[FreeBSD Samba printersharing] Toegang geweigerd..
  • 272 views sinds 30-01-2008
  • SvMp
Mij smb.conf:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options (perhaps too
# many!) most of which are not shown in this example
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentry and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command "testparm"
# to check that you have not many any basic syntactic errors.
#======================= Global Settings =====================================
[global]
# workgroup = NT-Domain-Name or Workgroup-Name, eg: REDHAT4
   workgroup = domein
# server string is the equivalent of the NT Description field
   server string = Fileserver
# This option is important for security. It allows you to restrict
# connections to machines which are on your local network. The
# following example restricts access to two C class networks and
# the "loopback" interface. For more examples of the syntax see
# the smb.conf man page
;   hosts allow = 192.168.1. 192.168.2. 127.
# If you want to automatically load your printer list rather
# than setting them up individually then you'll need this
   load printers = yes
# you may wish to override the location of the printcap file
;   printcap name = /etc/printcap
# on SystemV system setting printcap name to lpstat should allow
# you to automatically obtain a printer list from the SystemV spool
# system
;   printcap name = lpstat
# It should not be necessary to specify the print system type unless
# it is non-standard. Currently supported print systems include:
# bsd, sysv, plp, lprng, aix, hpux, qnx
   printing = bsd
# Uncomment this if you want a guest account, you must add this to /etc/passwd
# otherwise the user "nobody" is used
;  guest account = pcguest
# this tells Samba to use a separate log file for each machine
# that connects
   log file = /var/log/log.%m
# Put a capping on the size of the log files (in Kb).
   max log size = 50
# Security mode. Most people will want user level security. See
# security_level.txt for details.
   security = user
# Use password server option only with security = server
;   password server = <NT-Server-Name>
# You may wish to use password encryption. Please read
# ENCRYPTION.txt, Win95.txt and WinNT.txt in the Samba documentation.
# Do not enable this option unless you have read those documents
encrypt passwords = yes
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;   include = /usr/local/etc/smb.conf.%m
# Most people will find that this option gives better performance.
# See speed.txt and the manual pages for details
   socket options = TCP_NODELAY
# Configure Samba to use multiple interfaces
# If you have multiple network interfaces then you must list them
# here. See the man page for details.
;   interfaces = 192.168.12.2/24 192.168.13.2/24
# Browser Control Options:
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
local master = yes
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
os level = 64
# Domain Master specifies Samba to be the Domain Master Browser. This
# allows Samba to collate browse lists between subnets. Don't use this
# if you already have a Windows NT domain controller doing this job
domain master = yes
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
preferred master = yes
# Use only if you have an NT server on your network that has been
# configured at install time to be a primary domain controller.
;   domain controller = <NT-Domain-Controller-SMBName>
# Enable this if you want Samba to be a domain logon server for
# Windows95 workstations.
domain logons = yes
# if you enable domain logons then you may want a per-machine or
# per user logon script
# run a specific logon batch file per workstation (machine)
;   logon script = %m.bat
# run a specific logon batch file per username
#logon script = %U.bat
logon script = logon.cmd
# Where to store roving profiles (only for Win95 and WinNT)
#     %L substitutes for this servers netbios name, %U is username
#     You must uncomment the [Profiles] share below
;   logon path = \\%L\Profiles\%U
   logon path = \\Server\windows\profiles\%U
   logon drive = P:
