[kde 3.1] compile errors
Ik ben vanmorgen begonnen met kde 3.1 compilen, ik heb deze goed voor elkaar gekregen:
- arts-1.0.6
- kdebindings-3.0.6
- kdegames-3.0.6
- kdelibs-3.0.6
- kdenetwork-3.0.6
- kdeutils-3.0.6
- kdeadmin-3.0.6
- kdeedu-3.0.6
- kdegraphics-3.0.6
- kdemultimedia-3.0.6
- kdetoys-3.0.6
Alles met --prefix=/opt/kde-3.1-alpha1 gecompiled.
Wat ik nu dus nog mis is o.a. kdebase, maar daarbij kreeg ik de volgende error:
libs/FontThumbnail.o: In function `CFontThumbnail::CFontThumbnail(void)':
.libs/FontThumbnail.o(.text+0x747e): undefined reference to `FTC_Manager_New'
.libs/FontThumbnail.o(.text+0x7490): undefined reference to `FTC_SBit_Cache_New'
.libs/FontThumbnail.o(.text+0x749f): undefined reference to `FTC_Image_Cache_New'
.libs/FontThumbnail.o: In function `CFontThumbnail::~CFontThumbnail(void)':
.libs/FontThumbnail.o(.text+0x74d7): undefined reference to `FTC_Manager_Done'
.libs/FontThumbnail.o: In function `CFontThumbnail::getGlyphBitmap(FTC_Image_Desc_ &, unsigned long, CFontThumbnail::Bitmap &, int &, int &, int &, void **)':
.libs/FontThumbnail.o(.text+0x761a): undefined reference to `FTC_SBit_Cache_Lookup'
.libs/FontThumbnail.o(.text+0x767f): undefined reference to `FTC_Image_Cache_Lookup'
.libs/FontThumbnail.o: In function `CFontThumbnail::create(QString const &, int, int, QImage &)':
.libs/FontThumbnail.o(.text+0x7d9d): undefined reference to `FTC_Manager_Lookup_Size'
collect2: ld returned 1 exit status
make[4]: *** [fontthumbnail.la.closure] Error 1
make[4]: Leaving directory `/usr/src/kde-3.1-alpha1/kdebase-3.0.6/kcontrol/kfontinst/thumbnail'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/usr/src/kde-3.1-alpha1/kdebase-3.0.6/kcontrol/kfontinst'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/src/kde-3.1-alpha1/kdebase-3.0.6/kcontrol'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/kde-3.1-alpha1/kdebase-3.0.6'
make: *** [all] Error 2
./configure gaat wel zonder errors. Systeem draait slackware 8.1
  • _JGC_
  • Laatst online: 08:04
Een aantal verschillende mogelijkheden:
- je compilers zijn verschillend voor kde en QT
- Je draait nog QT 3.0.3
  • Fatal-Error
Da's de verkeerde volgorde... eerst (de nieuwste) qt, daarna artd, libs en daarna pas base... grote kans dat het dan wel werkt.
Welcome to the desert of the real.
Op woensdag 17 juli 2002 19:49 schreef _JGC_ het volgende:
M'n compilers zijn hetzelfde, maar QT is een Slack package. Ik draaide nog wel QT 3.0.4, ik ga wel even upgraden naar 3.0.5.
  • igmar
  • Laatst online: 29-06 18:56
igmar
ISO20022
Op woensdag 17 juli 2002 19:19 schreef Magio het volgende:
Die functies komen uit freetype 2. Kijk je config.log er nog eens op na, en kijk if je freetype goed geinstalleerd is.
Op woensdag 17 juli 2002 20:59 schreef igmar het volgende:
uhm...krijg dus weer zelfde error ... op qt 3.0.5. en over freetype :
configure:26627: checking for FreeType2 freetype/t1tables.h
configure: 26636: /usr/include/freetype/t1tables.h
configure: 26636: /usr/include/freetype2/freetype/t1tables.h
configure: 26636: /usr/local/include/freetype/t1tables.h
configure: 26636: /usr/local/include/freetype2/freetype/t1tables.h
taking that
configure:26649: result: yes, /usr/local/include/freetype2
configure:26661: checking for FreeType2 freetype/ftsnames.h
configure: 26669: /usr/include/freetype/ftsnames.h
configure: 26669: /usr/include/freetype2/freetype/ftsnames.h
configure: 26669: /usr/local/include/freetype/ftsnames.h
configure: 26669: /usr/local/include/freetype2/freetype/ftsnames.h
taking that
configure:26682: result: yes
  • Fatal-Error
Op woensdag 17 juli 2002 21:44 schreef Magio het volgende:
Hm.. weet je zeker dat er niets wordt gebruikt van de oude kde installatie (zoals includes en libs)?
Op woensdag 17 juli 2002 22:24 schreef Fatal-Error het volgende:
Yep, ik heb alles van 3.1-alpha1 gecompiled met --prefix=/opt/kde-3.1-alpha1.
  • Fatal-Error
Op donderdag 18 juli 2002 09:33 schreef Magio het volgende:
Maar die prefix zegt toch alleen wat over de plaats waar het spul moet komen te staan, niet over de plaats waar de headers en libraries worden gezocht die gebruikt worden tijdens de compilatie?
Op donderdag 18 juli 2002 09:39 schreef Fatal-Error het volgende:
hm....hebbie gelijk in...
/edit:
fout ontdekt ... KDEDIR=/opt/kde stond nog in me env, de oude kde map dus... export KDEDIR=/opt/kde-3.1-alpha1 lostte het op
