Ik ben al een hele namiddag bezig om XF86 aan de praat te krijgen op mijn laptop. Ik heb een speciale patched XF86 gecompiled maar als ik nu startx typ krijg ik:
XFree86 Version 4.0a / X Window System
(protocol Version 11, revision 0, vendor release 6400)
Release Date: 6 April 2000
If the server is older than 6-12 months, or if your card is newer
than the above date, look for a newer version before reporting
problems. (see http://www.XFree86.Org/FAQ)
Operating System: Linux 2.4.19-gentoo-r7 1 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Wed Jul 17 20:04:27 2002
(==) Using config file: "/root/XF86Config"
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (??) unknown.
(==) ServerLayout "Simple Layout"
(**) |-->Screen "Screen 1" (0)
(**) | |-->Monitor "Screen"
(**) | |-->Device "* Generic VESA compatible"
(**) |-->Input Device "Mouse1"
(**) |-->Input Device "Keyboard1"
(**) XKB: rules: "xfree86"
(**) XKB: model: "pc101"
(**) XKB: layout: "be"
(**) XKB: variant: "be"
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/local/,/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/75dpi/:unscaled,/usr/X11R6/lib/X11/fonts/100dpi/:unscaled,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/Speedo/,/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/100dpi/"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.0a, module version = 1.0.0
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.0a, module version = 0.1.0
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(--) PCI:*(1:0:0) SiS 630 rev 49, Mem @ 0xf0000000/27, 0xec100000/17, I/O @ 0xa000/7
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.0a, module version = 1.1.7
(II) Loading /usr/X11R6/lib/modules/drivers/vesa_drv.o
(II) Module vesa: vendor="The XFree86 Project"
compiled for 2.50.89Z, module version = 1.0.0
(WW) module ABI minor version (5) is newer than the server's version (2)
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
(II) VESA: driver for VESA chipsets: vesa
(--) Assigning device section with no busID to primary device
(--) Chipset vesa found
Fatal server error:
Caught signal 4. Server aborting
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
after 0 requests (0 known processed) with 0 events remaining.
Iemand een idee?
Fatal server error:
Iemand een idee?
