Kun je wel Tracken maar niet Sequencen? -> RENOISE
  • Mastermind
  • Laatst online: 24-09 20:41
Geweldig programma voor de Trackers onder ons. Voor degenen die Cubase en Reason te moeilijk vinden, en liever tracken, is er nu een Tracker die ook de benefits van sequencers bevat: Renoise!
Real-time DSP engine with high quality effects (reverb, echo/delay, compressor, distorsion, flanger, phaser...) Echte trance maken met een tracker! :)
http://www.renoise.com/
*Easy to use user interface, all-in-one, customizable and user friendly (uses DirectX for fastest response time)
*Easy to use arranger (sequencer) and song editor (tracker style)
* FastTracker2 - like keyboard shortcuts (and similar GUI)
* Integrated sampler and high quality mixer
* Integrated sample editor with full sample editing capabilities
* Full MIDI support (MIDI playback synchronized with audio latency and can be additionally synchronized manually if necessary)
* Full synchronization via MIDI clock as master or slave to external programs (eg. Cubase, etc.) or hardware that is able to receive or send MIDI clock (eg. drum machines, external sequencer, etc.)
* ASIO multi I/O cards support (for very low latency) with the ability to route tracks to hardware channels
* High quality player (internal 32-bit float point processing, interpolated, click free)
* Real-time DSP engine with high quality effects (reverb, echo/delay, compressor, distorsion, flanger, phaser...)!!!!!!!!!!!!!!!
* Integrated support for VST Plug-Ins 2.0 (this means even more effects and sound processors) !!! :D
* Integrated support for VSTi (VST instruments 2.0 - you can use many great software synths from Renoise now)
* Unlimited number of effects per track and high speed effects processing
* Popular formats support (songs/modules/instruments/samples)
* Automation of effects via track and instrument envelopes. * No need to type or remember effect numbers.
* Sampler supports: samples, multisampled samples (multilayered sample splits), loop samples (loops)
* Use sounds all at once: Sampler + VSTi + MIDI audio (as one instrument)
* Runs on all 32-bit Windows with DirectX 8.0 installed (Windows 95-98-Me-NT-2000-XP)
:9~
  • NiaX
heb het pakketje net ff gedownload
ziet er goed uit!!!