   logon home = \\Server\%U
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
;   wins support = yes
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
#Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;   wins server = w.x.y.z
# WINS Proxy - Tells Samba to answer name resolution queries on
# behalf of a non WINS capable client, for this to work there must be
# at least oneWINS Server on the network. The default is NO.
;   wins proxy = yes
# DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
# via DNS nslookups. The built-in default for versions 1.9.17 is yes,
# this has been changed in version 1.9.18 to no.
   dns proxy = no
# Client codepage settings
# for Greek users
; client code page=737
# for European users (Latin 1)
; client code page=850
# for European users (Latin 2)
; client code page=852
# for Icelandic users
; client code page=861
# for Cyrillic users
; client code page=866
# for Japanese Users
; client code page=932
; coding system=cap
# for Simplified Chinese Users
; client code page=936
; coding system=cap
# for Korean Users
; client code page=949
; coding system=cap
# for Traditional Chinese Users
; client code page=950
; coding system=cap
#============================ Share Definitions ==============================
[homes]
   comment = Home Directories
   browseable = no
   writeable = yes
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
;   comment = Network Logon Service
;   path = /usr/local/samba/lib/netlogon
;   guest ok = yes
;   writeable = no
;   share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
;[Profiles]
;    path = /usr/local/samba/profiles
;    browseable = no
;    guest ok = yes
# NOTE: If you have a BSD-style print system there is no need to
# specifically define each individual printer
#[printers]
#   comment = All Printers
#   path = /var/spool/samba
#   browseable = no
# Set public = yes to allow user 'guest account' to print
#   guest ok = no
#   writeable = no
#   printable = yes
#[HP845c]
#printable = yes
#print command = /usr/bin/lpr -r  %s
#printer = lp
#printing = BSD
#read only = yes
#guest ok = yes
# This one is useful for people to share files
;[tmp]
;   comment = Temporary file space
;   path = /tmp
;   read only = no
;   public = yes
# A publicly accessible directory, but read only, except for people in
# the "staff" group
;[public]
;   comment = Public Stuff
;   path = /home/samba
;   public = yes
;   writeable = yes
;   printable = no
;   write list = @staff
# Other examples.
# A private printer, usable only by fred. Spool data will be placed in fred's
# home directory. Note that fred must have write access to the spool directory,
# wherever it is.
;[fredsprn]
;   comment = Fred's Printer
;   valid users = fred
;   path = /homes/fred
;   printer = freds_printer
;   public = no
;   writeable = no
;   printable = yes
# A private directory, usable only by fred. Note that fred requires write
# access to the directory.
;[fredsdir]
;   comment = Fred's Service
;   path = /usr/somewhere/private
;   public = no
;   writeable = yes
;   printable = no
# a service which has a different directory for each machine that connects
# this allows you to tailor configurations to incoming machines. You could
# also use the %U option to tailor it by user name.
# The %m gets replaced with the machine name that is connecting.
;[pchome]
;  comment = PC Directories
;  path = /usr/pc/%m
;  public = no
;  writeable = yes
# A publicly accessible directory, read/write to all users. Note that all files
# created in the directory by users will be owned by the default user, so
# any user with access can delete any other user's files. Obviously this
# directory must be writeable by the default user. Another user could of course
# be specified, in which case all files would be owned by that user instead.
;[public]
;   path = /usr/somewhere/else/public
;   public = yes
;   only guest = yes
;   writeable = yes
;   printable = no
# The following two entries demonstrate how to share a directory so that two
# users can place files there that will be owned by the specific users. In this
# setup, the directory should be writeable by both users and should have the
# sticky bit set on it to prevent abuse. Obviously this could be extended to
# as many users as required.
;[myshare]
;   comment = Mary's and Fred's stuff
;   path = /usr/somewhere/shared
;   valid users = mary fred
;   public = no
;   writeable = yes
;   printable = no
;   create mask = 0765
[HP845c1]
      printable = yes
      printer = lp
      printing = BSD
valid users = simon
      comment = HP Deskjet 845c
      browseable = no
# public = yes to allow user 'guest account' to print
public = yes
guest ok = yes
writeable = yes
printable = yes
[muziek]
      comment = Al Simon zijn smaakvolle songs
      path = /storage1/muziek
      valid users = simon jan jsb
      public = no
      writeable = yes
      printable = no
      create mask = 0765
.. Nog meer directory-shares ..
Ik wil graag mijn HP Deskjet 845c delen met Samba vanaf mijn FreeBSD server. Met behulp van het FreeBSD handbook heb ik de printer aan de gang weten te krijgen. Met lpr kan ik printen, werkt perfect. Dit kan ik doen met _elke_ user vanaf de shell.
De volgende stap is Samba, maar da's janken met de pet op. Ik had al snel de printer share en een driver in Windows geïnstalleerd voor de printer, maar als ik de taken-lijst van de printer open, krijg ik de melding toegang gewijgerd. Wat ik ook doe, toegang blijft geweigerd.
Ik heb gezocht op GoT, alles tips geprobeerd, niks hielp. Verontrustend feit: Er waren twee topics met exact hetzelfde probleem, zonder replies :(
Dus nog maar een poginkje...
