Vraagjes over de Compaq DLP MP2810 beamer
  • ken
  • Laatst online: 11-10 16:26
Ik wil graag een 2de handse beamer kopen
Nu heb ik al wat op internet zitten zoeken en kwam ik uiteindelijk op de Compaq DLP MP2810
url http://www.compaq.com/products/projectors/mp2810/
De spec:
Brightness 1500 peak lumens (1100 ANSI lumens)
Portability
General Fits in existing notebook carrying case along with notebook computer. Additional traveling case also included.
Size/Volume (HxWxD) 18.06 x 6.89 x 22.13 cm and 1937 cubic cm
Weight 1.36 kg
Casing Magnesium (Stronger than plastics; 30% lighter than aluminum)
Display Resolution Displays native XGA (1024 x 768) resolution but will automatically scale up from VGA and SVGA or down from SXGA to fill screen. Will also scale from Macintosh 832 x 624 compatible.
Image Quality
Technology Texas Instruments Digital Light Processing (DLP) technology
Contrast 400:1 contrast full-on; 150:1 checkerboard
Color SMPTE-C, 24 bit, 16.7M
White Point 8000° Kelvin
Uniformity 70%
Plug and Play Yes
Lens
Type Adjustable Focal Length Zoom lens (1.2x) and manual adjustable focus
Throw Ration (D/W) 2.0:1 - 2.4:1
Lens Height 15.18 cm
Throw distance 1.14 to 10 m
Offset 128% of image above center line
Focus Manual focus via focus ring around lens
Keystoning Digital keystone correction (corrects angle up to 150)
Connectivity
Signal Interface Standard analog VGA, DVI, S-Video, RCA Video, and audio cables
User Interface Standard Compaq 3 button OSD (includes zoom and keystone correction), Power and Re-synch
Standards Supported VGA and DVI
USB Capabilities 8-pin to USB/RS-232 cable included with Multimedia Adapter for remote mouse functions
Approvals/Certifications CE, C.I.S.P.R., VDE / TUV, UL Approval, FCC Class B Approval
Multimedia Adapter Yes
Remote Control Yes
On-Screen Controls Yes
Language Selection English, German, French, Spanish, Italian, Dutch, Japanese, Chinese
User Controls Brightness, Contrast, Positioning, Keystone Correction, Digital Zoom, Clock, Clock Phase, Color Temperature, Picture Control, HDTV Settings, Menu Location Control, Power Saver, Lamp Hours, Lamp Hours Reset, Standby Lamp Delay, Serial Number, Master Reset, Image Control (upside down, reverse, upside down and reversed)
Tilt Feature Up to 10 degrees
Horizontal Frequency 31.5 to 80 kHz for analog signals and 31.5 to 60 kHz for digital signals
Vertical Frequency 48 to 85 Hz for analog signals and 48 to 85 Hz for digital signals
Power Consumption 5 Watts (standby)/185 Watts (full power)
Operating Temperature 50° to 104°F/10° to 40°C
Operating Humidity 20% to 80%
Video Projector is capable of displaying video from a VGA or DVI source (example: DVD on Portable PC). Video and S-Video capability (from DVD, Camcorder, VCR, game center, satellite receiver) through the included multimedia adapter
HDTV Support 720p, 1080i
Audio Multimedia adapter has integrated 8-watt PremieroSound speaker system.
Power supply 90V to 255V (auto switching): warm restrike after 45 seconds
Lamp/Module User Replaceable
Noise level 36 decibels
Warranty The MP2810 projector comes with a two-year worldwide limited warranty. In North America, Europe and Asia Pacific, the Advanced Unit Replacement program offers a new or "like new" replacement of a defective unit in 48 hours during the two-year warranty period. In all other regions, a replacement is available by mail-in. There is a 90-day standard bulb warranty. Within the bulb warranty period, defective bulbs will be replaced via overnight shipment.
Mijn vragen zijn:
Ondersteund deze wel of geen 1024x768??
Is deze beamer voldoende om DVD te bekijken en games op te spelen??
Het is dus alleen voor films en games op te spelen
Moet dus wel goed beeld geven (in het donker en licht)
Is deze voldoende??
thnx
Canon 5D Mark II, Canon 35 f/1.4L
  • twiekert
  • Laatst online: 11-10 16:17
die beamer ondersteund native 1024x768, de reso daarboven (SXGA,1280x1024) wordt naar 1024x768 geschaald.
1100 ansi lumen is zat om met daglicht nog te wat te zien.
Ik heb zelf ook een beamer(tje). 640x480, 350 ansi lumen, en is voldoende om savonds goed film te kunnen kijken.
Die dingen zijn gewoon uber-geil :P
moet ff picjes posten, kan het niet laten:
Afbeeldingslocatie: http://httpd.chello.nl/~jstienstra01/got/pic_sg1.jpg
is 1.5mtr breed x 1.5mtr hoog voor 4:3 en breedbeeld 1.5 breed x 60cm hoog.
Move VB --> [forum=9], daar zitten de beamerfreaks (alhoewel ik er toch ook wel 1-tje ben) ;)
  • ken
ok thanx
dus deze is goed genoeg voor dvd en games :)
DVD kijken met een beamer is echt :9~
  • sebas82
  • Laatst online: 23-10-2024
om dvd's te kijken heb je niet zo'n hoge resolutie nodig... 800x600 is zat
  • ken
wat ik me afvraag is
Waar gebruik je een beamer voor met 2000+ANSI Limens en helderheid van 1:800 :?
  • Bierkameel
Bierkameel
I use Debian btw
Op zondag 14 juli 2002 23:14 schreef ken het volgende:
Om dingen bij veel daglicht ook nog te zien?
Ik heb geen verstand van beamers :)
Alle proemn in n drek
  • ken
stel ik heb 2 beamers
1 = 1100 ANSI Lumens en 1= 1600
Is het verschil dan goed te zien als je deze in dezelfde ruimte plaats
Dus evenveel licht etc :?
