omdat iedereen die goed schijnt te vinden en.. )
Lekkere eigen mening zeg ;) 't gaat erom wat JIJ mooi vindt en vind klinken niet wat andere vinden. Kom nou.
dis me zilverkabel:
http://www.vandenhul.nl/cable/clrwtr.htm
ik kan me normale speakerkabel daaro niet vinden.... damn das ook van de hul maar kan niet op de naam komen
  • Duck-Twacy
Duck-Twacy
I'm hit!
Op donderdag 18 juli 2002 12:49 schreef Fireman het volgende:
Ja, ik ga even mijn tijd verspillen met naar verschillende kabels luisteren. Zie me al staan in de winkel. "Mag ik 3 verschillende soorten kabels meenemen naar huis? Per soort 1 stuk van 3 en 1 stuk van 5 meter."
Get real ;) .
(ben inderdaad slechts een slaafse consument :) )
  • Fireman
Fireman
Op donderdag 18 juli 2002 13:00 schreef Duck-Twacy het volgende:
Get real ;) .
Ik "had" jou hoger ingeschat met al die AV postings :) Of niet. Beetje audio-tweaker gaat voor de ins & outs.
Op donderdag 18 juli 2002 13:08 schreef Fireman het volgende:
en gaat zelf luisteren, gewoon in de winkel :)
Alsof het wat uit maakt.. laatst is er nog een hele grote test geweest met een boel "audiofielen", en ze konden het verschil niet eens horen tussen doodnormaal 2-aderig snoer en snoer van enkele duizenden guldens..
'T zit allemaal tussen de oortjes hoor :)
  • Fireman
Fireman
Op donderdag 18 juli 2002 13:11 schreef Shakespeer het volgende:
Weet je hoe ze dat noemen?
Op donderdag 18 juli 2002 13:10 schreef neographikal het volgende:
Nee het liefst thuis in de eigen luisterruimte, komt de "klank"het beste tot zijn recht >:)
  • Duck-Twacy
Duck-Twacy
I'm hit!
ik voel een offtopic discussie over het nut van kabels aankomen. :P
Probleem is een beetje "hoe kies je een kabel". Als ik de kabelfanaten (gelovigen?) mg geloven hangt het success sterk af van de rest van je set, dus in de winkel luisteren heeft geen zin (zeker als je set bestaat uit zelfbouw en/of vrij zeldzame apparatuur). Dus moet je thuis luisteren. Speakerkabel haal je meestal van een rol (tenzij je het over de extreem dure kabels praat van enkele honderden euro's per meter, die zit vaak voorverpakt, bv 2 * 3 meter)
Bij interlink kan ik me het nog wel voorstellen dat een goede zaak ze je thuis laat uitproberen, maar kabel versnijden (in de prijsklasse van 10-20 euro per meter) voor thuis luisteren (als je een winkelier weet die dat doet?). Okay, misschien zijn er winkels die gewoon wat "probeerstukjes" hebben liggen.
Maar dan nog. Ik zie kabel als de finishing touch, met betrekkelijk weinig invloed op het resultaat (als dat wel zo zou zijn is er volgens mij iets goed mis). Ik wil geen rommelkabel, maar ook geen belachelijke dure, dus ga ik af op de informatie van derden (liefst verschillende bronnen). Ik kan me niet echt voorstellen dat ik echt veel veschil zal horen tussen bv bovengenoemde Kimber en een vdHul CS-122 van 12 euro of een QED silver anniversary (van 5 Bpd)
  • Fireman
Fireman
Op donderdag 18 juli 2002 13:40 schreef Duck-Twacy het volgende:
IDD en dan gaan we nu weer ON topic.
Sommige mensen vinden de 2.5mm2 van de electrische bekabeling ook al mooi strak. Dan niet die met al die losse adertjes maar met vaste kern. Zo'n draad gaat meestal van af de meterkast naar het stopkontakt.
  • Duck-Twacy
Duck-Twacy
I'm hit!
Nog even voor de topic starter :)
Afbeeldingslocatie: http://www.monstercable.com/images_db/home_av/sigma/SRGLEK_pis_bkrnd.jpg
een willekeurig mooi kabelsetje in kado verpakking ($4500 voor 2 * 8 ft, maar dan krijg je er ook 2 interconnects bij)
  • adana
  • Laatst online: 22-10 01:37
adana
merzbow, schmerzbow
tiepies gevalletje overengineering:
Afbeeldingslocatie: http://www.transparentcable.com/images/news/Opus_MM_family_650x406.jpg
sorry voor de layout
"One day I may find it quite amusing,
how touch and tongues make life so confusing."
Anne Clark
