Het volgende heb ik dus in mijn index.php staan.(kort samengevat)
eerst een stuk site en dan dmv include mijn login script.
en dit is mijn login script
nu krijg ik dus deze foutmelding,
het stomme is alleen dat de cookies(setcookie(blabla) wel worden uitgevoerd. ik krijg alleen die foutmelding ertussen
PHP:
| <?<html><head></head><body><?phpinclude("login.php");?></body></html>?> |
PHP:
| <?$database_host = "***"; $username = "***";$password = "***";$database = "***";mysql_connect($database_host, $username, $password) or die("Failed to connect to the Database"); mysql_select_db("$database") or die("mySQL doesnt seem to work!"); if (isset($_POST['name']) && isset($_POST['pass'])) { $result = mysql_query("SELECT * FROM users WHERE name='$_POST[name]' AND pass='$_POST[pass]'") or die("Oups! mySQL doesnt seem to work!"); if (mysql_num_rows($result) == 1) { setcookie("name", $_POST['name'],time()+3600); setcookie("pass", $_POST['pass'],time()+3600); // ************************************************************ ?> wat html blaat <?php echo "Hoi $name, je bent ingelogd"; ?> <?// ************************************************************ } Else { ?> <centre><b>Wrong Password!</b><br> Try again!!<br></centre> <? print("<a href=\"$PHP_SELF\">Retry</a>"); } } Else { ?> <form method="post" action="<?php echo $PHP_SELF?>?page=login"> <b>Your Username: </b> <input name="name"><br> <b>Your Password: </b> <input name="pass" type="password"><br> <input type="submit" value="submit"> </form> <? } ?> ?> |
| Warning: Cannot add header information - headers already sent by (output started at /index.php:10) in /login.php on line 15 Warning: Cannot add header information - headers already sent by (output started at /index.php:10) in /login.php on line 16 |