Ik heb de spool-directory ook al toegankelijk gemaakt voor alle users.
De bovenstaande smb.conf is nog erger: Ik zie nu helemaal geen printers meer! Ik heb er zo in om lopen rotzooien..
Maar goed het probleem is met name die toegang geweigerd.
Remeber: Het gaat hier om FreeBSD
Da's geen Linux, FreeBSD is in de regel wat strenger met beveiliging dus dat kan die toegang geweigerd ook verklaren. Ik hoop hier een FreeBSD gebruiker te treffen die het wel voor elkaar heeft gekregen.
  • SiErRa
  • Laatst online: 14-08 13:57
Ik heb dezelfde printer ook onder freebsd (4.6) maar ik maak gebruik van cups met samba. Dit werkt verder prima.
ps. (dit is meer een tip als het niet mocht lukken)\
http://www.cups.org
  • SvMp
Op zondag 14 juli 2002 17:08 schreef SiErRa het volgende:
http://www.cups.org
Zou je je SMB.conf willen posten?
  • SiErRa
[global]
workgroup = NEEDWEBHELP.NET
server string = Samba Server
hosts allow = 10.0.0. 127.
load printers = yes
# system
# Cups printing system
printcap name = cups
printing = cups
# that connects
max log size = 50
security = user
# The argument list may include:
# password server = My_PDC_Name [My_BDC_Name] [My_Next_BDC_Name]
# or to auto-locate the domain controller/s
# password server = *
# Note: Do NOT use the now deprecated option of "domain controller"
# This option is no longer implemented.
# You may want to add the following on a Linux system:
# SO_RCVBUF=8192 SO_SNDBUF=8192
interfaces = 10.0.0.0/24
local master = yes
os level = 33
domain master = yes
; domain logons = yes
; logon script = %U.bat
wins support = yes
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
# at least one WINS Server on the network. The default is NO.
; wins proxy = yes
dns proxy = no
# for Greek users
; coding system=cap
; coding system=cap
# for Korean Users
; coding system=cap
; coding system=cap
[homes]
browseable = no
writeable = yes
# Un-comment the following two lines to add a recycle bin facility to a samba share
# NOTE: It currently doesn't work with the [homes] virtual share, use a regular share instead
; vfs object = /usr/local/lib/samba/recycle.so
; vfs options= recycle=.recycle
; [netlogon]
; guest ok = yes
; writeable = no
; share modes = no
;[Profiles]
; browseable = no
; guest ok = yes
[printers]
browseable = no
guest ok = no
writeable = no
printable = yes
;[tmp]
; path = /tmp
; read only = no
; public = yes
# the "staff" group
[public]
comment = Public File Storage
path = /home/samba
public = yes
writeable = yes
printable = no
write list = @staff
# Other examples.
# wherever it is.
;[fredsprn]
; public = no
; writeable = no
; printable = yes
;[fredsdir]
; public = no
; writeable = yes
; printable = no
;[pchome]
; path = /usr/pc/%m
; public = no
; writeable = yes
;[public]
; public = yes
; only guest = yes
; writeable = yes
; printable = no
;[myshare]
; public = no
; writeable = yes
; printable = no
  • Roeland4
  • Laatst online: 28-06 17:54
Ik kan via FreeBSD printen. Dit is mijn smb.conf
onderaan staat ook nog printcap.
Het printen zelf geeft geen problemen bij mij, alleen heb ik een probleem dat al mijn documenten in de wachtrij blijven staan in windows. Staan er nu al een paar honderd.
Als iemand dit kan oplossen :)
SMB.CONF
29
[global]
   workgroup = WORKGROUP
   server string = De server
   hosts allow = 192.168.1. 127.
   load printers = yes
   printing = bsd
   max log size = 50
   security = share
   dns proxy = no
[homes]
   browseable = no
   writeable = yes
[laserjet]
  path=/var/spool/lpd/laserjet
  public=yes
  printable=yes
  writeable=yes
  comment = HP Laserjet 6L
  printer driver = HP Laserjet 6L
Hier nog een deel gedeelde mappen
PRINTCAP:
laserjet|HP Laserjet 6L:\
:lp=/dev/lpt0:sd=/var/spool/lpd/laserjet:\
:lf=/var/log/lpd-errs:sh:mx#0:\
:sf:
code tags gebruikt
