[WSH] Mijn output scherm is te klein.
  • 52 views sinds 30-01-2008
Dit is het script:
<code>
'*This script is for all user management needs.
'*computer running Win2K or WinNT w/WMI installed.
'*Author: Sarper SARIDAL
'*Date: 21/01/2002
'*Adjusted by: Patrick de Wijs
Option Explicit
On Error Resume Next
Dim User , LstNm , Acry , dlg , UserName, MSG ,Prop , result,domainname,newpass
domainname = InputBox("Please enter domain name: " & vbcrlf & "If you leave it blank the domain name will be accepted as DOMAIN. " , "Domain Information")
if domainname = "" then domainname = "DOMAIN"
call main()
sub main()
UserName = InputBox("Please enter UserName: ", "User Information")
set User = GetObject("WinNT://" + domainname + "/" + UserName)
If User.Name = "" Then
Dim wu
wu = MsgBox("UserName is not specified." & vbcrlf & vbcrlf & "Do you want to enter another name?",4,"No such user")
msgbox wu
if wu=6 then call main else exit sub
Else
MSG= vbCRLf
MSG = MSG & "User (ID):" & UserName & vbcrlf
MSG = MSG & "Full Name:" & User.FullName & vbcrlf
MSG = MSG & "Description:" & User.Description & vbcrlf
MSG = MSG & vbcrlf
MSG = MSG & "Group Membership " & vbcrlf
For Each Prop In User.groups
MSG = MSG & " " & Prop.Name & vbcrlf
Next 'Prop
Acry = Instr(1, User.FullName, ", ", 1)
'LstNm = Left(User.FullName, Acry - 1)
If User.IsAccountLocked = -1 Then
MSG = MSG & vbcrlf
MSG = MSG & "Account Status: Locked" & vbcrlf
Else
MSG = MSG & vbcrlf
MSG = MSG & "Account Status: Active" & vbcrlf
End If
'rem status
If User.LastLogin < 0 Then
MSG = MSG & vbcrlf
MSG = MSG & LstNm & " is not logged on to domain." & vbcrlf
Else
MSG = MSG & vbcrlf
MSG = MSG & LstNm & " Last User Logon" & vbCRLF & "Time: " & User.LastLogin & vbcrlf
End If
'rem status
MSG = MSG & vbcrlf
MSG = MSG & "Do you want to unlock " & vbcrlf
result=msgbox (msg,4,Username & " Status")
Else
MSG = MSG & vbcrlf
MSG = MSG & "The user is not locked out." & vbcrlf
result=msgbox (msg,0,Username & " Status")
End if
if result=6 then
User.IsAccountLocked = 0
User.SetInfo
result = msgbox(username & " has been unlocked successfully.")
end if
result = msgbox (username & " Attempt to change the password of the user?",4,"Password")
if result = 6 then
newpass = InputBox(" Please enter the user's new password : ", "New Password")
Call User.SetPassword(NewPass)
result = msgbox (username & " The password has been changed successfully.",0,"Password change")
end if
result = msgbox (username & " user is allowed to change his/her password" & vbcrlf & "at next logon?",4,"Authorization State")
if result = 6 then
User.passwordexpired = 1
User.SetInfo
result = msgbox (username & " will be able to change his/her password at next logon.",0,"Status Change")
end if
set User = nothing
set LstNm = nothing
set Acry = nothing
set wu = nothing
End If
wu = MsgBox("Do you want to enter another user name?",4,"New User")
end sub
</code>
Als ik het test krijg ik alle info.
Maar omdat ik als domain admin lid ben van veel groepen krijg ik niet alle gegevens op mijn output scherm te zien.
Hoe kan ik in dit script de maat van het output scherm aan laten passen aan de hoeveelheid data of een scrollbar toevoegen aan de rechterkant.
Bedankt alvast.
  • Janoz
  • Laatst online: 28-08 12:00
Janoz
Moderator Devschuur®
!litemod
Vraag het Sarper SARIDAL zou ik zo zeggen. ANders ff bij msdn of in een andere manual kijken welke dialog je kunt gebruiken om grote lappen tekst weer te geven..
Het is hier niet echt de bedoeling om een script neer te planten en vervolgens iets te zeggen als 'dit werkt niet'. Lees eventueel ff de quickstart en/of de faq (voor VB links) door.
