ik was even bezig met ene protocol.... nou moet ik dit antwoord hebben.
(To find these numbers, you can do integer division and modulus with the packet size and 256)
nou weet ik wel wat een interger division is das deze in VB (\) en wat modulus is das deze MOD() maar ik snap gewoon de hele vraag niet
er moeten dus 2 byte's uit komen.
nou snap ik dit stukje niet :Every packet you send will begin with a three byte header. The first byte will always have an ASCII value of 0. The second and third bytes make up the size of the packet being sent. It has something to do with high and low order stuff, but I don't know the terminology. The value of the second byte plus 256 times the value of the third byte will be the size of the packet. To find these numbers, you can do integer division and modulus with the packet size and 256. Every packet should be 2045 bytes long, except for the last one, which will have the remaining number of bytes.
